Не удаётся установить packet tracer 8.0.1
Melior
11 сен 2021, 10:13
Linux mint 20.2 cinnamon
При попытке установки появляется эта ошибка
(Reading database ...
(Reading database ... 5%%
(Reading database ... 10%%
(Reading database ... 15%%
(Reading database ... 20%%
(Reading database ... 25%%
(Reading database ... 30%%
(Reading database ... 35%%
(Reading database ... 40%%
(Reading database ... 45%%
(Reading database ... 50%%
(Reading database ... 55%%
(Reading database ... 60%%
(Reading database ... 65%%Linux mint
(Reading database ... 70%%
(Reading database ... 75%%
(Reading database ... 80%%
(Reading database ... 85%%
(Reading database ... 90%%
(Reading database ... 95%%
(Reading database ... 100%%
(Reading database ... 401872 files and directories currently installed.)
Preparing to unpack .../CiscoPacketTracer_801_Ubuntu_64bit.deb ...
dpkg: error processing archive /home/sanzhar/Downloads/CiscoPacketTracer_801_Ubuntu_64bit.deb (--install):
new packettracer package pre-installation script subprocess returned error exit status 1
gtk-update-icon-cache: Cache file created successfully.
Errors were encountered while processing:
Kernel: 5.4.0-84-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 5.0.5 Distro: Linux Mint 20.2 Uma
base: Ubuntu 20.04 focal
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX505DT.316 date: 01/28/2021
ID-1: BAT0 charge: 38.3 Wh condition: 39.4/48.1 Wh (82%) model: FX50442
status: Unknown
Topology: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 33538
Speed: 1396 MHz min/max: 1400/2100 MHz Core speeds (MHz): 1: 1271 2: 1231
3: 1288 4: 1264 5: 1289 6: 1327 7: 1497 8: 1448
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 470.63.01 bus ID: 01:00.0
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 05:00.0
Display: x11 server: X.Org 1.20.11 driver: amdgpu,ati,nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~120Hz
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.35.0
5.4.0-84-generic LLVM 12.0.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 01:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 05:00.6
Sound Server: ALSA v: k5.4.0-84-generic
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.0
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtl8821ce v: v5.5.2.1_35598.20191029 port: d000
bus ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 715.41 GiB used: 47.90 GiB (6.7%)
ID-1: /dev/nvme0n1 vendor: Micron model: 2200V MTFDHBA512TCK
ID-2: /dev/sda vendor: Team model: T253X2256G size: 238.47 GiB
ID-1: / size: 131.92 GiB used: 44.01 GiB (33.4%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 93.06 GiB used: 3.88 GiB (4.2%) fs: ext4 dev: /dev/sda4
ID-3: swap-1 size: 7.64 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
System Temperatures: cpu: 59.4 C mobo: N/A gpu: amdgpu temp: 60 C
Fan Speeds (RPM): cpu: 2700
Processes: 289 Uptime: 16m Memory: 13.66 GiB used: 2.20 GiB (16.1%)
inxi: 3.0.38
Решение Melior » 11 сен 2021, 10:48
Так, я разобрался. Нужно было просто использовать команду
sudo dpkg -i CiscoPacketTracer_801_Ubuntu_64bit.deb
11 сен 2021, 10:37
Возможно пакет или криво собран, или криво скачался
Melior
11 сен 2021, 10:39
11 сен 2021, 10:37
Я его с оф сайта 2 раза скачивал. А что можно сделать?
Melior
11 сен 2021, 10:48
11 сен 2021, 10:49
Melior писал(а):
11 сен 2021, 10:48
Так надо было начинать с того как ты пытаешься установить - тут нет экстрасенсов
Melior
11 сен 2021, 10:58
11 сен 2021, 10:49
Melior писал(а):
11 сен 2021, 10:48
Я до этого не пользовался linux'ом и не знал, что .deb можно устанавливать как-нибудь по другому.
