По IP адресу пингует, по имени нет
Doctor_Che
24 мар 2021, 17:30
LinuxMint 20.1 x64 Cinnamon
Перестал работать пинг по имени хоста, при этом по IP пингует. Если сделать раздачу WiFi через телефон и подключиться к нему, то всё работает нормально.
$ nslookup ya.ru
;; connection timed out; no servers could be reached
$ nslookup ya.ru 8.8.8.8
Server: 8.8.8.8
Address: 8.8.8.8#53
Non-authoritative answer:
Address: 87.250.250.242
Address: 2a02:6b8::2:242
/etc/resolv.conf
# This file is managed by man:systemd-resolved(8). Do not edit.
# This is a dynamic resolv.conf file for connecting local clients to the
# internal DNS stub resolver of systemd-resolved. This file lists all
# configured search domains.
# Run "resolvectl status" to see details about the uplink DNS servers
# currently in use.
# Third party programs must not access this file directly, but only through the
# symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a different way,
# replace this symlink by a static file or a different symlink.
# See man:systemd-resolved.service(8) for details about the supported modes of
# operation for /etc/resolv.conf.
nameserver 127.0.0.53
options edns0 trust-ad
search --
System: Kernel: 5.8.0-48-generic x86_64 bits: 64 compiler: N/A Desktop: Cinnamon 4.8.6
Distro: Linux Mint 20.1 Ulyssa base: Ubuntu 20.04 focal
Machine: Type: Laptop System: ASUSTeK product: TP500LN v: 1.0 serial: <filter>
Mobo: ASUSTeK model: TP500LN v: 1.0 serial: <filter> UEFI: American Megatrends v: TP500LN.203
date: 06/11/2014
Battery: ID-1: BAT0 charge: 24.2 Wh condition: 24.2/48.3 Wh (50%) model: ASUSTeK TP50042 status: Not charging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse charge: 5% (should be ignored)
status: Discharging
CPU: Topology: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell rev: 1
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19154
Speed: 936 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 898 2: 898 3: 898 4: 898
Graphics: Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GM108M [GeForce 840M] vendor: ASUSTeK driver: nvidia v: 460.39 bus ID: 04:00.0
Display: x11 server: X.Org 1.20.9 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce 840M/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39 direct render: Yes
Audio: Device-1: Intel Haswell-ULT HD Audio driver: snd_hda_intel v: kernel bus ID: 00:03.0
Device-2: Intel 8 Series HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.8.0-48-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: e000
bus ID: 02:00.1
IF: enp2s0f1 state: down mac: <filter>
Device-2: MEDIATEK MT7630e 802.11bgn Wireless Network Adapter vendor: Foxconn driver: mt76x0e
v: kernel port: e000 bus ID: 03:00.0
IF: wlp3s0f0 state: up mac: <filter>
Drives: Local Storage: total: 465.76 GiB used: 387.66 GiB (83.2%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
Partition: ID-1: / size: 48.83 GiB used: 26.24 GiB (53.7%) fs: btrfs dev: /dev/sda2
ID-2: /home size: 402.72 GiB used: 361.41 GiB (89.7%) fs: ext4 dev: /dev/sda3
Sensors: System Temperatures: cpu: 60.0 C mobo: N/A gpu: nvidia temp: 59 C
Fan Speeds (RPM): cpu: 3300
Info: Processes: 336 Uptime: 5h 52m Memory: 11.59 GiB used: 6.71 GiB (57.9%) Init: systemd runlevel: 5
Compilers: gcc: 9.3.0 Shell: bash v: 5.0.17 inxi: 3.0.38
Решение slant » 24 мар 2021, 18:10
Doctor_Che, Быстрый костыль: зайти в свойства вашего соединения в network manager, перейти на вкладку свойств IPv4, и вписать 8.8.8.8 в поле "Дополнительные серверы DNS". Можно также переставить режим получения настроек "Автоматический (DHCP)" на "Автоматический (DHCP, только адрес)" в этом случае уже лучше вписать сразу два DNS адреса: 8.8.8.8, 8.8.4.4
24 мар 2021, 18:00
странно как-то...
dja@dja-work:~$ nslookup ya.ru
Server:		127.0.0.53
Address:	127.0.0.53#53
dja@dja-work:~$ nslookup ya.ru 8.8.8.8
dja@dja-work:~$ nslookup 8.8.8.8
8.8.8.8.in-addr.arpa	name = dns.google.
Authoritative answers can be found from:
dja@dja-work:~$
24 мар 2021, 18:10
Doctor_Che
24 мар 2021, 18:23
slant, спасибо, заработало!
24 мар 2021, 20:07
DHCP, наверное, не выдавал адрес кэширующего DNS или он вообще на роутере перешёл в состояние "выключено". Поэтому девайс и был в затруднении: к кому обращаться для распознавания имени.
Doctor_Che
24 мар 2021, 23:24
madesta писал(а):
24 мар 2021, 20:07
Так телефон, подключенный к роутеру, работал нормально. И ноутбук при подключении к телефону, а не к роутеру напрямую, тоже находил хосты без проблем.
24 мар 2021, 23:57
А в свойствах ноутбучного соединения при его подключении к роутеру первичный DNS-сервер какой отображался (или вы не помните)? Пример:
Doctor_Che
25 мар 2021, 00:11
madesta писал(а):
24 мар 2021, 23:57
Не знал, а поэтому и не помню.
Подскажите где это посмотреть можно. Попробую восстановить.
25 мар 2021, 00:35
Правым кликом по значку сетевого соединения. Там несколько пунктов. Насколько я понял, вы уже пользовались одним из них когда вписывали адреса гугловских DNS - изменить соединения. А выше него будет сведения о соединении. Вроде так.
