Пропадает Интернет Linux Mint
ribalks
09 мар 2021, 14:11
У меня беспроводной интернет, который пропадает через каждые 30 минут, после переподключения все снова работает.
Вот нужные данные для решения моей проблемы:
~$ inxi -Fxz
Kernel: 5.4.0-66-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.8.6 Distro: Linux Mint 20.1 Ulyssa
base: Ubuntu 20.04 focal
Type: Desktop Mobo: Biostar model: P35D2-A7 serial: <filter> BIOS: Phoenix
v: 6.00 PG date: 07/18/2008
Topology: Dual Core model: Intel Core2 Duo E8200 bits: 64 type: MCP
arch: Penryn rev: 6 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 10644
Speed: 1996 MHz min/max: 1998/2664 MHz Core speeds (MHz): 1: 1996 2: 1996
Device-1: AMD RV670 [Radeon HD 3690/3850] vendor: ASUSTeK driver: radeon
v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: ati,radeon
OpenGL: renderer: AMD RV670 (DRM 2.50.0 / 5.4.0-66-generic LLVM 11.0.0)
v: 3.3 Mesa 20.2.6 direct render: Yes
Device-1: Intel 82801I HD Audio vendor: Biostar Microtech Intl Corp
Device-2: AMD RV670/680 HDMI Audio [Radeon HD 3690/3800 Series]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.4.0-66-generic
Device-1: Ralink RT3060 Wireless 802.11n 1T/1R driver: rt2800pci v: 2.3.0
port: db00 bus ID: 04:01.0
IF: wlp4s1 state: up mac: <filter>
Device-2: Realtek RTL-8110SC/8169SC Gigabit Ethernet
vendor: Biostar Microtech Intl Corp driver: r8169 v: kernel port: ce00
bus ID: 04:04.0
IF: enp4s4 state: down mac: <filter>
Local Storage: total: 456.46 GiB used: 22.77 GiB (5.0%)
ID-1: /dev/sda vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
temp: 41 C
ID-2: /dev/sdb vendor: Samsung model: HD251HJ size: 232.89 GiB temp: 29 C
ID-1: / size: 27.38 GiB used: 9.06 GiB (33.1%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 56.63 GiB used: 13.63 GiB (24.1%) fs: ext4 dev: /dev/sda6
ID-3: swap-1 size: 3.72 GiB used: 82.5 MiB (2.2%) fs: swap dev: /dev/sda5
System Temperatures: cpu: 44.0 C mobo: N/A gpu: radeon temp: 63 C
Processes: 215 Uptime: 3h 46m Memory: 3.84 GiB used: 2.00 GiB (51.9%)
inxi: 3.0.38
часть /var/log/syslog
:43:01 dancomp-OEM avahi-daemon[806]: Leaving mDNS multicast group on interface wlp4s1.IPv6 with address fe80::60b0:22d5:85d5:71df.
Mar 9 13:43:01 dancomp-OEM systemd[1]: Starting Load/Save RF Kill Switch Status...
Mar 9 13:43:01 dancomp-OEM avahi-daemon[806]: Interface wlp4s1.IPv4 no longer relevant for mDNS.
Mar 9 13:43:01 dancomp-OEM avahi-daemon[806]: Leaving mDNS multicast group on interface wlp4s1.IPv4 with address 192.168.0.103.
Mar 9 13:43:01 dancomp-OEM avahi-daemon[806]: Withdrawing address record for fe80::60b0:22d5:85d5:71df on wlp4s1.
Mar 9 13:43:01 dancomp-OEM avahi-daemon[806]: Withdrawing address record for 192.168.0.103 on wlp4s1.
Mar 9 13:43:01 dancomp-OEM wpa_supplicant[840]: rfkill: WLAN soft blocked
Mar 9 13:43:01 dancomp-OEM geoclue[2250]: WiFi scan failed
Mar 9 13:43:01 dancomp-OEM NetworkManager[810]: <info> [1615290181.4424] dhcp4 (wlp4s1): canceled DHCP transaction
Mar 9 13:43:01 dancomp-OEM NetworkManager[810]: <info> [1615290181.4425] dhcp4 (wlp4s1): state changed bound -> done
Mar 9 13:43:01 dancomp-OEM NetworkManager[810]: <info> [1615290181.4547] manager: NetworkManager state is now DISCONNECTED
Mar 9 13:43:01 dancomp-OEM NetworkManager[810]: <info> [1615290181.4609] audit: op="radio-control" arg="wireless-enabled" pid=2177 uid=1000 result="success"
Mar 9 13:43:01 dancomp-OEM systemd[1]: Started Load/Save RF Kill Switch Status.
