administrator@k21-1:~$ inxi -Fxz System: Kernel: 5.4.0-42-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Xfce 4.14.2 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal Machine: Type: Desktop Mobo: Foxconn model: G31MX Series serial: <filter> BIOS: Phoenix v: 6.00 PG date: 06/19/2008 CPU: Topology: Dual Core model: Intel Core2 Duo E7200 bits: 64 type: MCP arch: Penryn rev: 6 L2 cache: 3072 KiB flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 bogomips: 10133 Speed: 1600 MHz min/max: 1600/2534 MHz Core speeds (MHz): 1: 1600 2: 1600 Graphics: Device-1: Intel 82G33/G31 Express Integrated Graphics vendor: Foxconn driver: i915 v: kernel bus ID: 00:02.0 Display: x11 server: X.Org 1.20.8 driver: intel unloaded: fbdev,modesetting,vesa resolution: 1280x1024~60Hz OpenGL: renderer: Mesa DRI Intel G33 v: 1.4 Mesa 20.0.8 direct render: Yes Audio: Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: Foxconn driver: snd_hda_intel v: kernel bus ID: 00:1b.0 Sound Server: ALSA v: k5.4.0-42-generic Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Foxconn driver: r8169 v: kernel port: ee00 bus ID: 02:00.0 IF: enp2s0 state: down mac: <filter> Drives: Local Storage: total: 149.05 GiB used: 7.62 GiB (5.1%) ID-1: /dev/sda vendor: Western Digital model: WD1600AAJS-00B4A0 size: 149.05 GiB Partition: ID-1: / size: 48.97 GiB used: 7.06 GiB (14.4%) fs: ext4 dev: /dev/sda1 ID-2: /home size: 92.07 GiB used: 573.9 MiB (0.6%) fs: ext4 dev: /dev/sda6 ID-3: swap-1 size: 5.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5 Sensors: System Temperatures: cpu: 43.0 C mobo: N/A Fan Speeds (RPM): N/A Info: Processes: 154 Uptime: 54m Memory: 1.93 GiB used: 562.1 MiB (28.4%) Init: systemd runlevel: 5 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.17 inxi: 3.0.38
При сканировании, после начала цветного сканирования, программа simple scan (простое сканирование), document scanner (Сканер Документов), xsane закрывается. МФУ остается в зависшем состоянии сканирования, каретка с лампой сканера не двигается, на дисплее МФУ отображается информация о том что идет сканирование.
Насколько я понял, у Sane что касаемо драйверов для Xerox WorkCentre 3210 ничего не менялось, вот уже много, много лет.
В чем может быть проблема?, может сталкивался кто то с подобным?, дайте совет или подскажите решение если знаете в чем проблема.
Также выкладываю логи simple scan (простое сканирование), document scanner (Сканер Документов) в Linux Mint 17.1, 18.1, 19.1 и 20.1 x64, XFCE:
Linux Mint 20.1 x64 xfce - Document scanner 3.36.3 (Сканер Документов) - программа закрывается, МФУ зависает
[+0.00s] DEBUG: simple-scan.vala:1720: Starting simple-scan 3.36.3, PID=1923
[+0.00s] DEBUG: unsetenv() is not thread-safe and should not be used after threads are created
[+0.13s] DEBUG: _g_io_module_get_default: Found default implementation dconf (DConfSettingsBackend) for ‘gsettings-backend’
[+0.22s] DEBUG: app-window.vala:1906: Loading state from /home/mint/.cache/simple-scan/state
[+0.22s] DEBUG: app-window.vala:1885: Restoring window to 600x400 pixels
[+0.44s] DEBUG: scanner.vala:1539: sane_init () -> SANE_STATUS_GOOD
[+0.44s] DEBUG: scanner.vala:1545: SANE version 1.0.29
[+0.44s] DEBUG: scanner.vala:1606: Requesting redetection of scan devices
[+0.44s] DEBUG: scanner.vala:828: Processing request
[+0.55s] DEBUG: app-window.vala:1981: Saving state to /home/mint/.cache/simple-scan/state
