Linux Mint 20 Сеть пропадает каждые 30 минут
Serg063
18 мар 2021, 15:39
Всем привет. Есть такая проблема , при работе происходят отвалы в сети каждые 30 минут. На Linux Mint 18.04 такой проблемы не было, устройства на Windows работают нормально.
ОС - Linux Mint 20 Cinnamon
Cinnamon version - 4.6.7
Ядро - 5.4.0-65-generic
вот вывод journalctl
Mar 18 11:55:15 test-user NetworkManager[782]: <error> [1616061315.4626] dhcp4 (enp2s0): error -113 dispatching events
Mar 18 11:55:15 test-user NetworkManager[782]: <info> [1616061315.4626] dhcp4 (enp2s0): state changed bound -> fail
Mar 18 11:55:15 test-user NetworkManager[782]: <info> [1616061315.4627] device (enp2s0): DHCPv4: trying to acquire a new lease within 90 seconds
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.4681] device (enp2s0): DHCPv4: grace period expired
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.4682] device (enp2s0): state change: activated -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.4702] manager: NetworkManager state is now DISCONNECTED
Mar 18 11:56:45 test-user NetworkManager[782]: <warn> [1616061405.4739] device (enp2s0): Activation: failed for connection 'Ethernet connection 2'
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.4776] device (enp2s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.4858] dhcp4 (enp2s0): canceled DHCP transaction
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.4860] dhcp4 (enp2s0): state changed fail -> done
Mar 18 11:56:45 test-user dbus-daemon[781]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=782 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.4935] policy: auto-activating connection 'Ethernet connection 2' (42ddc538-3249-4e53-9f97-705698a0f85a)
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.5093] device (enp2s0): Activation: starting connection 'Ethernet connection 2' (42ddc538-3249-4e53-9f97-705698a0f85a)
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.5095] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.5103] manager: NetworkManager state is now CONNECTING
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.5109] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.5158] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.5164] dhcp4 (enp2s0): activation: beginning transaction (timeout in 45 seconds)
Mar 18 11:56:45 test-user NetworkManager[782]: <info> [1616061405.5277] dhcp4 (enp2s0): state changed unknown -> expire
Mar 18 11:56:51 test-user NetworkManager[782]: <info> [1616061411.8815] device (enp2s0): state change: ip-config -> deactivating (reason 'user-requested', sys-iface-state: 'managed')
Mar 18 11:56:51 test-user NetworkManager[782]: <info> [1616061411.8827] manager: NetworkManager state is now DISCONNECTING
Mar 18 11:56:51 test-user NetworkManager[782]: <info> [1616061411.8836] audit: op="device-disconnect" interface="enp2s0" ifindex=2 pid=1405202 uid=1000 result="success"
Mar 18 11:56:51 test-user NetworkManager[782]: <info> [1616061411.8907] device (enp2s0): state change: deactivating -> disconnected (reason 'user-requested', sys-iface-state: 'managed')
Mar 18 11:56:51 test-user NetworkManager[782]: <info> [1616061411.9146] dhcp4 (enp2s0): canceled DHCP transaction
Mar 18 11:56:51 test-user NetworkManager[782]: <info> [1616061411.9146] dhcp4 (enp2s0): state changed expire -> done
Mar 18 11:56:51 test-user NetworkManager[782]: <info> [1616061411.9160] manager: NetworkManager state is now DISCONNECTED
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.0984] device (enp2s0): Activation: starting connection 'Ethernet connection 2' (42ddc538-3249-4e53-9f97-705698a0f85a)
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.0986] audit: op="connection-activate" uuid="42ddc538-3249-4e53-9f97-705698a0f85a" name="Ethernet connection 2" pid=1405202 uid=1000 result="success"
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.0988] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.1011] manager: NetworkManager state is now CONNECTING
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.1020] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.1049] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.1062] dhcp4 (enp2s0): activation: beginning transaction (timeout in 45 seconds)
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.1182] dhcp4 (enp2s0): state changed unknown -> expire
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.7144] device (enp2s0): state change: ip-config -> deactivating (reason 'user-requested', sys-iface-state: 'managed')
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.7151] manager: NetworkManager state is now DISCONNECTING
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.7161] audit: op="device-disconnect" interface="enp2s0" ifindex=2 pid=1405202 uid=1000 result="success"
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.7256] device (enp2s0): state change: deactivating -> disconnected (reason 'user-requested', sys-iface-state: 'managed')
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.7506] dhcp4 (enp2s0): canceled DHCP transaction
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.7506] dhcp4 (enp2s0): state changed expire -> done
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.7527] manager: NetworkManager state is now DISCONNECTED
