Драйвера NVIDIA
serge61
Благодарил (а): 19 раз
Драйвера NVIDIA
20 авг 2021, 19:54
Установил LM 20.2, после установки все обновил, но есть такой момент, не отображаются настройки (NVIDIA X Server Settings) появляется маленькое окно и все.
serge@serge-mint:~$ inxi -Fxz
Kernel: 5.4.0-81-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 5.0.5 Distro: Linux Mint 20.2 Uma
base: Ubuntu 20.04 focal
Type: Laptop System: LENOVO product: 81DC v: Lenovo ideapad 330-15IKB
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
v: 8RCN55WW date: 06/19/2020
ID-1: BAT0 charge: 24.8 Wh condition: 25.7/30.0 Wh (86%)
model: SMP L17M2PB7 status: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
charge: 55% (should be ignored) status: Discharging
Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber Lake rev: 9 L2 cache: 3072 KiB
bogomips: 21599
Speed: 700 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 700 2: 700
3: 700 4: 700
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0
Device-2: NVIDIA GM108M [GeForce MX110] vendor: Lenovo driver: N/A
bus ID: 01:00.0
Display: x11 server: X.Org 1.20.11 driver: modesetting
unloaded: fbdev,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.3
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
Sound Server: ALSA v: k5.4.0-81-generic
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel port: 3000 bus ID: 03:00.0
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-7:3
Local Storage: total: 1.14 TiB used: 13.84 GiB (1.2%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD 870 EVO 1TB size: 931.51 GiB
ID-1: / size: 45.50 GiB used: 13.81 GiB (30.4%) fs: ext4 dev: /dev/sdb5
System Temperatures: cpu: 38.5 C mobo: N/A
Processes: 213 Uptime: 17m Memory: 11.61 GiB used: 2.20 GiB (19.0%)
inxi: 3.0.38
serge@serge-mint:~$
ubuntu-drivers devices
serge@serge-mint:~$ ubuntu-drivers devices
WARNING:root:_pkg_get_support nvidia-driver-390: package has invalid Support Legacyheader, cannot determine support level
== /sys/devices/pci0000:00/0000:00:1c.0/0000:01:00.0 ==
modalias : pci:v000010DEd0000174Esv000017AAsd00003978bc03sc02i00
vendor : NVIDIA Corporation
model : GM108M [GeForce MX110]
driver : nvidia-driver-460 - distro non-free
driver : nvidia-driver-460-server - distro non-free
driver : nvidia-driver-470 - distro non-free recommended
driver : nvidia-driver-390 - distro non-free
driver : nvidia-driver-450-server - distro non-free
driver : nvidia-driver-418-server - distro non-free
driver : nvidia-driver-470-server - distro non-free
driver : xserver-xorg-video-nouveau - distro free builtin
Буду благодарен за любую помощь
Whowka
Благодарил (а): 777 раз
Драйвера NVIDIA
20 авг 2021, 20:11
serge61,
Тыц
serge61
Драйвера NVIDIA
20 авг 2021, 20:14
Конечно пользовался поиском( но ответ не нашел :blush: может ссылку скинете?
Whowka
Драйвера NVIDIA
20 авг 2021, 20:18
serge61, Дык в "Тыц" мышой кликните :smile:
serge61
Драйвера NVIDIA
25 авг 2021, 18:17
Спасибо с этим разобрался, проблема в том, что пока не вернеш все настройки в биосе по дефолту, то есть должен быть включен legacy boot и Secure Boot, не хочет работать NVIDIA, вернул настройки все драйвера без проблем установились
Есть еще одна проблема, NVIDIA, как мне кажется работает неправильно, температура 55-59 градусов и постоянно крутит куллер, ноут ощутимо горячий, ниже ссылка на на вывод инфы из Утилита-агрегатор логов и сведений о системе - hw-probe может по логам можно что то понять?
https://linux-hardware.org/?probe=e864d693e4
Благодарил (а): 54 раза
Драйвера NVIDIA
25 авг 2021, 18:24
serge61 писал(а):
25 авг 2021, 18:17
Для драйвера nvidia должен быть ВЫКЛЮЧЕН Secure Boot. При включенном же legacy - он по факту и есть выключенный, т.к. legacy его не поддерживает.
serge61
Драйвера NVIDIA
25 авг 2021, 18:51
25 авг 2021, 18:24
Да, все правильно, сейчас еще раз в биос заглянул, спасибо
По поводу моей проблемы не подскажете?
Драйвера NVIDIA
25 авг 2021, 21:03
serge61 писал(а):
25 авг 2021, 18:51
Если про температуру - дык не факт что это именно проблема. Возможно для данной машины это норма. А если такого раньше не было и это таки проблема, то с ней только в сервис - чистить и менять термопасту.