[+6.28s] DEBUG: scanner.vala:341: sane_get_devices () -> SANE_STATUS_GOOD
[+6.28s] DEBUG: scanner.vala:353: Device: name="xerox_mfp:libusb:001:003" vendor="Xerox" model="Xerox WorkCentre 3210" type="multi-function peripheral"
[+6.60s] DEBUG: app-window.vala:1981: Saving state to /home/mint/.cache/simple-scan/state
[+16.42s] DEBUG: app-window.vala:1981: Saving state to /home/mint/.cache/simple-scan/state
[+18.14s] DEBUG: app-window.vala:1981: Saving state to /home/mint/.cache/simple-scan/state
[+18.50s] DEBUG: app-window.vala:1981: Saving state to /home/mint/.cache/simple-scan/state
[+26.41s] DEBUG: app-window.vala:1981: Saving state to /home/mint/.cache/simple-scan/state
[+27.64s] DEBUG: app-window.vala:1981: Saving state to /home/mint/.cache/simple-scan/state
[+29.17s] DEBUG: app-window.vala:1981: Saving state to /home/mint/.cache/simple-scan/state
[+40.51s] DEBUG: app-window.vala:1981: Saving state to /home/mint/.cache/simple-scan/state
[+41.91s] DEBUG: app-window.vala:1981: Saving state to /home/mint/.cache/simple-scan/state
[+42.66s] DEBUG: simple-scan.vala:1536: Requesting scan at 300 dpi from device 'xerox_mfp:libusb:001:003'
[+42.66s] DEBUG: scanner.vala:1674: Scanner.scan ("xerox_mfp:libusb:001:003", dpi=300, scan_mode=ScanMode.COLOR, depth=8, type=single, paper_width=2100, paper_height=2970, brightness=0, contrast=0, delay=3000ms)
[+42.66s] DEBUG: scanner.vala:828: Processing request
[+42.66s] DEBUG: scanner.vala:889: sane_open ("xerox_mfp:libusb:001:003") -> SANE_STATUS_GOOD
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (0)
[+42.66s] DEBUG: scanner.vala:760: Option 0: title='Number of options' type=int size=4 cap=soft-detect
[+42.66s] DEBUG: scanner.vala:763: Description: Read-only option that specifies how many options a specific device supports.
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (1)
[+42.66s] DEBUG: scanner.vala:760: Option 1: name='standard' title='Standard' type=group size=4
[+42.66s] DEBUG: scanner.vala:763: Description: Source, mode and resolution options
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (2)
[+42.66s] DEBUG: scanner.vala:760: Option 2: name='resolution' title='Scan resolution' type=int size=4 unit=dpi values=[75, 100, 150, 200, 300, 600, 1200] cap=soft-select,soft-detect
[+42.66s] DEBUG: scanner.vala:763: Description: Sets the resolution of the scanned image.
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (3)
[+42.66s] DEBUG: scanner.vala:760: Option 3: name='mode' title='Scan mode' type=string size=9 values=["Lineart", "Halftone", "Gray", "Color"] cap=soft-select,soft-detect
[+42.66s] DEBUG: scanner.vala:763: Description: Selects the scan mode (e.g., lineart, monochrome, or color).
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (4)
[+42.66s] DEBUG: scanner.vala:760: Option 4: name='highlight' title='Threshold' type=fixed size=4 unit=percent min=30.000000, max=70.000000, quant=655360 cap=soft-select,soft-detect,inactive
[+42.66s] DEBUG: scanner.vala:763: Description: Select minimum-brightness to get a white point
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (5)
[+42.66s] DEBUG: scanner.vala:760: Option 5: name='source' title='Scan source' type=string size=8 values=["Flatbed", "ADF", "Auto"] cap=soft-select,soft-detect
[+42.66s] DEBUG: scanner.vala:763: Description: Selects the scan source (such as a document-feeder).
