Не отображается температура CPU (Процессора)
Talekh
31 мар 2021, 18:10
Моя система:
System:    Kernel: 5.4.0-70-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 4.8.6
           wm: muffin dm: LightDM Distro: Linux Mint 20.1 Ulyssa base: Ubuntu 20.04 focal
Machine:   Type: Desktop Mobo: ASUSTeK model: A88XM-A v: Rev X.0x serial: <filter>
           UEFI: American Megatrends v: 1801 date: 08/25/2014
CPU:       Topology: Quad Core model: AMD A10-6700 APU with Radeon HD Graphics bits: 64 type: MCP
           arch: Piledriver rev: 1 L2 cache: 2048 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 29524
           Speed: 2478 MHz min/max: 1800/3700 MHz Core speeds (MHz): 1: 2397 2: 2401 3: 2407
           4: 2443
Graphics:  Device-1: AMD Tobago PRO [Radeon R7 360 / R9 360 OEM] vendor: ASUSTeK driver: radeon
           v: kernel bus ID: 01:00.0 chip ID: 1002:665f
           Display: x11 server: X.Org 1.20.9 driver: ati,radeon unloaded: fbdev,modesetting,vesa
           resolution: 1440x900~60Hz
           OpenGL: renderer: AMD BONAIRE (DRM 2.50.0 5.4.0-70-generic LLVM 11.0.1)
           v: 4.5 Mesa 21.0.1 - kisak-mesa PPA direct render: Yes
Audio:     Device-1: AMD FCH Azalia vendor: ASUSTeK AM1I-A driver: snd_hda_intel v: kernel
           bus ID: 00:14.2 chip ID: 1022:780d
           Device-2: AMD Tobago HDMI Audio [Radeon R7 360 / R9 360 OEM]
           vendor: ASUSTeK R7260X-DC2OC-2GD5 driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 1002:aac0
           Sound Server: ALSA v: k5.4.0-70-generic
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK H81M-C
           driver: r8169 v: kernel port: d000 bus ID: 04:00.0 chip ID: 10ec:8168
Drives:    Local Storage: total: 931.51 GiB used: 47.13 GiB (5.1%)
           ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-21M2NA0 size: 931.51 GiB
           speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 468.35 GiB used: 12.48 GiB (2.7%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 446.45 GiB used: 34.64 GiB (7.8%) fs: ext4 dev: /dev/sda3
Sensors:   System Temperatures: cpu: 20.9 C mobo: N/A gpu: radeon temp: 42 C
Установил я себе Conky и захотел чтобы он отображал температуру CPU, но к не счастью он показывает 0 градусов, то есть не работает.
Я пошёл на форумы и узнал об утилите im_sensors при её настройке меня смутило это:
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no):
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595...                       No
VIA VT82C686 Integrated Sensors...                          No
VIA VT8231 Integrated Sensors...                            No
AMD K8 thermal sensors...                                   No
AMD Family 10h thermal sensors...                           No
AMD Family 11h thermal sensors...                           No
AMD Family 12h and 14h thermal sensors...                   No
AMD Family 15h thermal sensors...                           Success!
    (driver `k10temp')
AMD Family 16h thermal sensors...                           No
AMD Family 17h thermal sensors...                           No
AMD Family 15h power sensors...                             No
AMD Family 16h power sensors...                             No
Hygon Family 18h thermal sensors...                         No
Intel digital thermal sensor...                             No
Intel AMB FB-DIMM thermal sensor...                         No
Intel 5500/5520/X58 thermal sensor...                       No
VIA C7 thermal sensor...                                    No
VIA Nano thermal sensor...                                  No
И когда я через терминал ввожу команду "sensors" вместо нормального ответа я получаю это:
radeon-pci-0100
Adapter: PCI adapter
temp1:        +43.0°C  (crit = +120.0°C, hyst = +90.0°C)
k10temp-pci-00c3
temp1:         +7.5°C  (high = +70.0°C)
                       (crit = +70.0°C, hyst = +69.0°C)
В то время как на сайте с инструкцией намного больше информации.
Пожалуйста прошу помочь мне с моей проблемой!
31 мар 2021, 18:16
Talekh писал(а):
31 мар 2021, 18:10
меня смутило это:
что именно? что у тебя не все известные утилите сенсоры стоят? ну паяльник в руки и впаивай всё подряд!
