ax200 не инециализируется после перезагрузки
seregka
Благодарил (а): 2 раза
25 сен 2021, 19:20
LM20.2 x64
Ноутбук Acer aspire 3 a317-32
Поставил минт одной системой при установке отключил секьюрити бут как в биосе так и через mokutil --disable-validation
Железо
System: Kernel: 5.4.0-86-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 5.0.5
Distro: Linux Mint 20.2 Uma base: Ubuntu 20.04 focal
Machine: Type: Laptop System: Acer product: Aspire A317-32 v: V1.06 serial: <filter>
Mobo: GLK model: Dopey_GL v: V1.06 serial: <filter> UEFI: Insyde v: 1.06 date: 06/19/2020
Battery: ID-1: BAT1 charge: 31.9 Wh condition: 33.0/37.0 Wh (89%) model: Murata AP16M4J
status: Charging
CPU: Topology: Quad Core model: Intel Pentium Silver N5030 bits: 64 type: MCP arch: Goldmont Plus
rev: 8 L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8755
Speed: 1568 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 1189 2: 1139 3: 1308 4: 1307
Graphics: Device-1: Intel UHD Graphics 605 vendor: Acer Incorporated ALI driver: i915 v: kernel
bus ID: 00:02.0
Display: x11 server: X.Org 1.20.11 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 605 (GLK 3) v: 4.6 Mesa 21.0.3 direct render: Yes
Audio: Device-1: Intel vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 00:0e.0
Sound Server: ALSA v: k5.4.0-86-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000 bus ID: 01:00.0
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lite-On
driver: ath10k_pci v: kernel port: 2000 bus ID: 02:00.0
Drives: Local Storage: total: 238.47 GiB used: 45.68 GiB (19.2%)
ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3256GJ1 size: 238.47 GiB
Partition: ID-1: / size: 73.31 GiB used: 17.97 GiB (24.5%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /home size: 157.50 GiB used: 13.85 GiB (8.8%) fs: ext4 dev: /dev/nvme0n1p4
ID-3: swap-1 size: 1.95 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 69.0 C mobo: N/A
Info: Processes: 243 Uptime: 49m Memory: 7.58 GiB used: 1.68 GiB (22.1%) Init: systemd runlevel: 5
Compilers: gcc: 9.3.0 Shell: bash v: 5.0.17 inxi: 3.0.38
со штатным модулем полет без проблем
Установив модуль он запускается но стоит перезагрузиться и он вообще пропfдает как будто его нет в lspci пусто насчет чего либо похожего
Чтобы он появился нужно включить секьюрите бут и он появится опять перезагрузишься он пропадет и что бы появился нужно включить секьюрети бут.
Все че перепробовал в интернете мне не помогло.
А еще момент насколько я понял wifi 5 сити тоже не видет
Будьте добрее к этому миру, даже если мир не добр к вам.
seregka
28 сен 2021, 10:22
Дело такое wifi работает в любом режиме хоть с включенным секьюрити бут хоть с выключенным до первой презагрузки если перед этим сделать сброс маленькая дырочка и значок скрепки на нижней крышке ноутбука.
seregka
28 сен 2021, 11:55
Вот какая штука он пропадает только когда перезагрузка а если я выключаю и потом включаю все работает как надо!
29 сен 2021, 14:27
А если после перезагрузки в NM выключить wifi (или поддержку сети), а потом включить снова, то wifi появляется или нет?
seregka
02 окт 2021, 17:17
madesta писал(а):
29 сен 2021, 14:27
Кароче он пропадает только после перезагрузки вообщм nm отсутстсвует переключатель беспроводной сети.
Там я нашел что вроде как это связанно с режимом энергосбережние оключил но резултьтат тот же в общем забил презагружаюсь через выключение
Ну а так модуль работает самолет бываю небольшие траблы с блютозом но мелочи.
Скорость у дикая
iw dev wlp2s0 link
Connected to 38:6b:1c:4c:f9:6e (on wlp2s0)
SSID: NelsonMandela
freq: 2457
RX: 2232450412 bytes (1527537 packets)
TX: 67055144 bytes (505267 packets)
signal: -41 dBm
rx bitrate: 270.0 MBit/s MCS 15 40MHz
tx bitrate: 300.0 MBit/s MCS 15 40MHz short GI
bss flags: short-slot-time
dtim period: 1
beacon int: 100
seregka
05 окт 2021, 15:06
Появилась новая беда с данным модулем но уже с блютозом не стабильное соединение с постоянными разрывами.