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (6)
[+42.66s] DEBUG: scanner.vala:760: Option 6: name='geometry' title='Geometry' type=group size=4
[+42.66s] DEBUG: scanner.vala:763: Description: Scan area and media size options
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (7)
[+42.66s] DEBUG: scanner.vala:760: Option 7: name='tl-x' title='Top-left x' type=fixed size=4 unit=mm min=0.000000, max=215.899994, quant=65536 cap=soft-select,soft-detect
[+42.66s] DEBUG: scanner.vala:763: Description: Top-left x position of scan area.
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (8)
[+42.66s] DEBUG: scanner.vala:760: Option 8: name='tl-y' title='Top-left y' type=fixed size=4 unit=mm min=0.000000, max=297.179993, quant=65536 cap=soft-select,soft-detect
[+42.66s] DEBUG: scanner.vala:763: Description: Top-left y position of scan area.
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (9)
[+42.66s] DEBUG: scanner.vala:760: Option 9: name='br-x' title='Bottom-right x' type=fixed size=4 unit=mm min=0.000000, max=215.899994, quant=65536 cap=soft-select,soft-detect
[+42.66s] DEBUG: scanner.vala:763: Description: Bottom-right x position of scan area.
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (10)
[+42.66s] DEBUG: scanner.vala:760: Option 10: name='br-y' title='Bottom-right y' type=fixed size=4 unit=mm min=0.000000, max=297.179993, quant=65536 cap=soft-select,soft-detect
[+42.66s] DEBUG: scanner.vala:763: Description: Bottom-right y position of scan area.
[+42.66s] DEBUG: scanner.vala:910: sane_get_option_descriptor (11)
[+42.66s] DEBUG: scanner.vala:571: sane_control_option (5, SANE_ACTION_SET_VALUE, "Auto") -> (SANE_STATUS_GOOD, "Auto")
[+42.66s] DEBUG: scanner.vala:571: sane_control_option (3, SANE_ACTION_SET_VALUE, "Color") -> (SANE_STATUS_GOOD, "Color")
[+42.66s] DEBUG: scanner.vala:483: sane_control_option (2, SANE_ACTION_SET_VALUE, 300) -> (SANE_STATUS_GOOD, 300)
[+42.66s] DEBUG: scanner.vala:523: sane_control_option (9, SANE_ACTION_SET_VALUE, 210.000000) -> (SANE_STATUS_GOOD, 210.000000)
[+42.66s] DEBUG: scanner.vala:523: sane_control_option (10, SANE_ACTION_SET_VALUE, 297.000000) -> (SANE_STATUS_GOOD, 297.000000)
[+43.00s] DEBUG: app-window.vala:1981: Saving state to /home/mint/.cache/simple-scan/state
[+48.39s] DEBUG: scanner.vala:1285: sane_start (page=0, pass=0) -> SANE_STATUS_GOOD
[+48.39s] DEBUG: scanner.vala:1312: sane_get_parameters () -> SANE_STATUS_GOOD
[+48.39s] DEBUG: scanner.vala:1324: Parameters: format=SANE_FRAME_RGB last_frame=SANE_TRUE bytes_per_line=7488 pixels_per_line=2496 lines=3567 depth=8
[+48.39s] DEBUG: simple-scan.vala:1431: Page is 2496 pixels wide, 3567 pixels high, 8 bits per pixel
[+48.43s] DEBUG: simple-scan.vala:1365: Getting color profile for device xerox_mfp:libusb:001:003
[+48.44s] DEBUG: simple-scan.vala:1385: Unable to find colord device xerox_mfp:libusb:001:003: property match 'Serial'='sane:xerox_mfp:libusb:001:003' does not exist
Linux Mint 19.1 x64 xfce - Simple scan 3.28.0 (простое сканирование) - программа закрывается, МФУ зависает
[+0.00s] DEBUG: simple-scan.vala:637: Starting Simple Scan 3.28.0, PID=1707
[+0.19s] DEBUG: app-window.vala:1714: Loading state from /home/mint/.cache/simple-scan/state
[+0.19s] DEBUG: app-window.vala:1671: Restoring window to 600x400 pixels
[+0.19s] DEBUG: autosave-manager.vala:64: Loading autosave information
[+0.19s] DEBUG: autosave-manager.vala:259: Waiting to autosave...