Talekh писал(а):
31 мар 2021, 18:10
чем ответ то ненормален? датчики видяхи и мат платы ответили, всё нормально
Последний раз редактировалось пользователем 1 WWolf; всего редактировалось раз: 31
31 мар 2021, 18:18
 ! Сообщение из: rogoznik
Talekh, изучить тему Панель форматирования текста в темах/ответах чтоб за тебя модераторы не занимались оформлением ТВОИХ сообщений
Talekh писал(а):
31 мар 2021, 18:10
А чем это не нормальный ответ?
Talekh писал(а):
31 мар 2021, 18:10
k10temp-pci-00c3
Это и есть температура процессора. А вот то что там значение странное, это уже другой вопрос.
Тут или проблема с датчиком или что-то софтовое.
Попробуй ядро другое(посвежее) - 5.8 к примеру. Может там поправили
31 мар 2021, 18:20
31 мар 2021, 18:18
ядро не причём... тут что-то утилита тупит, потому что в inxi вывод нормальный
31 мар 2021, 18:22
31 мар 2021, 18:20
Точно, не заметил :hoho:
31 мар 2021, 18:25
Тогда самый простой вариант распарсить из inxi -s в коньки температуру
31 мар 2021, 18:25
rogoznik, тут явно что-то в драйвере k10temp не правильно написано для довольно нового проца
Talekh писал(а):
31 мар 2021, 18:10
(driver `k10temp')
31 мар 2021, 18:28
31 мар 2021, 18:25
Процу лет 8
31 мар 2021, 18:29
31 мар 2021, 18:25
распарсить
Например так: inxi -s | head -n1 | awk '{print $5}'
отдаст цифру с градусами
Talekh
31 мар 2021, 18:39
31 мар 2021, 18:25
В таком случае показана температура 4.8 градусов что тоже неправда.
31 мар 2021, 18:40
Talekh писал(а):
31 мар 2021, 18:10
Ясно. Ну там двадцать в первом посте ловили, значит предположение оказалось не верным)
31 мар 2021, 23:01
Есть подозрение что inxi тоже врет как сивый мерин. Т.к. 20 градусов на работающем камне даже в idle будет лишь тогда, когда в помещении около 10-12.
По хорошему, для такого железа sensors должны показывать:
- Температуру каждого ядра.
- Температуру процессора (собственный общий датчик)
- Температуру процессора по датчику материнки.
- Температуру чипсета.
- Обороты каждого кулера.
Сейчас же показывает лишь общее по процессору, причем неправильно. Итого - модули ядра сенсоров неправильно работают, скорее всего. К сожалению, по AMD ничего большего сказать не могу. У меня живем было только еще более старое поколение - там сразу заводилось, без проблем. Гуглить надо...
31 мар 2021, 23:13
slant, вообще вероятно оба варианта гоняют одну цифру, т.к. inxi их по-моему и берет из lm-sensors. И не покажет в его отсутствие.
Так что затея была провальной изначально :smile:
31 мар 2021, 23:18
31 мар 2021, 23:13
Берет оттуда, но интерпретирует по своему, как и psensors и просто sensors. Но начинать надо с того, чтобы датчики нормально увиделись в выводе sensors, да... Нормально - хотя бы боле-менее все.
31 мар 2021, 23:21
31 мар 2021, 23:01
у меня на буке на и7 и половины из этого списка не кажет :-D пхах, так ещё и температуру видяхи не даёт без дровины nvidia :blink2:
на рабочем ПК на АМД так ваще только температура проца и видяхи и всё... хотя все кулеры рулятся биосом, но инфы ни о них, ни о чипсете сенсор не даёт совсем
31 мар 2021, 23:44
WWolf, Дык это с учетом 8-ми летнего камня. Вообще - чем свежее железо, тем меньше шанс что сразу заработает/найдет датчики без бубна.
У меня на текущем железе 8-го интеловского поколения, без шаманства видит только температуру (хотя всю - по отдельным ядрам, чипсету, и правильно). Зато вентиляторов вообще не видит. :)
И заставить увидеть - целая история.
sheridan
Решено: 14
Благодарил (а): 900 раз
01 апр 2021, 08:58
По датчикам могу сказать, что нет нормальной поддержи в ядре тех микросхем которые установлены на материнских платах,
если вы зайдете в .config ядра (вкладка device drivers > hardware monitoring support), то вы увидите скудный перечень микросхем среди которых большая вероятность вашей нет. С другой стороны переходим в Win10 запускаем Everest и что мы видим? Даже материнские платы десятилетней давности нормально распознают все параметры сенсоров в Win10, следовательно нужно кому то этим заниматься и стоит это больших затрат и лицензий которые свободным сообществом не всегда хочется покупать, вот и имеем то что имеем.
