Нет звука через динамики на ноутбуке
Artyom
02 окт 2021, 21:17
Здравствуйте, установил LM Cinnamon 20.2 с оф.сайта. Но почему-то нет звука через динамики (через наушники все нормально). Проверял через alsamixer и pavucontrol - динамики распознаются (см. скрины), но звука нет. Ума не приложу что не так.
Kernel: 5.4.0-88-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 5.0.5 Distro: Linux Mint 20.2 Uma
base: Ubuntu 20.04 focal
Type: Laptop System: Micro-Star product: GP75 Leopard 9SD v: REV:1.0
serial: <filter>
Mobo: Micro-Star model: MS-17E2 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E17E2IMS.112 date: 06/14/2019
ID-1: BAT1 charge: 25.8 Wh condition: 39.6/51.6 Wh (77%) model: MSI BIF0_9
status: Charging
Device-1: hidpp_battery_0
model: Logitech G305 Lightspeed Wireless Gaming Mouse
charge: 100% (should be ignored) status: Discharging
Topology: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 12.0 MiB
bogomips: 62399
Speed: 3506 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 2484 2: 2583
3: 2571 4: 2530 5: 2410 6: 2486 7: 2577 8: 2357 9: 2484 10: 2562 11: 2170
12: 2443
Device-1: Intel UHD Graphics 630 vendor: Micro-Star MSI driver: i915
v: kernel bus ID: 00:02.0
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile]
vendor: Micro-Star MSI driver: N/A bus ID: 01:00.0
Display: x11 server: X.Org 1.20.11 driver: modesetting
unloaded: fbdev,vesa resolution: 1920x1080~144Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.0.3
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
Sound Server: ALSA v: k5.4.0-88-generic
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
v: kernel port: 5000 bus ID: 00:14.3
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: 3000 bus ID: 03:00.0
Local Storage: total: 1.14 TiB used: 16.06 GiB (1.4%)
ID-1: /dev/nvme0n1 vendor: Western Digital
model: PC SN520 SDAPNUW-256G-1032 size: 238.47 GiB
ID-2: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
ID-1: / size: 48.97 GiB used: 16.03 GiB (32.7%) fs: ext4
dev: /dev/nvme0n1p5
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 311 Uptime: 23m Memory: 15.48 GiB used: 2.68 GiB (17.3%)
inxi: 3.0.38
EDIT: Случайно прикрепил скрин где подключены наушники, вот правильный:
03 окт 2021, 00:55
Посмотрите это обсуждение, м.б. наведёт на какие-нибудь мысли. Может быть ещё здесь, здесь, здесь.
Artyom
03 окт 2021, 21:19
madesta, спасибо! Добавил options snd-hda-intel model=clevo-p950 в конец /etc/modprobe.d/alsa-base.conf. После перезагрузки все заработало.
Вернуться в «Звуковые карты»