[+0.37s] DEBUG: autosave-manager.vala:281: Autosaving book information
[+0.37s] DEBUG: scanner.vala:1454: sane_init () -> SANE_STATUS_GOOD
[+0.37s] DEBUG: scanner.vala:1460: SANE version 1.0.27
[+0.37s] DEBUG: scanner.vala:1521: Requesting redetection of scan devices
[+0.37s] DEBUG: scanner.vala:806: Processing request
[+0.50s] DEBUG: app-window.vala:1775: Saving state to /home/mint/.cache/simple-scan/state
[+2.11s] DEBUG: app-window.vala:1775: Saving state to /home/mint/.cache/simple-scan/state
[+3.29s] DEBUG: app-window.vala:1775: Saving state to /home/mint/.cache/simple-scan/state
[+5.47s] DEBUG: scanner.vala:341: sane_get_devices () -> SANE_STATUS_GOOD
[+5.47s] DEBUG: scanner.vala:353: Device: name="xerox_mfp:libusb:001:003" vendor="Xerox" model="Xerox WorkCentre 3210" type="multi-function peripheral"
[+5.57s] DEBUG: app-window.vala:1775: Saving state to /home/mint/.cache/simple-scan/state
[+9.70s] DEBUG: app-window.vala:1775: Saving state to /home/mint/.cache/simple-scan/state
[+10.83s] DEBUG: app-window.vala:1775: Saving state to /home/mint/.cache/simple-scan/state
[+11.92s] DEBUG: app-window.vala:1775: Saving state to /home/mint/.cache/simple-scan/state
[+12.34s] DEBUG: app-window.vala:1775: Saving state to /home/mint/.cache/simple-scan/state
[+12.51s] DEBUG: simple-scan.vala:454: Requesting scan at 300 dpi from device 'xerox_mfp:libusb:001:003'
[+12.51s] DEBUG: scanner.vala:1569: Scanner.scan ("xerox_mfp:libusb:001:003", dpi=300, scan_mode=ScanMode.COLOR, depth=8, type=ScanType.SINGLE, paper_width=2100, paper_height=2970, brightness=0, contrast=0, delay=10000ms)
[+12.51s] DEBUG: scanner.vala:806: Processing request
[+12.51s] DEBUG: scanner.vala:867: sane_open ("xerox_mfp:libusb:001:003") -> SANE_STATUS_GOOD
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (0)
[+12.51s] DEBUG: scanner.vala:738: Option 0: title='Number of options' type=int size=4 cap=soft-detect
[+12.51s] DEBUG: scanner.vala:741: Description: Read-only option that specifies how many options a specific devices supports.
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (1)
[+12.51s] DEBUG: scanner.vala:738: Option 1: name='standard' title='Standard' type=group size=4
[+12.51s] DEBUG: scanner.vala:741: Description: Source, mode and resolution options
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (2)
[+12.51s] DEBUG: scanner.vala:738: Option 2: name='resolution' title='Scan resolution' type=int size=4 unit=dpi values=[75, 100, 150, 200, 300, 600, 1200] cap=soft-select,soft-detect
[+12.51s] DEBUG: scanner.vala:741: Description: Sets the resolution of the scanned image.
