LM 20.1 Cinnamon Странные кавычки после установки шрифтов
andakrus
Благодарил (а): 4 раза
29 апр 2021, 11:05
LM 20.1 x64 Cinnamon
andakrus@andakrus-desktop ~> inxi -Fxz
Kernel: 5.4.0-72-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.8.6 Distro: Linux Mint 20.1 Ulyssa
base: Ubuntu 20.04 focal
Type: Desktop Mobo: ASRock model: Z68 Pro3 Gen3 serial: <filter>
UEFI: American Megatrends v: P2.30 date: 06/29/2012
Topology: Quad Core model: Intel Core i5-2500K bits: 64 type: MCP
arch: Sandy Bridge rev: 7 L2 cache: 6144 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 26340
Speed: 1611 MHz min/max: 1600/5900 MHz Core speeds (MHz): 1: 1643 2: 1598
3: 1596 4: 1599
vendor: ASRock driver: i915 v: kernel bus ID: 00:02.0
Device-2: AMD Cape Verde XT [Radeon HD 7770/8760 / R7 250X]
vendor: XFX Pine driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: ati,modesetting,radeon
unloaded: fbdev,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: AMD VERDE (DRM 2.50.0 5.4.0-72-generic LLVM 11.0.0)
v: 4.5 Mesa 20.2.6 direct render: Yes
vendor: ASRock driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.4.0-72-generic
vendor: ASRock driver: r8169 v: kernel port: d000 bus ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-2: TP-Link TL-WN822N Version 4 RTL8192EU type: USB driver: rtl8xxxu
bus ID: 2-1.2:5
IF: wlxd03745151b55 state: up mac: <filter>
Local Storage: total: 1.14 TiB used: 934.04 GiB (80.3%)
ID-1: /dev/sda vendor: Intel model: SSDSC2CW120A3 size: 111.79 GiB
ID-2: /dev/sdb vendor: Apacer model: AS350 128GB size: 119.24 GiB
ID-3: /dev/sdc vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB
ID-1: / size: 93.29 GiB used: 10.69 GiB (11.5%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 116.87 GiB used: 72.44 GiB (62.0%) fs: ext4
dev: /dev/sdb1
ID-3: swap-1 size: 16.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
System Temperatures: cpu: 41.0 C mobo: N/A gpu: radeon temp: 47 C
Processes: 229 Uptime: 49m Memory: 15.53 GiB used: 2.78 GiB (17.9%)
Init: systemd runlevel: 5 Compilers: gcc: 9.3.0 Shell: fish v: 3.1.0
inxi: 3.0.38
Установил шрифты MS TrueTipe и ClearTipe, по руководству с сайта Установка шрифтов в Linux | Losst.
sudo apt install ttf-mscorefonts-installer
и
wget -qO- http://plasmasturm.org/code/vistafonts-installer/vistafonts-installer | bash
Не могу привыкнуть к шрифтам Linux. Дискомфорт ужасный был. Сейчас всё отлично, кроме:
Кавычки на английской раскладке какие то... странные. Отображаются не корректно и при нажатии на клавишу ¨ они не сразу вводятся, а с большой задержкой.
На русской раскладке всё в порядке. Вводятся быстро и корректно отображаются.
Скриншот:
388
Подбешивает переключаться с английской раскладки на русскую, чтобы кавычки поставить.
Печатаю быстро и кавычки просто не успевают напечататься (на английской раскладке) из-за этой самой задержки ввода.
Сама клавиша работает нормально. :smile: Большая буква Э, на русской раскладке, печатается без задержек.
Как ситуацию исправить?
С Linux Mint "дружу" недавно.
Снёс к фигам W10, поставил на оба SSD Linux Mint и "в ус не дую", почти. :thumbs:
П.С. Пришлось из-за работы на W11 вернуться. Сейчас заново с LMC (Edge ISO) 21.3 знакомлюсь. :-D
Благодарил (а): 794 раза
29 апр 2021, 11:30
andakrus писал(а):
29 апр 2021, 11:05
Не использовать этот шрифт
demonlibra
Благодарил (а): 29 раз
29 апр 2021, 17:39
andakrus писал(а):
29 апр 2021, 11:05
Это пройдёт. Трудно избавиться от вредной привычки, навязываемой годами.