Mar 9 13:43:01 dancomp-OEM NetworkManager[810]: <info> [1615290181.4758] manager: rfkill: Wi-Fi now disabled by radio killswitch
Mar 9 13:43:01 dancomp-OEM dbus-daemon[809]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.11' (uid=0 pid=810 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
Mar 9 13:43:01 dancomp-OEM systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 9 13:43:01 dancomp-OEM wpa_supplicant[840]: nl80211: deinit ifname=wlp4s1 disabled_11b_rates=0
Mar 9 13:43:01 dancomp-OEM dbus-daemon[809]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 9 13:43:01 dancomp-OEM systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 9 13:43:01 dancomp-OEM nm-dispatcher[45191]: run-parts: failed to stat component /etc/network/if-post-down.d/avahi-daemon: No such file or directory
Mar 9 13:43:02 dancomp-OEM NetworkManager[810]: <info> [1615290182.4247] manager: rfkill: Wi-Fi hardware radio set enabled
Mar 9 13:43:02 dancomp-OEM NetworkManager[810]: <info> [1615290182.8000] audit: op="radio-control" arg="wireless-enabled" pid=2177 uid=1000 result="success"
Mar 9 13:43:02 dancomp-OEM NetworkManager[810]: <info> [1615290182.8006] manager: rfkill: Wi-Fi now enabled by radio killswitch
Mar 9 13:43:02 dancomp-OEM wpa_supplicant[840]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface.P2PDevice dbus_property=P2PDeviceConfig getter failed
Mar 9 13:43:02 dancomp-OEM NetworkManager[810]: <info> [1615290182.8525] sup-iface[0x563291d514c0,wlp4s1]: supports 4 scan SSIDs
Mar 9 13:43:02 dancomp-OEM NetworkManager[810]: <info> [1615290182.8548] device (wlp4s1): supplicant interface state: starting -> ready
Mar 9 13:43:02 dancomp-OEM NetworkManager[810]: <info> [1615290182.8549] device (wlp4s1): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9352] policy: auto-activating connection '1setka1' (43963c86-f4b6-4300-a443-1ca39f8f0c7e)
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9384] device (wlp4s1): Activation: starting connection '1setka1' (43963c86-f4b6-4300-a443-1ca39f8f0c7e)
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9389] device (wlp4s1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9427] manager: NetworkManager state is now CONNECTING
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9488] device (wlp4s1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9502] device (wlp4s1): Activation: (wifi) access point '1setka1' has security, but secrets are required.
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9503] device (wlp4s1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9575] device (wlp4s1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9612] device (wlp4s1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9623] device (wlp4s1): Activation: (wifi) connection '1setka1' has security, and secrets exist. No new secrets needed.
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9623] Config: added 'ssid' value '1setka1'
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9624] Config: added 'scan_ssid' value '1'
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9624] Config: added 'bgscan' value 'simple:30:-70:86400'
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9624] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9624] Config: added 'auth_alg' value 'OPEN'
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9624] Config: added 'psk' value '<hidden>'
Mar 9 13:43:03 dancomp-OEM wpa_supplicant[840]: wlp4s1: SME: Trying to authenticate with 90:f6:52:87:62:2e (SSID='1setka1' freq=2452 MHz)
Mar 9 13:43:03 dancomp-OEM kernel: [12147.221985] wlp4s1: authenticate with 90:f6:52:87:62:2e
Mar 9 13:43:03 dancomp-OEM kernel: [12147.225193] wlp4s1: send auth to 90:f6:52:87:62:2e (try 1/3)
Mar 9 13:43:03 dancomp-OEM wpa_supplicant[840]: wlp4s1: Trying to associate with 90:f6:52:87:62:2e (SSID='1setka1' freq=2452 MHz)
Mar 9 13:43:03 dancomp-OEM kernel: [12147.226521] wlp4s1: authenticated
Mar 9 13:43:03 dancomp-OEM kernel: [12147.227914] wlp4s1: associate with 90:f6:52:87:62:2e (try 1/3)
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9779] device (wlp4s1): supplicant interface state: ready -> associating
Mar 9 13:43:03 dancomp-OEM kernel: [12147.231485] wlp4s1: RX AssocResp from 90:f6:52:87:62:2e (capab=0x431 status=0 aid=1)
Mar 9 13:43:03 dancomp-OEM kernel: [12147.231540] wlp4s1: associated
Mar 9 13:43:03 dancomp-OEM wpa_supplicant[840]: wlp4s1: Associated with 90:f6:52:87:62:2e
Mar 9 13:43:03 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 9 13:43:03 dancomp-OEM NetworkManager[810]: <info> [1615290183.9882] device (wlp4s1): supplicant interface state: associating -> associated
Mar 9 13:43:04 dancomp-OEM wpa_supplicant[840]: wlp4s1: WPA: Key negotiation completed with 90:f6:52:87:62:2e [PTK=CCMP GTK=TKIP]
Mar 9 13:43:04 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-CONNECTED - Connection to 90:f6:52:87:62:2e completed [id=0 id_str=]
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1282] device (wlp4s1): supplicant interface state: associated -> completed
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1286] device (wlp4s1): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "1setka1"
Mar 9 13:43:04 dancomp-OEM kernel: [12147.376602] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s1: link becomes ready
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1321] device (wlp4s1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1390] dhcp4 (wlp4s1): activation: beginning transaction (timeout in 45 seconds)
Mar 9 13:43:04 dancomp-OEM avahi-daemon[806]: Joining mDNS multicast group on interface wlp4s1.IPv6 with address fe80::60b0:22d5:85d5:71df.
