тусклый экран
tARTar
тусклый экран
10 сен 2021, 22:57
не работают клавиши изменения яркости на ноутбуке.Точнее работают, но яркость не меняют, и ползунок в настройках не работает. экран очень тусклый, неудобно работать(не могу изменить яркость никак)...
1.Linux Mint 20.2 "Uma" - Cinnamon (64-bit)
2.
Kernel: 5.4.0-84-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 5.0.5 Distro: Linux Mint 20.2 Uma
base: Ubuntu 20.04 focal
Type: Laptop System: HP product: HP Laptop 15s-eq2xxx v: N/A
serial: <filter>
Mobo: HP model: 887A v: 59.08 serial: <filter> UEFI: AMI v: F.03
date: 03/10/2021
ID-1: BAT0 charge: 40.6 Wh condition: 41.5/41.5 Wh (100%)
model: HP Primary status: Charging
Topology: 8-Core model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64
type: MT MCP arch: Zen rev: 1 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 57496
Speed: 1262 MHz min/max: 1400/1800 MHz Core speeds (MHz): 1: 1275 2: 1383
3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1260 10: 1242 11: 1287
12: 1310 13: 1604 14: 1528 15: 1397 16: 1397
Device-1: AMD vendor: Hewlett-Packard driver: N/A bus ID: 03:00.0
Display: x11 server: X.Org 1.20.11 driver: ati,fbdev
unloaded: intel,modesetting,vesa resolution: 1920x1080~77Hz
OpenGL: renderer: llvmpipe (LLVM 12.0.0 256 bits) v: 4.5 Mesa 21.0.3
Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 03:00.1
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel bus ID: 03:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 03:00.6
Sound Server: ALSA v: k5.4.0-84-generic
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_pci v: N/A port: f000 bus ID: 01:00.0
Local Storage: total: 476.94 GiB used: 10.43 GiB (2.2%)
ID-1: /dev/nvme0n1 model: KBG40ZNV512G KIOXIA size: 476.94 GiB
ID-1: / size: 100.34 GiB used: 9.98 GiB (9.9%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /home size: 100.94 GiB used: 432.2 MiB (0.4%) fs: ext4
dev: /dev/nvme0n1p6
System Temperatures: cpu: 50.6 C mobo: N/A
Processes: 322 Uptime: 14m Memory: 15.05 GiB used: 1.38 GiB (9.2%)
inxi: 3.0.38
Whowka
Благодарил (а): 777 раз
тусклый экран
11 сен 2021, 00:49
tARTar, С нубуками мало имел дел, но, так навскидку: Может в параметрах энергосбережения(ну , или какое-то подобное название) настройки посмотреть?
Благодарил (а): 1737 раз
тусклый экран
11 сен 2021, 01:53
tARTar, так работают или нет? Сами определитесь или переформулируйте...
ilikethat
Решено: 10
Благодарил (а): 130 раз
тусклый экран
11 сен 2021, 09:10
tARTar, у тебя свежий Ryzen. Нужно более новое ядро.
Зайди в Менеджер обновлений, Ядра Linux.
Выбери ядро 5.11
тусклый экран
11 сен 2021, 10:43
WWolf, недавно где-то читал, как товарищ столкнулся с такой же бедой.
Сами клавиши работают. Т.е. при нажатии появляется индикатор, показывающий уровень подсветки. На этом индикаторе уровень изменяется, но фактически уровень яркости не меняется. Т.е. вот как она установилась при загрузке системы так и остается
tARTar, поиск по форуму не пробовал? уже не раз обсуждали и находили решения
kobolt
Решено: 6
Благодарил (а): 40 раз
тусклый экран
11 сен 2021, 11:00
У меня на ноуте такая ерунда была году в 15. Через редактирование файликов решал вопрос, а потом как-то само все прошло. Также настраивал кнопки на ноуте, также через конфиг.
Ноутбук: ASUS Vivobook S301LA
inxi
Machine: Mobo: ASUSTeK model: S301LA
CPU: Dual core Intel Core i3-4010U
Graphics: Card: Intel Haswell-ULT Integrated Graphics Controller (Intel HD Graphics 4400)
ОС и рабочее окружение:
Linux Mint 17 Qiana x64 Cinnamon
Проблема: после установки Linux Mint 17 Qiana x64 на ноутбук, не работают клавиши Fn+F1,F2,F5,F6, то есть не регулируется яркость, не включаются "Ждущий режим" и Wi-Fi.
Потратив пару часиков на поиски в интернете, было найдено несколько вариантов решения вопроса.
1-ый способ
Частичное решение вопроса, только регулировка яркости:
Устанавливаем утилитку xbacklight, в терминале:
Код PHP:
sudo apt-get install xbacklight
Добавляем комбинации клавиш:
Меню->Настройки->Клавиатура->Комбинации клавиш->Дополнительные комбинации клавиш->Добавить пользовательскую комбинацию
Снижение яркости на 10%
Название: < любое >
Команда: xbacklight -10 (или любое другое число от 0 до 100)
Привязка клавиш: Ctrl-F5 (можно другие удобные вам клавиши)
Повышение яркости на 10%
Название: < любое >
Команда: xbacklight +10 (или любое другое число от 0 до 100)
Привязка клавиш: Ctrl-F6
Недостатки: после перезагрузки яркость снова выставляется на максимум, всё равно не работают клавиши Fn+F1,F2.
2-ой способ
Редактируем загрузчик GRUB следующим образом:
В терминале
Код PHP:
sudo gedit /etc/default/grub
Добавляем в строку GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" параметр <acpi_osi=>
Получим: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi="
Обновляем GRUB командой
Код PHP:
sudo update-grub
Перезагружаемся.
Теперь все клавиши работают как надо.
Мне тогда помогало.
warning
Решено: 7
Благодарил (а): 161 раз
тусклый экран
11 сен 2021, 13:27
У меня была когда-то такая трабла.
делал следующее:
sudo nano /etc/default/grub
приводил к виду: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
Сохраняем, выходим из редактора
Применяем обновления :
sudo update-grub
hw-probe: тыц!
