Cinnamon загружает процессор при подключчении второго монитора
samec2011
Благодарил (а): 6 раз
22 фев 2021, 10:33
Привет. Есть старенький ноутбук, Compaq nx7400
timofey@timofey-pc:~$ inxi -Fxz
  Kernel: 5.4.0-65-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: Cinnamon 4.8.6 Distro: Linux Mint 20.1 Ulyssa
  base: Ubuntu 20.04 focal
  Type: Laptop System: Hewlett-Packard
  product: HP Compaq nx7400 (RH387EA#ABD) v: F.0E serial: <filter>
  Mobo: Hewlett-Packard model: 30A2 v: KBC Version 40.17 serial: <filter>
  BIOS: Hewlett-Packard v: 68YGU Ver. F.0E date: 08/27/2008
  ID-1: C1BE charge: 8.1 Wh condition: 8.2/8.2 Wh (100%)
  model: Hewlett-Packard Primary status: Unknown
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
  charge: 100% (should be ignored) status: Discharging
  Topology: Dual Core model: Intel Core2 T7200 bits: 64 type: MCP
  arch: Core Merom rev: 6 L2 cache: 4096 KiB
  flags: lm nx pae sse sse2 sse3 ssse3 vmx bogomips: 7980
  Speed: 998 MHz min/max: 1000/2000 MHz Core speeds (MHz): 1: 998 2: 998
  Device-1: Intel Mobile 945GM/GMS 943/940GML Express Integrated Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.20.9 driver: intel
  unloaded: fbdev,modesetting,vesa resolution: 1280x800~60Hz
  OpenGL: renderer: Mesa DRI Intel 945GM v: 1.4 Mesa 20.2.6
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k5.4.0-65-generic
  Device-1: Broadcom and subsidiaries BCM4401-B0 100Base-TX
  vendor: Hewlett-Packard NX7300 laptop driver: b44 v: 2.0 port: 40d0
  bus ID: 02:0e.0
  Device-2: Broadcom and subsidiaries BCM4311 802.11b/g WLAN
  vendor: Hewlett-Packard driver: b43-pci-bridge v: N/A port: 40d0
  bus ID: 10:00.0
  IF-ID-1: eth0 state: down mac: <filter>
  IF-ID-2: wlan0 state: up mac: <filter>
  Local Storage: total: 298.09 GiB used: 24.78 GiB (8.3%)
  ID-1: /dev/sda vendor: Western Digital model: WD3200BPVT-24JJ5T0
  ID-1: / size: 45.58 GiB used: 11.59 GiB (25.4%) fs: ext4 dev: /dev/sda2
  ID-2: /home size: 120.50 GiB used: 13.19 GiB (10.9%) fs: ext4
  dev: /dev/sda3
  ID-3: swap-1 size: 4.66 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
  System Temperatures: cpu: 60.0 C mobo: 57.0 C
  Processes: 205 Uptime: 12m Memory: 3.28 GiB used: 1.17 GiB (35.6%)
  inxi: 3.0.38
Все прекрасно работает. Но стоит только подключить второй монитор, система "виснет". Если открыть system monitor, то видна вот такая картина:
Cinnamon загружает процессор. Как только отключаешь второй монитор - всё приходит в норму.
Мониторы - пробовал разные, картина одинаковая. Подключаю через вход vga на ноутбуке.
До вчерашнего дня был установлен mint 19.3. Там было всё то же самое. Обновил систему (не чистой установкой, а через обновление). Но это не помогло.
Скажите, где - что можно посмотреть, как исправить?
22 фев 2021, 10:39
samec2011, думаю стоит сменить DE. Посмотри в сторону MATE
samec2011
22 фев 2021, 12:00
с mate работает как надо.
Но хотелось бы разобраться с корицей...
Как то можно посмотреть, из за чего происходит нагрузка такая на процессор?
22 фев 2021, 12:02
samec2011 писал(а):
22 фев 2021, 12:00
Предложить свои незаурядные способности разработчикам Cinnamon)
22 фев 2021, 14:27
samec2011 писал(а):
22 фев 2021, 12:00
Нет аппаратного ускорения вот проц и отдувается.
Тяжеловата корица для твоего раритета