Mar 9 13:43:04 dancomp-OEM avahi-daemon[806]: New relevant interface wlp4s1.IPv6 for mDNS.
Mar 9 13:43:04 dancomp-OEM avahi-daemon[806]: Registering new address record for fe80::60b0:22d5:85d5:71df on wlp4s1.*.
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1583] dhcp4 (wlp4s1): option dhcp_lease_time => '7200'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1584] dhcp4 (wlp4s1): option domain_name_servers => '192.168.0.1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1584] dhcp4 (wlp4s1): option expiry => '1615297384'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1584] dhcp4 (wlp4s1): option ip_address => '192.168.0.103'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1584] dhcp4 (wlp4s1): option requested_broadcast_address => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1584] dhcp4 (wlp4s1): option requested_domain_name => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1586] dhcp4 (wlp4s1): option requested_domain_name_servers => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1586] dhcp4 (wlp4s1): option requested_domain_search => '1'
Mar 9 13:43:04 dancomp-OEM avahi-daemon[806]: Joining mDNS multicast group on interface wlp4s1.IPv4 with address 192.168.0.103.
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1586] dhcp4 (wlp4s1): option requested_host_name => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1586] dhcp4 (wlp4s1): option requested_interface_mtu => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1587] dhcp4 (wlp4s1): option requested_ms_classless_static_routes => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1587] dhcp4 (wlp4s1): option requested_nis_domain => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1587] dhcp4 (wlp4s1): option requested_nis_servers => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1588] dhcp4 (wlp4s1): option requested_ntp_servers => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1588] dhcp4 (wlp4s1): option requested_rfc3442_classless_static_routes => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1588] dhcp4 (wlp4s1): option requested_root_path => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1589] dhcp4 (wlp4s1): option requested_routers => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1589] dhcp4 (wlp4s1): option requested_static_routes => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1590] dhcp4 (wlp4s1): option requested_subnet_mask => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1590] dhcp4 (wlp4s1): option requested_time_offset => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1590] dhcp4 (wlp4s1): option requested_wpad => '1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1591] dhcp4 (wlp4s1): option routers => '192.168.0.1'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1591] dhcp4 (wlp4s1): option subnet_mask => '255.255.255.0'
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1591] dhcp4 (wlp4s1): state changed unknown -> bound
Mar 9 13:43:04 dancomp-OEM avahi-daemon[806]: New relevant interface wlp4s1.IPv4 for mDNS.
Mar 9 13:43:04 dancomp-OEM avahi-daemon[806]: Registering new address record for 192.168.0.103 on wlp4s1.IPv4.
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1666] device (wlp4s1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1772] device (wlp4s1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1796] device (wlp4s1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1814] manager: NetworkManager state is now CONNECTED_LOCAL
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1911] manager: NetworkManager state is now CONNECTED_SITE
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1939] policy: set '1setka1' (wlp4s1) as default for IPv4 routing and DNS
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.1947] device (wlp4s1): Activation: successful, device activated.
Mar 9 13:43:04 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-31 noise=9999 txrate=60000
Mar 9 13:43:04 dancomp-OEM NetworkManager[810]: <info> [1615290184.6041] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 9 13:43:07 dancomp-OEM systemd[1]: systemd-rfkill.service: Succeeded.
Mar 9 13:43:14 dancomp-OEM systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Mar 9 13:43:17 dancomp-OEM rtkit-daemon[1876]: Supervising 3 threads of 2 processes of 1 users.