Контекстное меню Nemo
andakrus
29 апр 2021, 18:43
29 апр 2021, 11:30
И компьютер тоже не использовать? :tema:
andakrus
29 апр 2021, 18:55
demonlibra писал(а):
29 апр 2021, 17:39
Это пройдёт.
За семь лет не прошло, а тут вдруг БАХ! и пройдёт? :-D
Я Ubuntu давным давно держал в качестве второй ОС, для редкого использования. Неудобства (шрифт, отсутствие "плюшек" для "Microsoft Sculpt Ergonomic Desktop Keyboard & Mouse" и ещё по мелочи...) перевешивали недовольство от использования Windows. Сейчас недовольство от "самостоятельности" Win10 перевесило неудобства Linux. Поэтому винду снёс и Linux Mint использую в качестве основной.
Хочешь - не хочешь, а приходится разбираться, ковыряться и "рукодельничать". Не люблю, когда в чём то не могу разобраться.
29 апр 2021, 17:39
А кто сказал, что это вредная привычка? Я своё зрение берегу, не более.
Поэтому :tema: и подскажи чего-нибудь дельное. :write: :hshake:
demonlibra
29 апр 2021, 18:59
andakrus писал(а):
29 апр 2021, 18:55
Найдите отдельно шрифт, без которого зрение портится.
andakrus
29 апр 2021, 19:02
29 апр 2021, 18:59
Найдите отдельно шрифт, без которого "зрение портится".
Да я ведь просил совет не про то, как в жизни устроиться поудобней. :bye:
Я спросил, что мне С КАВЫЧКАМИ СДЕЛАТЬ и с ЗАДЕРЖКОЙ ВВОДА?
demonlibra
29 апр 2021, 19:07
Так я и предложил вариант.
Удалите пакеты шрифтов MS, найдите необходимый шрифт отдельно и установите.
Будет ли та же проблема?
Если проблема останется, напишите ссылку на установленный проблемный шрифт.
29 апр 2021, 19:16
andakrus писал(а):
29 апр 2021, 18:43
Можете не использовать. Проблема - шрифт. Решение - не использовать шрифт. Если для вас решением является "не использовать компьютер" - ну флаг вам в руки.
andakrus
29 апр 2021, 19:19
29 апр 2021, 19:16
Проблема - шрифт.
Шрифт - НЕ ПРОБЛЕМА. ))
Проблема - кривые кавычки и задержка ввода.
А шрифт мне очень нравится.
29 апр 2021, 19:22
andakrus писал(а):
29 апр 2021, 19:19
Шрифт - НЕ ПРОБЛЕМА
В том то и дело что вся проблема в шрифте. Ну не верите - ищите проблему дальше
demonlibra
29 апр 2021, 19:23
andakrus писал(а):
29 апр 2021, 19:19
Да как же называется этот замечательный шрифт?
Я уже чувствую, что мне без него плохо )
andakrus
29 апр 2021, 19:24
29 апр 2021, 19:07
Я же их "оптом" ставил. Честно говоря, я даже не знаю, как называется этот шрифт, которым я в данный момент пользуюсь.
Скриншот:
389
andakrus
29 апр 2021, 19:26
demonlibra
29 апр 2021, 19:29
TrueTipe и ClearTipe это не название, а тип шрифта.
andakrus писал(а):
29 апр 2021, 19:24
Где конкретно пользуетесь? В какой программе?
29 апр 2021, 19:29
andakrus писал(а):
29 апр 2021, 19:26
Только TrueType и ClearType. это типы/виды шрифтов.
ClearType
TrueType
andakrus
29 апр 2021, 19:31
29 апр 2021, 19:29
Я даже представления не имею, что можно в отдельных программах пользоваться отдельными шрифтами.
Я просто установил пакеты, перезагрузил ПК и шрифты во всех программах поменялись.
По крайней мере в тех, которыми я пользуюсь.
andakrus
29 апр 2021, 19:33
29 апр 2021, 19:29
Хорошо. Я и не спорю с этим.
А делать то что?
Только не предлагайте снова шрифты удалить.
Тем более, я и не знаю, как это сделать. :-D
demonlibra
29 апр 2021, 19:33
Что у Вас тут: Start -> Выбор шрифтов
andakrus
29 апр 2021, 19:40
Как ни странно...
390
Но ведь они стали другими. :hoho:
