При воспроизведении видео ноутбук зависает.
Viktor_M
Благодарил (а): 2 раза
01 мар 2021, 16:31
Linux Mint 20x64
  Kernel: 5.4.0-65-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: MATE 1.24.0 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
  Type: Laptop System: HP product: HP Laptop 15-bs1xx
  v: Type1ProductConfigId serial: <filter>
  Mobo: HP model: 8444 v: 67.33 serial: <filter> UEFI: Insyde v: F.60
  date: 05/17/2019
  ID-1: BAT1 charge: 22.4 Wh condition: 29.8/31.1 Wh (96%)
  model: COMPAL PABAS0241231 status: Discharging
  Topology: Dual Core model: Intel Core i3-5005U bits: 64 type: MT MCP
  arch: Broadwell rev: 4 L2 cache: 3072 KiB
  bogomips: 16000
  Speed: 800 MHz min/max: 500/1900 MHz Core speeds (MHz): 1: 800 2: 801
  3: 800 4: 800
  Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.20.9 driver: intel resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.2.6
  Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:03.0
  Device-2: Intel Wildcat Point-LP High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k5.4.0-65-generic
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 07:00.0
  IF: eno1 state: down mac: <filter>
  Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
  vendor: Hewlett-Packard driver: rtw_pci v: N/A port: 3000 bus ID: 0d:00.0
  Device-3: Realtek 802.11n WLAN Adapter type: USB driver: btusb
  bus ID: 2-4:3
  Local Storage: total: 473.04 GiB used: 53.24 GiB (11.3%)
  ID-1: /dev/sda vendor: Seagate model: ST500LM030-1RK17D size: 465.76 GiB
  ID-2: /dev/sdb type: USB vendor: Transcend model: JetFlash Transcend 8GB
  ID-1: / size: 45.58 GiB used: 16.38 GiB (35.9%) fs: ext4 dev: /dev/sda4
  ID-2: /home size: 107.51 GiB used: 32.30 GiB (30.0%) fs: ext4
  dev: /dev/sda7
  ID-3: swap-1 size: 3.73 GiB used: 20.8 MiB (0.5%) fs: swap dev: /dev/sda6
  System Temperatures: cpu: 44.0 C mobo: N/A
  Processes: 225 Uptime: 3h 31m Memory: 3.76 GiB used: 1.90 GiB (50.6%)
  inxi: 3.0.38
При попытки включить видео любого формата на ноутбуки , он просто намертво зависает. Спасает только перезагрузка. Пробовал разные плееры с разными настройками - не помогло. В браузере видео нормально работает.
Последний раз редактировалось пользователем 1 Viktor_M; всего редактировалось раз: 1
01 мар 2021, 16:33
Viktor_M, при установке проприетарь устанавливалась ?
Viktor_M
01 мар 2021, 16:34
01 мар 2021, 16:33
Да
01 мар 2021, 16:46
Viktor_M, запусти видео из терминала , посмотри , что скажет.
Viktor_M
01 мар 2021, 17:14
01 мар 2021, 16:46
Вот попробовал через vlc
VLC media player 3.0.9.2 Vetinari (revision 3.0.9.2-0-gd4c1aefe4d)
[00005585883c5670] main libvlc: Запуск vlc с интерфейсом по умолчанию. Используйте 'cvlc' для запуска vlc без интерфейса.
qt5ct: using qt5ct plugin
qt5ct: D-Bus global menu: no
qt5ct: D-Bus system tray: no
libva info: VA-API version 1.7.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_7
libva info: va_openDriver() returns 0
Убито
01 мар 2021, 17:16
Это кусок текста без начала и конца.
01 мар 2021, 17:20
Хм...странно все это. Должно норм проигрываться
Viktor_M
01 мар 2021, 17:42
01 мар 2021, 17:16
Вот попробовал через mplayer. Видео включилось, и вот что выдало в консоль. Или надо было через какую-то команду?
MPlayer 1.3.0 (Debian), built with gcc-9 (C) 2000-2016 MPlayer Team
do_connect: could not connect to socket
connect: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing movie.mp4.
libavformat version 58.29.100 (external)
libavformat file format detected.
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x7f211a689600]Protocol name not provided, cannot determine if input is local or a network protocol, buffers and access patterns cannot be configured optimally without knowing the protocol
[lavf] stream 0: video (h264), -vid 0
[lavf] stream 1: audio (aac), -aid 0, -alang und
VIDEO: [H264] 1024x576 24bpp 24.000 fps 7908.5 kbps (965.4 kbyte/s)
Failed to open VDPAU backend libvdpau_va_gl.so: cannot open shared object file: No such file or directory
[vdpau] Error when calling vdp_device_create_x11: 1
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
libavcodec version 58.54.100 (external)
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
Clip info:
major_brand: isom
minor_version: 512
compatible_brands: isomiso2avc1mp41
encoder: Lavf58.29.100
Load subtitles in ./
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 48000 Hz, 2 ch, floatle, 433.7 kbit/14.12% (ratio: 54210->384000)
Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
AO: [pulse] 48000Hz 2ch floatle (4 bytes per sample)
Starting playback...
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
VO: [xv] 1024x576 => 1024x576 Planar YV12
A: 3.9 V: 3.9 A-V: 0.000 ct: 0.020 0/ 0 41% 1% 1.0% 2 0
Exiting... (Quit)
01 мар 2021, 17:55
Viktor_M писал(а):
01 мар 2021, 17:42
Я просил показывать выводы терминала полностью. Примеры ниже.
abulaev2008
Благодарил (а): 24 раза
02 мар 2021, 08:18
Viktor_M писал(а):
01 мар 2021, 16:31
inxi -Fxz снимал перед запуском видео? Последи за температурой во время воспроизведения.
02 мар 2021, 11:50
Viktor_M, Судя по выводу и вашему описанию - у вас с аппаратным декодированием видео проблема. Программное - работает (броузер, и mplayer на него автоматически переходит когда обламывается с аппаратным). IMHO здесь надо химичить в сторону драйвера видео - где-то что-то не совсем встало. Возможно, для начала имеет смысл посмотреть системный журнал с момента запуска - возможно при старте системы там что-то пишется по этому поводу (journalctl -b).
Вернуться в «Mate»
