LMDE не видит мой телефон
akula22
Благодарил (а): 8 раз
17 фев 2021, 12:59
Хочу в андроид студио использовать свой телефон для запуска приложений, но мой линукс почему-то не видит его
adb devices
List of devices attached
пусто
Телефон samsung duos, отладка по усб и режим разработчиков включен
lsusb
Bus 004 Device 002: ID 8087:8000 Intel Corp.
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 004: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 002 Device 003: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
Bus 002 Device 002: ID 09da:9090 A4Tech Co., Ltd. XL-730K / XL-750BK / XL-755BK Mice
Bus 002 Device 005: ID 248a:8514 Maxxter
System: Host: x Kernel: 4.19.0-14-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: Cinnamon 4.8.6
Distro: LMDE 4 Debbie base: Debian 10.2 buster
Machine: Type: Desktop Mobo: ASRock model: H81M serial: <filter> UEFI [Legacy]: American Megatrends v: P2.00
date: 01/18/2016
CPU: Topology: Dual Core model: Intel Pentium G3220 bits: 64 type: MCP arch: Haswell rev: 3 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11996
Speed: 2632 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 1389 2: 1329
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: ASRock driver: i915 v: kernel
bus ID: 00:02.0
Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel Haswell Desktop v: 4.5 Mesa 18.3.6 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Sound Server: ALSA v: k4.19.0-14-amd64
Network: Device-1: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: ASRock driver: alx v: kernel port: e000 bus ID: 04:00.0
Drives: Local Storage: total: 1.02 TiB used: 195.11 GiB (18.7%)
ID-1: /dev/sda vendor: KingMAX model: SSD 120GB size: 111.79 GiB temp: 29 C
ID-2: /dev/sdb vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB temp: 32 C
Partition: ID-1: / size: 54.03 GiB used: 34.93 GiB (64.7%) fs: ext4 dev: /dev/sda3
ID-2: swap-1 size: 7.81 GiB used: 512 KiB (0.0%) fs: swap dev: /dev/sda1
Sensors: System Temperatures: cpu: 35.0 C mobo: N/A
Info: Processes: 238 Uptime: 1h 13m Memory: 7.47 GiB used: 3.94 GiB (52.8%) Init: systemd runlevel: 5 Compilers:
gcc: 8.3.0 Shell: bash v: 5.0.3 inxi: 3.0.32
файл /etc/udev/rules.d/51-android.rules создал и прописал SUBSYSTEM=="usb", ATTR{idVendor}=="04e8", MODE="0666", GROUP="plugdev"
при подключение телефона запроса как подключить не появляется, зарядка идет
LMDE 5 Elsie :blink2: Cinnamon
i5-12400 / RTX 3050
17 фев 2021, 13:04
akula22 писал(а):
17 фев 2021, 12:59
кабель значит проверяй, хабы и прочее
17 фев 2021, 13:06
akula22 писал(а):
17 фев 2021, 12:59
lsusb
А его и не видно чет 04e8 среди устройств.
Меняется что-то в выводе если отключить телефон?
17 фев 2021, 13:06
akula22, зачем правило в udev?
Ну и в выводе lsusb нет твоего телефона.
Помниться когда баловался с andoidstudio не создавал никаких правил для udev.
Ну и как написали выше проверяй кабель. Желательно для таких целей использовать оригинальный кабель или кабель хорошего качества
akula22
17 фев 2021, 13:13
подозреваю что телефон очень старый, кабели менял, 100% рабочие, один прям только сегодня купил, думаю дело в телефоне. и к разных портам подключал
Еще слышал что можно по вай фаю подключать, не знаете как?
i5-12400 / RTX 3050
Whowka
Благодарил (а): 777 раз
17 фев 2021, 13:17
akula22, Какой нибудь другой смартфон через кабеля видит?
akula22
17 фев 2021, 13:23
подключил huawei тоже самое, тишина при подключение, просто начинается зарядка телефона и все
в lsusb ничего не меняется
i5-12400 / RTX 3050
Whowka
17 фев 2021, 13:25
Ну, похоже, кабеля только для зарядки. Нужен data-кабель.
17 фев 2021, 13:26
akula22, и телефон не реагирует на подключение?
Если не реагирует - или с кабелем проблемы или с портом на компе.
17 фев 2021, 13:32
Whowka писал(а):
17 фев 2021, 13:25
Нужен data-кабель.
Когда я прошивал свой первый смарт столкнулся с таким. Решил купить кабель в нашем магазине , сначала выбрал попроще - за 200 , у хозяина магазина стоял ноут , подоткнули мой телефон , молчит. Взял попробовать подороже - молчит. Хорошо что хозяин знакомый , порылся по сусекам , нашёл бэушный оригинальный , этот зразу мяукнул )) , но обошёлся мне , по знакомству в 350 )).
akula22
17 фев 2021, 13:37
сейчас взял у соседа телефон, тоже хуавей только по моднее по новее, и комп увидел его, при подключение выскочило как подключить, выбрал фото
Bus 002 Device 023: ID 12d1:107e Huawei Technologies Co., Ltd.
только у него провод тайп-с, тот же комп, а мои телефоны с моими разьемами usb не видит, три разных провода пробовал :blink2:
i5-12400 / RTX 3050
17 фев 2021, 13:38
С Китая заказывал 2 кабеля.
1. Дешевый. Комп/телефон друг друга видят, но зарядка по этому кабелю никакая - пол дня телефон заряжается. Оставил этот кабель на старой работе.
2. Чуть дороже, но уже обращал внимание на характеристики и выбирал вдумчиво. Комп/телефон друг друга видят, зарядка по этому кабелю как по оригинальному.
17 фев 2021, 13:48
akula22, как вариант - телефоны не в чехлах, которые мешают нормально воткнуть кабель полностью? если нет, то кабели гавно и под замену
как вариант ещё - ушатанные разъёмы на телефонах вхлам, что только зарядку и тянут
Whowka
17 фев 2021, 13:52
akula22, Поищи у кого-нибудь кабель, который со смартфоном в комплекте при продаже был.Через него должны увидеться.
akula22
17 фев 2021, 14:01
Все понял спасибо.
А так можно подключить по вайфай
adb tcpip 5555 команду adb tcpip 5555 чтобы открыть порт на устройстве для подключения adb.
Создать беспроводное отладочное соединение adb connect IPADDRESS.
В моем случае команда выглядела как adb connect 192.168.43.1
i5-12400 / RTX 3050
Вернуться в «LMDE»