Благодарил (а): 1737 раз
Драйвера NVIDIA
25 авг 2021, 21:11
serge61, хочешь холодный бук, поставь свободный драйвер, поиграйся с ядрами, смени ДЕ...
Oleg_Y_Oleg
Драйвера NVIDIA
25 авг 2021, 22:30
Незнаю как вам, у меня от Mint 20.2 XFCE - одно расстройство. И на Нвидии 1050 ти, постоянно что-то не то, и АСПИ ругается на всё что только можна, и дисковая подсистема - работает медленнее, чем на 19,3. Пришлось ставить старика, ядро 4,15 и последний драйвер из сайта Нвидии. Может комп и несвежий, но : i5 - 3570/Asus P8Z77V-pro/8G DDR3/Nvidia 1050ti/WD Black 500Gb.
serge61
Драйвера NVIDIA
25 авг 2021, 23:07
Мне пока не с чем сравнить, кроме как с виндой, карта там холодная, вот по этому и вопросы, все таки я думаю что должны быть какие то настройки NVIDIA, в системе ни чего не установлено, открыт браузер и пара тройка страниц...а если не дай Бог игрушку какую то запустить-сгорит :blush:
WWolf да со свободным драйвером с темп-рой все нормально, но почему то мне кажется, что работает не NVIDIA а графика Intel
Драйвера NVIDIA
25 авг 2021, 23:44
serge61, когда кажется, креститься надо :)
на винде работает оптимус - когда на встройке крутится всё, а нвидиа включается в производительные моменты...
на линукс нвидиа (фак нвидиа(с) Торвальдс ) оптимус не завезли, потому когда ты ставишь драйвер и активируешь его у тебя всё крутится исключительно на нвидиа, отсюда и температура и вентиляторы орут...
свободный драйвер частично этот оптимус пытается крутить, но без исходников (фак нвидиа ту) реверс инженирингом это полноценно не получить - отсюда имеем меньшую производительность (хотя на старых картах свободный уже даже обгоняет проприентарщину), но и меньшую температуру...
поэтому тут надо самому выбирать какой драйвер использовать в зависимости от сценариев работы...
опять же корица достаточно жрущее ДЕ, поэтому можно посмотреть как на других - опять же сугубо личное дело
Драйвера NVIDIA
26 авг 2021, 04:14
Это же какие задачи нужно решать на ноутбуке, чтобы стоял именно драйвер NVIDIA? Свободного драйвера не хватает, чтобы смотреть кино и производить не шибко сложное редактирование изображений и видео?
Драйвера NVIDIA
26 авг 2021, 07:37
madesta писал(а):
26 авг 2021, 04:14
А поиграть?
Драйвера NVIDIA
26 авг 2021, 11:18
madesta, со свободным драйвером тоже не всё гладко в некоторых задачах :) на ум сразу приходит 9800GT и KiCad, который на свободном драйвере виснет при 3D рендере печатной платы, а на проприентарном всё нормально :)
serge61
Драйвера NVIDIA
26 авг 2021, 17:06
WWolf, спасибо за содержательный ответ, правда вопросов появилось еще больше, я хочу остаться на Linux, достала уже винда, по этому в инете ищу инфу, под час она противоречива, по этому приходится задавать простые вопросы...что бы для себя понять некоторые моменты.
Значит так, драйвера NVIDIA работают криво на Linux? По крайней мере в моем случае, или возможно это связано с огрангиченым пространством в ноуте для эфективного охлождения карты, ( хотя повторюсь в винде проблем нет, и там в настройках выбран режим именно NVIDIA а не АВТО) то есть, например в компе, возможно с более мощьной картой этот момент будет малозаметен?
26 авг 2021, 07:37
А поиграть?
Именно, это немаловажный момент, в игры я совсем не играю, вопрос в другом, почему бы и нет? I5 седьмого поколения, не самый плохои процессор плюс NVIDIA, должно ирать без проблем в неэнергоемкие игры, но в моем случае это не получится :blush:
Драйвера NVIDIA
26 авг 2021, 17:37
serge61 писал(а):
26 авг 2021, 17:06
Да, технологию OPTIMUS не завезли зелёные в линукс, а в винду завезли, потому там и холодный бук. Хочешь холодный бук ставь свободные драйвера, в некоторых (наверное уже даже во многих) сценариях использования они уделывают дрова от зелёных.
С играми тут уже конкретно от игры зависит, что-то на свободном взлетит и хорошо, что-то взлетит, но не особо, а что-то не взлетит совсем без драйвера зелёных. Каждый конкретный случай отдельно надо разбирать и искать решение.
Вернуться в «Видеокарты»
