Проблема с запуском игры через Wine (X Error of failed request: GLXBadFBConfig)
Модератор: WWolf
Sanchez
15 авг 2021, 15:33
Сама ошибка:
wine ~/.wine/drive_c/Games/Misao/LAUNCHER.exe
002e:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
Setting breakpad minidump AppID = 691450
Steam_SetMinidumpSteamID: Caching Steam ID: 76561200720604776 [API loaded no]
003a:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 0 ()
Serial number of failed request: 327
Current serial number in output stream: 327
Система: Linux Mint 20.2 Uma
DE: MATE 1.24.0
Вывод "inxi -Fxz"
Kernel: 5.4.0-74-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: MATE 1.24.0 Distro: Linux Mint 20.2 Uma base: Ubuntu 20.04 focal
Type: Laptop System: LENOVO product: 80G0 v: Lenovo G50-30
serial: <filter>
Mobo: LENOVO model: Lancer 5A6 v: 31900058WIN serial: <filter>
UEFI: LENOVO v: A7CN47WW date: 04/16/2015
ID-1: BAT0 charge: 10.5 Wh condition: 23.9/28.5 Wh (84%) model: Lenovo
status: Discharging
Topology: Dual Core model: Intel Celeron N2840 bits: 64 type: MCP
arch: Silvermont rev: 8 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8666
Speed: 2583 MHz min/max: 500/2582 MHz Core speeds (MHz): 1: 2583 2: 2583
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 21.0.3
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.4.0-74-generic
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel port: 2000
bus ID: 02:00.0
vendor: Lenovo driver: r8169 v: kernel port: 1000 bus ID: 03:00.0
Local Storage: total: 465.76 GiB used: 17.70 GiB (3.8%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
ID-1: / size: 456.96 GiB used: 17.69 GiB (3.9%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 55.0 C mobo: N/A
Processes: 174 Uptime: 14h 22m Memory: 3.73 GiB used: 1.78 GiB (47.9%)
inxi: 3.0.38
(простите, если вопрос тупой, я новенький в линуксе)
Решение MrTowelie » 15 авг 2021, 22:47
Не особо умею обращаться с командой export, но как я понимаю она работает только на текущий сеанс терминала. Если у вас весь запуск в одном терминале, тогда просто ввести export MESA_GL_VERSION_OVERRIDE=4.5 и запустить командой игру.
Если запуск через steam идёт, тогда в параметры запуска игры советуют писать так MESA_GL_VERSION_OVERRIDE=4.5COMPAT %command%.
Для конкретного .exe не из steam пишут, что надо прописывать так env MESA_GL_VERSION_OVERRIDE=4.5COMPAT wine /путь/до/program.exe.
Точно не знаю, сам с такими проблемами не встречаюсь, может кто заглянет в тему и подправит меня. Но все недавние темы в интернете сводят решения к такому виду.
MrTowelie
Решено: 8
Благодарил (а): 18 раз
15 авг 2021, 16:44
Ну в интернете пишут, что это возникло с каким-то из обновлением у людей, правда не понятно обновлением драйверов или wine, или vulkan. Как вариант предлагают использовать команду export MESA_GL_VERSION_OVERRIDE=4.5 перед запуском игры.
Ну или откатить драйвера и wine до прошлых версий. Не знаю, когда это пофиксят. У меня такого на версиях постарше нету.
Sanchez
15 авг 2021, 22:19
MrTowelie писал(а):
15 авг 2021, 16:44
Только как именно это использовать?
MrTowelie
Решено: 8
15 авг 2021, 22:47
Вернуться в «Wine»