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9484] device (enp2s0): Activation: starting connection 'Ethernet connection 2' (42ddc538-3249-4e53-9f97-705698a0f85a)
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9485] audit: op="connection-activate" uuid="42ddc538-3249-4e53-9f97-705698a0f85a" name="Ethernet connection 2" pid=1405202 uid=1000 result="success"
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9487] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9494] manager: NetworkManager state is now CONNECTING
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9497] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9510] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9515] dhcp4 (enp2s0): activation: beginning transaction (timeout in 45 seconds)
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9647] dhcp4 (enp2s0): option dhcp_lease_time => '3600'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9647] dhcp4 (enp2s0): option domain_name => 'intra'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9648] dhcp4 (enp2s0): option domain_name_servers => '192.168.226.2'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9648] dhcp4 (enp2s0): option domain_search => 'company.com intra int.company.com'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9648] dhcp4 (enp2s0): option expiry => '1616065012'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9648] dhcp4 (enp2s0): option ip_address => '192.168.226.104'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9648] dhcp4 (enp2s0): option requested_broadcast_address => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9648] dhcp4 (enp2s0): option requested_domain_name => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9648] dhcp4 (enp2s0): option requested_domain_name_servers => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9648] dhcp4 (enp2s0): option requested_domain_search => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9648] dhcp4 (enp2s0): option requested_host_name => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9648] dhcp4 (enp2s0): option requested_interface_mtu => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9649] dhcp4 (enp2s0): option requested_ms_classless_static_routes => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9649] dhcp4 (enp2s0): option requested_nis_domain => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9649] dhcp4 (enp2s0): option requested_nis_servers => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9649] dhcp4 (enp2s0): option requested_ntp_servers => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9649] dhcp4 (enp2s0): option requested_rfc3442_classless_static_routes => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9649] dhcp4 (enp2s0): option requested_root_path => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9649] dhcp4 (enp2s0): option requested_routers => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9649] dhcp4 (enp2s0): option requested_static_routes => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9649] dhcp4 (enp2s0): option requested_subnet_mask => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9649] dhcp4 (enp2s0): option requested_time_offset => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9650] dhcp4 (enp2s0): option requested_wpad => '1'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9650] dhcp4 (enp2s0): option routers => '192.168.226.2'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9650] dhcp4 (enp2s0): option subnet_mask => '255.255.255.0'
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9650] dhcp4 (enp2s0): state changed unknown -> bound
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9662] device (enp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9733] device (enp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9737] device (enp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9743] manager: NetworkManager state is now CONNECTED_LOCAL
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9754] manager: NetworkManager state is now CONNECTED_SITE
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9756] policy: set 'Ethernet connection 2' (enp2s0) as default for IPv4 routing and DNS
Mar 18 11:56:52 test-user NetworkManager[782]: <info> [1616061412.9762] device (enp2s0): Activation: successful, device activated.
Mar 18 11:56:53 test-user NetworkManager[782]: <info> [1616061413.2761] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 18 11:57:03 test-user systemd[1]: NetworkManager-dispatcher.service: Succeeded.
18 мар 2021, 16:21
DHCP не может обновить адрес, после чего NM делает полное переподключение интерфейса - это помогает. 30 минут - это период аренды адреса, который выдает сервер.
Это все, что могу сказать на основе таких куцых данных.
Serg063
18 мар 2021, 16:43
18 мар 2021, 16:21
На сервере время аренды стоит 1 час
broken
Благодарил (а): 21 раз
18 мар 2021, 16:45
Serg063 писал(а):
18 мар 2021, 15:39
Как и версии такой не было. 18.3 была. Дальше 19 идёт.
18 мар 2021, 20:32
Serg063 писал(а):
18 мар 2021, 15:39
У вас несколько сетевых плат или так соединение обозвано? Странно, на шнурке вообще проблем быть не должно. А если статический адрес назначить, будет пропадать сеть?
