Не запустить КС 1.6 и Half-Life 1 через Steam.
Нативные и в Wine - настройка, обсуждение, решение проблем
Nicket7
Сообщение Nicket7 » 28 апр 2021, 20:07
2-4)
Kernel: 5.4.0-72-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.8.6 Distro: Linux Mint 20.1 Ulyssa
base: Ubuntu 20.04 focal
Type: Desktop Mobo: ASUSTeK model: M5A97 R2.0 v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 0906 date: 09/17/2012
Topology: Quad Core model: AMD Phenom II X4 965 bits: 64 type: MCP
arch: K10 rev: 3 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 27290
Speed: 800 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800
Device-1: AMD Pitcairn PRO [Radeon HD 7850 / R7 265 / R9 270 1024SP]
vendor: PC Partner Limited driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: ati,radeon
OpenGL: renderer: AMD PITCAIRN (DRM 2.50.0 5.4.0-72-generic LLVM 11.0.0)
v: 4.5 Mesa 20.2.6 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:14.2
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-3: Logitech HD Webcam C615 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-2:2
Sound Server: ALSA v: k5.4.0-72-generic
vendor: ASUSTeK P8 series driver: r8169 v: kernel port: d000
bus ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.25 TiB used: 81.73 GiB (6.4%)
ID-1: /dev/sda vendor: Kingston model: SV300S37A120G size: 111.79 GiB
ID-2: /dev/sdb vendor: Ricoh model: R5SL256G size: 238.47 GiB
ID-3: /dev/sdc vendor: Hitachi model: HDS721010CLA330 size: 931.51 GiB
ID-1: / size: 233.24 GiB used: 81.72 GiB (35.0%) fs: ext4 dev: /dev/sdb2
System Temperatures: cpu: 32.4 C mobo: N/A gpu: radeon temp: 34 C
Processes: 216 Uptime: 25m Memory: 7.70 GiB used: 2.68 GiB (34.8%)
inxi: 3.0.38
5) Проблема. Не запустить КС 1.6 и Half-Life 1 через Steam.
При нажатии кнопки "Играть" или нажатии на ярлык на рабочем столе высвечивается надпись "подготовка к запуску..." , и всё. Дальше игра просто не запускается.
Хочу заметить, что CS:Sourse и Half-Life 2 запускаются без проблем как по ярлыку, так и по кнопке "Играть". Предположу, что это как-то связано с Видеокартой или OpenGL, поскольку CS:Sourse и Half-Life 2 имеют один и тот же движок, насколько я понимаю. Поэтому они обе и запускаются, а вот первые части (1.6 и 1-я халфа) не хотят запускаться.
Ещё любопытно - при запуске Half-Life 2 перед выводом картинки на полный экрал высвечивается сначала маленькое окошко игры и назывется оно Half-Life2 - OpenGL. (Подробности на фото). То же происходит и с Sourse.
Прошу помочь. Спасибо.
ВоЛчара
Сообщение ВоЛчара » 10 июн 2021, 08:39
Я хз. Подскажите пж, я пиратил всегда 1.6 и вместе с ней ишел халф лайф ,что это за тема ? Я всегда думал, что это ещё одна игрушка
Много инфы здесь: https://davydenko.com.ua/
FreeStyler
Решено: 7
Благодарил (а): 772 раза
Сообщение FreeStyler » 10 июн 2021, 09:52
ВоЛчара, они нативные? Через протон пробовал?
deadmau5 - Harmonic Mix
ВоЛчара
Сообщение ВоЛчара » 14 июн 2021, 11:18
Нет
Junnait
Сообщение Junnait » 12 апр 2022, 08:42
Решил проблему? Такая же проблема. Накатил кучу библиотек, запустить кс или халфу так и не удалось.
Если запускаю через терминал hl.sh, то выдает
Error:libopenal.so.1: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
Could not load hw.so.
При запуске hl_linux
Error:libsteam_api.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
Файл hw.so в директории есть.
Вернуться в «Игры»
