Не устанавливается телеграм из ppa?
Justsar
Благодарил (а): 10 раз
17 мар 2021, 20:39
Не могу установить телеграм из ppa:atareao/telegram. Такое выводит в консоли:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
linux-hwe-5.4-headers-5.4.0-52 linux-hwe-5.4-headers-5.4.0-56
Use 'sudo apt autoremove' to remove them.
The following NEW packages will be installed:
telegram
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/11,6 kB of archives.
After this operation, 28,7 kB of additional disk space will be used.
Selecting previously unselected package telegram.
(Reading database ... 358847 files and directories currently installed.)
Preparing to unpack .../telegram_2.6.4-0ubuntu1_amd64.deb ...
Unpacking telegram (2.6.4-0ubuntu1) ...
Setting up telegram (2.6.4-0ubuntu1) ...
tar: This does not look like a tar archive
xz: (stdin): File format not recognized
tar: Child returned status 1
tar: Error is not recoverable: exiting now
dpkg: error processing package telegram (--configure):
installed telegram package post-installation script subprocess returned error exit status 2
Processing triggers for mime-support (3.60ubuntu1) ...
Processing triggers for desktop-file-utils (0.23+linuxmint8) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
Errors were encountered while processing:
telegram
xz-utils установлена. Чего посоветуете?
System: Host: linuxMint Kernel: 5.4.0-67-generic x86_64 bits: 64 compiler: gcc v: 7.5.0 Desktop: Cinnamon 4.4.8
Machine: Type: Desktop Mobo: Foxconn model: G31MX Series serial: <filter> BIOS: Phoenix v: 6.00 PG date: 11/05/2009
CPU: Topology: Quad Core model: Intel Xeon E5440 bits: 64 type: MCP arch: Penryn rev: A L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 22649
Speed: 1998 MHz min/max: 1998/2831 MHz Core speeds (MHz): 1: 1999 2: 1999 3: 1999 4: 1999
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Gigabyte driver: nvidia v: 450.102.04 bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: nvidia resolution: 1920x1200~60Hz
OpenGL: renderer: GeForce GTX 1060 3GB/PCIe/SSE2 v: 4.6.0 NVIDIA 450.102.04 direct render: Yes
Audio: Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: Foxconn driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.4.0-67-generic
Network: Device-1: VIA VT6105/VT6106S [Rhine-III] vendor: D-Link System DFE-520TX Fast PCI driver: via-rhine v: N/A
port: ee00 bus ID: 04:01.0
IF: enp4s1 state: unknown speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 1.65 TiB used: 566.50 GiB (33.6%)
ID-1: /dev/sda vendor: Western Digital model: WD7501AALS-00J7B0 size: 698.64 GiB
ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-22MFCA0 size: 931.51 GiB
ID-3: /dev/sdc model: SPCC Solid State Disk size: 55.90 GiB
Partition: ID-1: / size: 31.55 GiB used: 12.20 GiB (38.7%) fs: ext4 dev: /dev/sdc1
ID-2: /home size: 17.75 GiB used: 4.14 GiB (23.3%) fs: ext4 dev: /dev/sdc2
ID-3: swap-1 size: 5.42 GiB used: 768 KiB (0.0%) fs: swap dev: /dev/sdc3
Sensors: System Temperatures: cpu: 57.0 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Info: Processes: 220 Uptime: 25m Memory: 3.84 GiB used: 2.26 GiB (58.9%) Init: systemd runlevel: 5 Compilers: gcc: 7.5.0
Shell: bash v: 4.4.20 inxi: 3.0.32
17 мар 2021, 20:55
Justsar писал(а):
17 мар 2021, 20:39
Чего посоветуете?
Скачать телеграм с оффсайта. Распаковать и запустить прямо в хомяке.
17 мар 2021, 21:10
Justsar писал(а):
17 мар 2021, 20:39
Чего посоветуете?
Можно установить из flatpack https://flathub.org/apps/details/org.telegram.desktop
demonlibra
Благодарил (а): 29 раз
17 мар 2021, 21:33
Justsar писал(а):
17 мар 2021, 20:39
Чего посоветуете?
тоже что и symon2014
https://telegram.org/dl/desktop/linux
и не нужны дополнительные репозитории. Меньше сторонних репозиториев, меньше проблем.
ppa:atareao/telegram ещё и beta версию предлагают. Тем более плохая идея.
Telegram любит по несколько версий в день выпускать.
Если очень хочется получить последние глюки
https://github.com/telegramdesktop/tdesktop/releases
Сейчас последней стабильной для Linux является 2.6.1
Контекстное меню Nemo
18 мар 2021, 01:53
Вообще непонятно откуда пакет ставился. В выхлопе написано, что Preparing to unpack .../telegram_2.6.4-0ubuntu1_amd64.deb ...
Но при просмотре подробностей на этом PPA последний пакет для Bionic только telegram_2.6.1-0ubuntu1_amd64.deb (33.7 МiB) и на него есть прямая ссылка. Причем на момент написания этого комментария пакет 2.6.1 выложен 3 часа назад. Хотя в столбце Series стоит Bionic в Changelog написано, что Focal [telegram (2.6.1-0ubuntu1) focal; urgency=medium]
Происхождение пакета telegram_2.6.4-0ubuntu1_amd64.deb для меня является загадкой. Может быть что-то в PPA было напутано, а потом сопровождающий увидел косяк и поправил?
Justsar
18 мар 2021, 05:48
17 мар 2021, 20:55
Так и сделаю.
17 мар 2021, 21:10
У меня он есть в софт менеджере, размер установщика 1 гиг, в развернутом виде требует 2,7 гига места на диске. Это законно вобще? :hoho:
madesta писал(а):
18 мар 2021, 01:53
Уверен что так и есть. Вчера помню просматривал список файлов в пакете telegram - 2.6.1-0ubuntu1 для Bionic и там в списке был telegram_2.6.4-0ubuntu1.tar.xz. Я такой подвох не заметил. :smile:
18 мар 2021, 08:24
Justsar писал(а):
18 мар 2021, 05:48
Вполне себе. Это "песочница" отдельная от основной системы, притащит с собой все необходимые библиотеки, и ей пофиг на версии библиотек в системе и версию системы
