Проблема с browser-sync в gulp
vladimir146
Благодарил (а): 3 раза
16 авг 2021, 17:08
LM 20.2 x64 Cinamon, железо:
System:~$ inxi -Fxz
  Kernel: 5.4.0-80-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: Cinnamon 5.0.5 Distro: Linux Mint 20.2 Uma
  base: Ubuntu 20.04 focal
  Type: Desktop Mobo: ASUSTeK model: H110M-R v: Rev X.0x serial: <filter>
  UEFI [Legacy]: American Megatrends v: 3401 date: 03/20/2017
  Device-1: hidpp_battery_0 model: Logitech M215
  charge: 55% (should be ignored) status: Discharging
  Topology: Dual Core model: Intel Celeron G3930 bits: 64 type: MCP
  arch: Kaby Lake rev: 9 L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11599
  Speed: 800 MHz min/max: 800/2900 MHz Core speeds (MHz): 1: 800 2: 800
  Device-1: Intel HD Graphics 610 vendor: ASUSTeK driver: i915 v: kernel
  bus ID: 00:02.0
  Display: x11 server: X.Org 1.20.11 driver: modesetting
  unloaded: fbdev,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 610 (KBL GT1) v: 4.6 Mesa 21.0.3
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
  Sound Server: ALSA v: k5.4.0-80-generic
  vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.0
  Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
  driver: r8188eu bus ID: 1-6.3:6
  IF: wlx503eaa451cd9 state: up mac: <filter>
  Local Storage: total: 1.36 TiB used: 1021.54 GiB (73.3%)
  ID-1: /dev/sda vendor: Samsung model: SSD 850 PRO 256GB size: 238.47 GiB
  ID-2: /dev/sdb vendor: Seagate model: ST380011A size: 74.53 GiB
  ID-3: /dev/sdc vendor: Seagate model: ST3160813AS size: 149.05 GiB
  ID-4: /dev/sdd type: USB vendor: Toshiba model: External USB 3.0
  ID-1: / size: 48.95 GiB used: 16.13 GiB (33.0%) fs: ext4 dev: /dev/sda5
  ID-2: /home size: 77.11 GiB used: 9.95 GiB (12.9%) fs: ext4 dev: /dev/sda6
  ID-3: swap-1 size: 4.00 GiB used: 512 KiB (0.0%) fs: swap dev: /dev/sda4
  System Temperatures: cpu: 34.0 C mobo: N/A
  Processes: 207 Uptime: 3h 41m Memory: 7.64 GiB used: 1.27 GiB (16.6%)
  inxi: 3.0.38
Работаю с VScode + Gulp, при использовании browser-sync, раньше все отрабатывало нормально, но после установки Apache2, перестал автоматически запускаться браузер, в ручном режиме запускается и далее работает штатно (страницы обновляются из Gulp) я так понимаю проблема в том, что работают 2 сервера, но принудительная остановка апача не помогает, Google тоже не помог, в принципе работать можно и в таком режиме, но может кто-нибудь сталкивался с такой проблемой? Apache мне тоже иногда нужен для запуска сайтов на PHP, так-что сносить его не вариант.
  Local: http://localhost:3000
    External: http://192.168.100.6:3000
          UI: http://localhost:3001
 UI External: http://localhost:3001
[Browsersync] Serving files from: ./fls_start_130821/
[Browsersync] Couldn't open browser (if you are using BrowserSync in a headless environment, you might want to set the open option to false)
Порты менял, браузеры менял, при запуске browser-sync из командной строки браузер запускается
browser-sync start --server
, а из gulp
function browserSync(done) {
	browsersync.init({
		server: {
			baseDir: "./" + project_name + "/"
		notify: false,
		port: 3000,
выдает ошибку
Дорогу осилит идущий...
16 авг 2021, 19:25
vladimir146 писал(а):
16 авг 2021, 17:08
выдает ошибку
а показать?
vladimir146
16 авг 2021, 20:16
Выше под спойлером - [Browsersync] Couldn't open browser (if you are using BrowserSync in a headless environment, you might want to set the open option to false) - до установки апача все работало без ошибки. если вручную запустить браузер (http://localhost:3000) то дальше все отрабатывает без проблем
[20:28:13] Starting 'html'...
[Browsersync] 1 file changed (index.html)
[20:28:13] Finished 'html' after 148 ms
[Browsersync] Reloading Browsers...
