Нотный редактор под Lunux. Sibelius.
Nicket7
10 апр 2021, 23:44
Доброго вечера всем! :smile: :smile: :smile:
2-4)System:
Kernel: 5.4.0-70-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.8.6 Distro: Linux Mint 20.1 Ulyssa
base: Ubuntu 20.04 focal
Type: Desktop Mobo: ASUSTeK model: M5A97 R2.0 v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 0906 date: 09/17/2012
Topology: Quad Core model: AMD Phenom II X4 965 bits: 64 type: MCP
arch: K10 rev: 3 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 27293
Speed: 2700 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 2700 2: 3400
3: 2700 4: 800
Device-1: AMD Pitcairn PRO [Radeon HD 7850 / R7 265 / R9 270 1024SP]
vendor: PC Partner Limited driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: ati,radeon
OpenGL: renderer: AMD PITCAIRN (DRM 2.50.0 5.4.0-70-generic LLVM 11.0.0)
v: 4.5 Mesa 20.2.6 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:14.2
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-3: Logitech HD Webcam C615 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-2:2
Sound Server: ALSA v: k5.4.0-70-generic
vendor: ASUSTeK P8 series driver: r8169 v: kernel port: d000
bus ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.25 TiB used: 697.84 GiB (54.4%)
ID-1: /dev/sda vendor: Kingston model: SV300S37A120G size: 111.79 GiB
ID-2: /dev/sdb vendor: Ricoh model: R5SL256G size: 238.47 GiB
ID-3: /dev/sdc vendor: Hitachi model: HDS721010CLA330 size: 931.51 GiB
ID-1: / size: 233.24 GiB used: 69.00 GiB (29.6%) fs: ext4 dev: /dev/sdb2
System Temperatures: cpu: 31.2 C mobo: N/A gpu: radeon temp: 32 C
Processes: 205 Uptime: 3h 39m Memory: 7.70 GiB used: 2.52 GiB (32.7%)
inxi: 3.0.38
Собственно вопрос о нотном редакторе. Если подходящий аналог нотного редактора Sibelius под Linux. Сам Sibelus платный - понимаю, Но где найти подходящий, читающий файлы .sib? Буду очень признателен! Спасибо! :vic: :vic: :vic:
11 апр 2021, 00:05
MuseScore. Правда .sib он не читает кажется, но в остальном - нормальный нотный редактор, можно как нотами писать так и треки, и сопряжение с синтезаторами по MIDI есть. Сам пользовался - мне за глаза хватало.
Есть в репах большинства дистрибутивов. Так то он здесь живет: https://musescore.org/ru
Nicket7
28 апр 2021, 23:11
11 апр 2021, 00:05
Ох, спасибо за то, что попытались мне помочь. Вряд ли, конечно, это поможет, посколько песен 30 я уже написал в Sib и переписывать их в другой формат и потратить много времени на это - не мой вариант, к сожалению. Эту куча работы на смарку. Но я проверю на чтение sib на всякий случай.
Спасибо.
Вернуться в «Мультимедиа»
