Зависает LM 20.1 x64, cinnamon 4.8.6
Levgenix
08 июл 2021, 16:46
Зависы происходят всегда после простоя, видимо, когда уходит в сон. Может нормально несколько дней проработать.
При нажатии на клавиатуре включается намлок и все, далее никаких реакций, только кнопка питания.
evgeny@evgeny-desktop:~$ inxi -Fxz
System:    Kernel: 5.4.0-42-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 4.8.6
           Distro: Linux Mint 20.1 Ulyssa base: Ubuntu 20.04 focal
Machine:   Type: Desktop Mobo: ASRock model: B450M-HDV serial: <filter> UEFI: American Megatrends v: P4.40 date: 03/24/2021
CPU:       Topology: 8-Core model: AMD Ryzen 7 1800X bits: 64 type: MT MCP arch: Zen rev: 1 L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 115203
           Speed: 2007 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 2007 2: 2013 3: 1990 4: 2051 5: 1971 6: 1979 7: 1896
           8: 2219 9: 1983 10: 1996 11: 1945 12: 2020 13: 1936 14: 1978 15: 2009 16: 2024
Graphics:  Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] vendor: Sapphire Limited
           driver: amdgpu v: kernel bus ID: 09:00.0
           Display: x11 server: X.Org 1.20.9 driver: amdgpu,ati unloaded: fbdev,modesetting,vesa
           resolution: 2560x1440~60Hz, 1920x1080~60Hz, 1680x1050~60Hz
           OpenGL: renderer: Radeon RX 560 Series (POLARIS11 DRM 3.35.0 5.4.0-42-generic LLVM 11.0.0) v: 4.6 Mesa 20.2.6
Audio:     Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] vendor: Sapphire Limited
           driver: snd_hda_intel v: kernel bus ID: 09:00.1
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
           bus ID: 0b:00.3
           Device-3: Sunplus Innovation Canyon CNS-CWC5 Webcam type: USB driver: snd-usb-audio,uvcvideo bus ID: 3-2:2
           Sound Server: ALSA v: k5.4.0-42-generic
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169 v: kernel port: f000
           bus ID: 08:00.0
           IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           IF-ID-1: br-4312ac7b70c9 state: down mac: <filter>
           IF-ID-2: br-efa2bd5d161c state: down mac: <filter>
           IF-ID-3: docker0 state: down mac: <filter>
Drives:    Local Storage: total: 931.52 GiB used: 87.93 GiB (9.4%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB
           ID-2: /dev/sda vendor: Western Digital model: WD5000AZLX-00CL5A0 size: 465.76 GiB temp: 41 C
Partition: ID-1: / size: 456.96 GiB used: 87.92 GiB (19.2%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: swap-1 size: 48.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
Sensors:   System Temperatures: cpu: 50.2 C mobo: N/A gpu: amdgpu temp: 54 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 990
Info:      Processes: 430 Uptime: 55m Memory: 31.29 GiB used: 5.96 GiB (19.1%) Init: systemd runlevel: 5 Compilers: gcc: 9.3.0
           Shell: bash v: 5.0.17 inxi: 3.0.38
Вижу, что есть проблемы Hardware for Linux
Levgenix
08 июл 2021, 17:07
Очень похоже,
попробую ждать 2-3 мин как советуют - может отвиснет
Благодарил (а): 1737 раз
08 июл 2021, 17:13
ядро б обновить... всё таки рязань 7
ilikethat
Решено: 10
Благодарил (а): 130 раз
08 июл 2021, 17:27
WWolf, поддержу, у меня ядро 5.8 и тоже Ryzen 2700x.
Levgenix
08 июл 2021, 17:28
Из 5.4 последнне ставил, и 5.11 было, все одно.. Попробую 5.8, спс