Mar 9 13:43:37 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 13:44:28 dancomp-OEM wpa_supplicant[840]: message repeated 12 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 13:44:33 dancomp-OEM rtkit-daemon[1876]: Supervising 3 threads of 2 processes of 1 users.
Mar 9 13:44:38 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 13:45:04 dancomp-OEM wpa_supplicant[840]: message repeated 8 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 13:45:09 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 13:45:27 dancomp-OEM wpa_supplicant[840]: message repeated 7 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 13:45:28 dancomp-OEM PackageKit: daemon quit
Mar 9 13:45:28 dancomp-OEM systemd[1]: packagekit.service: Succeeded.
Mar 9 13:45:29 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 13:48:08 dancomp-OEM wpa_supplicant[840]: message repeated 57 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 13:48:11 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Mar 9 13:48:21 dancomp-OEM geoclue[2250]: Failed to query location: Ошибка разрешения «location.services.mozilla.com»: Неизвестное имя или служба
Mar 9 13:48:38 dancomp-OEM udisksd[839]: Cleaning up mount point /media/dancomp/E610373110370857 (device 8:21 is not mounted)
Mar 9 13:48:38 dancomp-OEM systemd[1]: media-dancomp-E610373110370857.mount: Succeeded.
Mar 9 13:48:38 dancomp-OEM ntfs-3g[3888]: Unmounting /dev/sdb5 ()
Mar 9 13:48:38 dancomp-OEM systemd[1]: Stopping Clean the /media/dancomp/E610373110370857 mount point...
Mar 9 13:48:38 dancomp-OEM systemd[1798]: media-dancomp-E610373110370857.mount: Succeeded.
Mar 9 13:48:38 dancomp-OEM systemd[1]: clean-mount-point@media-dancomp-E610373110370857.service: Succeeded.
Mar 9 13:48:38 dancomp-OEM systemd[1]: Stopped Clean the /media/dancomp/E610373110370857 mount point.
Mar 9 13:48:38 dancomp-OEM udisksd[839]: Unmounted /dev/sdb5 on behalf of uid 1000
Mar 9 13:48:46 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 13:50:00 dancomp-OEM wpa_supplicant[840]: message repeated 61 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 13:50:09 dancomp-OEM rtkit-daemon[1876]: Supervising 3 threads of 2 processes of 1 users.
Mar 9 13:50:13 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 13:50:23 dancomp-OEM wpa_supplicant[840]: message repeated 2 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 13:50:23 dancomp-OEM rtkit-daemon[1876]: Supervising 3 threads of 2 processes of 1 users.
Mar 9 13:50:31 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 13:52:18 dancomp-OEM wpa_supplicant[840]: message repeated 67 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 13:52:20 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 13:52:35 dancomp-OEM wpa_supplicant[840]: message repeated 13 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 13:52:37 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 13:52:39 dancomp-OEM wpa_supplicant[840]: message repeated 2 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 13:52:39 dancomp-OEM avahi-daemon[806]: Withdrawing address record for ::1 on lo.
Mar 9 13:52:39 dancomp-OEM avahi-daemon[806]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
Mar 9 13:52:39 dancomp-OEM avahi-daemon[806]: Interface lo.IPv6 no longer relevant for mDNS.
Mar 9 13:52:39 dancomp-OEM avahi-daemon[806]: Withdrawing address record for fe80::60b0:22d5:85d5:71df on wlp4s1.
Mar 9 13:52:39 dancomp-OEM avahi-daemon[806]: Leaving mDNS multicast group on interface wlp4s1.IPv6 with address fe80::60b0:22d5:85d5:71df.
Mar 9 13:52:39 dancomp-OEM avahi-daemon[806]: Interface wlp4s1.IPv6 no longer relevant for mDNS.
Mar 9 13:52:43 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 13:55:29 dancomp-OEM wpa_supplicant[840]: message repeated 88 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 13:55:30 dancomp-OEM rtkit-daemon[1876]: Supervising 3 threads of 2 processes of 1 users.
Mar 9 13:55:32 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 13:58:13 dancomp-OEM wpa_supplicant[840]: message repeated 77 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 13:58:27 dancomp-OEM geoclue[2250]: Failed to query location: Ошибка разрешения «location.services.mozilla.com»: Неизвестное имя или служба
Mar 9 13:58:34 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 14:00:00 dancomp-OEM wpa_supplicant[840]: message repeated 44 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 14:00:01 dancomp-OEM CRON[45872]: (root) CMD (timeshift --check --scripted)
Mar 9 14:00:01 dancomp-OEM crontab[45905]: (root) LIST (root)
Mar 9 14:00:01 dancomp-OEM crontab[45906]: (root) LIST (root)
Mar 9 14:00:02 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 14:00:48 dancomp-OEM wpa_supplicant[840]: message repeated 16 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 14:00:50 dancomp-OEM rtkit-daemon[1876]: Supervising 3 threads of 2 processes of 1 users.
