Не работает WiFi на LMDE 4
DrKolbasa
Благодарил (а): 2 раза
07 май 2021, 12:57
Я поставил LMDE на Thinkpad T400, но по неизвестной причине WiFi отказывается работать.
В самом ноутбуке стоит wifi-карточка Qualcomm Athernos AR242x.
Что делать?
07 май 2021, 13:17
DrKolbasa писал(а):
07 май 2021, 12:57
Что делать?
покажи вывод
lspci -knn | grep -A3 "Net"
DrKolbasa
07 май 2021, 13:34
07 май 2021, 13:17
  Host: thinkpad Kernel: 4.19.0-16-amd64 x86_64 bits: 64 compiler: gcc
  v: 8.3.0 Desktop: Cinnamon 4.8.6 Distro: LMDE 4 Debbie
  base: Debian 10.2 buster
  Type: Laptop System: LENOVO product: 6474ES7 v: ThinkPad T400
  serial: <filter>
  Mobo: LENOVO model: 6474ES7 serial: <filter> BIOS: LENOVO
  v: 7UET94WW (3.24 ) date: 10/17/2012
  ID-1: BAT0 charge: 6.0 Wh condition: 6.0/84.2 Wh (7%) model: SANYO 42T4644
  status: Unknown
  Topology: Dual Core model: Intel Core2 Duo P8600 bits: 64 type: MCP
  arch: Penryn rev: A L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 9576
  Speed: 798 MHz min/max: 800/2401 MHz Core speeds (MHz): 1: 798 2: 798
  Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Lenovo
  Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
  resolution: 1440x900~60Hz
  OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express v: 2.1 Mesa 18.3.6
  Device-1: Intel 82801I HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k4.19.0-16-amd64
  Device-1: Intel 82567LM Gigabit Network vendor: Lenovo driver: e1000e
  v: 3.2.6-k port: 1840 bus ID: 00:19.0
  IF: enp0s25 state: down mac: <filter>
  Device-2: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter
  vendor: AMBIT Microsystem AR5BXB63 802.11bg NIC driver: ath5k v: kernel
  port: 1c60 bus ID: 02:00.0
  IF: wlp2s0 state: down mac: <filter>
  Device-3: Intel PRO/Wireless 5100 AGN [Shiloh] Network driver: iwlwifi
  v: kernel port: 1c60 bus ID: 03:00.0
  IF-ID-1: enp0s29f7u2 state: unknown speed: N/A duplex: N/A mac: <filter>
  Local Storage: total: 298.09 GiB used: 6.49 GiB (2.2%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABD032 size: 298.09 GiB
  ID-1: / size: 288.56 GiB used: 6.29 GiB (2.2%) fs: ext4 dev: /dev/sda2
  ID-2: swap-1 size: 3.91 GiB used: 204.2 MiB (5.1%) fs: swap dev: /dev/sda1
  System Temperatures: cpu: 51.0 C mobo: 50.0 C
  Fan Speeds (RPM): cpu: 2970
  Processes: 186 Uptime: 48m Memory: 3.75 GiB used: 1.45 GiB (38.6%)
  Init: systemd runlevel: 5 Compilers: gcc: 8.3.0 Shell: bash v: 5.0.3
  inxi: 3.0.32
00:19.0 Ethernet controller [0200]: Intel Corporation 82567LM Gigabit Network Connection [8086:10f5] (rev 03)
	Subsystem: Lenovo 82567LM Gigabit Network Connection (ThinkPad T400) [17aa:20ee]
	Kernel driver in use: e1000e
	Kernel modules: e1000e
00:1a.0 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 [8086:2937] (rev 03)
02:00.0 Ethernet controller [0200]: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express) [168c:001c] (rev 01)
	Subsystem: AMBIT Microsystem Corp. AR5BXB63 802.11bg NIC [1468:0428]
	Kernel driver in use: ath5k
	Kernel modules: ath5k
03:00.0 Network controller [0280]: Intel Corporation PRO/Wireless 5100 AGN [Shiloh] Network Connection [8086:4237]
	Subsystem: Intel Corporation WiFi Link 5100 AGN [8086:1211]
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
warning
Решено: 7
Благодарил (а): 161 раз
07 май 2021, 13:41
DrKolbasa писал(а):
07 май 2021, 13:34
state: down
Надо поднять интерфейс
hw-probe: тыц!
DrKolbasa
07 май 2021, 13:46
warning писал(а):
07 май 2021, 13:41
DrKolbasa писал(а):
07 май 2021, 13:34
state: down
Каким образом?
07 май 2021, 14:02
DrKolbasa, покажи вывод
rfkill list
DrKolbasa
07 май 2021, 14:08
07 май 2021, 14:02
rfkill list
0: tpacpi_bluetooth_sw: Bluetooth
	Soft blocked: yes
	Hard blocked: no
1: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
2: phy1: Wireless LAN
	Soft blocked: no
	Hard blocked: yes
Уже вижу проблему, но как её решить?
07 май 2021, 16:42
DrKolbasa писал(а):
07 май 2021, 14:08
Hard blocked: yes
Это аппаратный выключатель, само железо выключено. Т.е. или переключатель на корпусе, или особая комбинация клавиш с Fn, или иногда - опция в BIOS/EFI. Но общее то, что это никак не контролируется из системы.
DrKolbasa
07 май 2021, 17:46
07 май 2021, 16:42
DrKolbasa писал(а):
07 май 2021, 14:08
Hard blocked: yes
Хорошо, спасибо за ответ. Я пока полезу в BIOS, дабы это исправить...
Вернуться в «LMDE»