Mar 9 14:00:52 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 14:06:55 dancomp-OEM wpa_supplicant[840]: message repeated 193 times: [ wlp4s1: CTRL-EVENT-BEACON-LOSS ]
Mar 9 14:06:56 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
Mar 9 14:07:16 dancomp-OEM wpa_supplicant[840]: wlp4s1: CTRL-EVENT-BEACON-LOSS
09 мар 2021, 14:27
ribalks, покажи вывод iwconfig
09 мар 2021, 14:31
DHCP отваливается. Интерфейс теряет IP адрес. Почему - не ясно, т.к. в предоставленном куске лога этого нету. Сделайте команду journalctl -b > log.txt и полученный файл покажите целиком. Разумеется, journalctl делать нужно после того как сеть отвалится.
ribalks
09 мар 2021, 14:40
symon2014,
dancomp@dancomp-OEM:~$ iwconfig
wlp4s1    IEEE 802.11  ESSID:"1setka1"
          Mode:Managed  Frequency:2.452 GHz  Access Point: 90:F6:52:87:62:2E
          Bit Rate=150 Mb/s   Tx-Power=20 dBm
          Retry short  long limit:2   RTS thr:off   Fragment thr:off
          Power Management:on
          Link Quality=70/70  Signal level=-33 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:37   Missed beacon:0
lo        no wireless extensions.
enp4s4    no wireless extensions.
Последний раз редактировалось пользователем 1 Dja; всего редактировалось раз: 11
Причина: Spoil
ribalks
09 мар 2021, 14:47
инет пока что не отвалился, но буквально 5 минут это было
файл скинуть не дает, говорит не то расширение
09 мар 2021, 14:53
ribalks писал(а):
09 мар 2021, 14:47
Текстовый файл или скопировать прямо в сообщение под спойлер , но лучше через пастебин.
ribalks
09 мар 2021, 14:57
symon2014, он слишком большой чтобы скопировать, а на две части могу потерять что то важное, так как он действительно большой. Что значит пастебин?)
09 мар 2021, 14:59
ribalks писал(а):
09 мар 2021, 14:57
Чтоб не слишком углубляться , сервисы для передачи текстов. Например - https://paste.ubuntu.com/
ribalks
09 мар 2021, 15:01
symon2014, https://paste.ubuntu.com/p/jmZkcvRyrz/, надеюсь ссылка работает
ribalks
09 мар 2021, 15:08
09 мар 2021, 14:31
подловил момент когда отвлился инет, вот лог https://paste.ubuntu.com/p/wfbF7qfHm9/
09 мар 2021, 15:21
Попробуй такую конструкцию.
echo "options rt2800pci fwlps=0 swlps=0" | sudo tee /etc/modprobe.d/rt2800pci.conf
Потом ребутнись , и жди , продолжит отваливаться или нет.
09 мар 2021, 15:27
ribalks, попробуй поменять шифрование в роутере.
Подозреваю что там
мар 09 10:20:50 dancomp-OEM NetworkManager[810]: <info> [1615278050.9078] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Замени на WPA2-PSK
ribalks
09 мар 2021, 15:32
symon2014, опять упал инет :( спустя 3 минуты после перезагрузки
ribalks
09 мар 2021, 15:33
vir0id, мне нужно ввести команду из гифки ниже или что то изменить, чтобы заменить что то на WPA2-PSK? Я действительно не понимаю
09 мар 2021, 15:35
ribalks писал(а):
09 мар 2021, 15:33
Зайди в настройки роутера и в разделе wifi замени своё шифрование пароля от 1setka1
09 мар 2021, 15:36
vir0id, не вижу связи с отваливанием работающей сети и шифрованием.
09 мар 2021, 15:45
09 мар 2021, 15:36
Ну а разницу ты видишь?
09 мар 2021, 15:46
vir0id писал(а):
09 мар 2021, 15:45
Между чем и чем ?
ribalks
09 мар 2021, 15:48
vir0id, вот настройки моего роутера, я не нахожу здесь WPA2-PSK, что я делаю не так?
sheridan
Решено: 14
Благодарил (а): 900 раз
09 мар 2021, 15:59
Вот
Сейчас этот форум просматривают: Google [Bot] и 2 гостя