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (3)
[+12.51s] DEBUG: scanner.vala:738: Option 3: name='mode' title='Scan mode' type=string size=9 values=["Lineart", "Halftone", "Gray", "Color"] cap=soft-select,soft-detect
[+12.51s] DEBUG: scanner.vala:741: Description: Selects the scan mode (e.g., lineart, monochrome, or color).
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (4)
[+12.51s] DEBUG: scanner.vala:738: Option 4: name='highlight' title='Threshold' type=fixed size=4 unit=percent min=30.000000, max=70.000000, quant=655360 cap=soft-select,soft-detect,inactive
[+12.51s] DEBUG: scanner.vala:741: Description: Select minimum-brightness to get a white point
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (5)
[+12.51s] DEBUG: scanner.vala:738: Option 5: name='source' title='Scan source' type=string size=8 values=["Flatbed", "ADF", "Auto"] cap=soft-select,soft-detect
[+12.51s] DEBUG: scanner.vala:741: Description: Selects the scan source (such as a document-feeder).
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (6)
[+12.51s] DEBUG: scanner.vala:738: Option 6: name='geometry' title='Geometry' type=group size=4
[+12.51s] DEBUG: scanner.vala:741: Description: Scan area and media size options
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (7)
[+12.51s] DEBUG: scanner.vala:738: Option 7: name='tl-x' title='Top-left x' type=fixed size=4 unit=mm min=0.000000, max=215.899994, quant=65536 cap=soft-select,soft-detect
[+12.51s] DEBUG: scanner.vala:741: Description: Top-left x position of scan area.
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (8)
[+12.51s] DEBUG: scanner.vala:738: Option 8: name='tl-y' title='Top-left y' type=fixed size=4 unit=mm min=0.000000, max=297.179993, quant=65536 cap=soft-select,soft-detect
[+12.51s] DEBUG: scanner.vala:741: Description: Top-left y position of scan area.
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (9)
[+12.51s] DEBUG: scanner.vala:738: Option 9: name='br-x' title='Bottom-right x' type=fixed size=4 unit=mm min=0.000000, max=215.899994, quant=65536 cap=soft-select,soft-detect
[+12.51s] DEBUG: scanner.vala:741: Description: Bottom-right x position of scan area.
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (10)
[+12.51s] DEBUG: scanner.vala:738: Option 10: name='br-y' title='Bottom-right y' type=fixed size=4 unit=mm min=0.000000, max=297.179993, quant=65536 cap=soft-select,soft-detect
[+12.51s] DEBUG: scanner.vala:741: Description: Bottom-right y position of scan area.
[+12.51s] DEBUG: scanner.vala:888: sane_get_option_descriptor (11)
[+12.51s] DEBUG: scanner.vala:549: sane_control_option (5, SANE_ACTION_SET_VALUE, "Auto") -> (SANE_STATUS_GOOD, "Auto")
[+12.51s] DEBUG: scanner.vala:549: sane_control_option (3, SANE_ACTION_SET_VALUE, "Color") -> (SANE_STATUS_GOOD, "Color")
[+12.51s] DEBUG: scanner.vala:465: sane_control_option (2, SANE_ACTION_SET_VALUE, 300) -> (SANE_STATUS_GOOD, 300)
[+12.51s] DEBUG: scanner.vala:505: sane_control_option (9, SANE_ACTION_SET_VALUE, 210.000000) -> (SANE_STATUS_GOOD, 210.000000)
[+12.51s] DEBUG: scanner.vala:505: sane_control_option (10, SANE_ACTION_SET_VALUE, 297.000000) -> (SANE_STATUS_GOOD, 297.000000)
[+12.97s] DEBUG: app-window.vala:1775: Saving state to /home/mint/.cache/simple-scan/state
[+18.36s] DEBUG: scanner.vala:1217: sane_start (page=0, pass=0) -> SANE_STATUS_GOOD
[+18.36s] DEBUG: scanner.vala:1246: Parameters: format=SANE_FRAME_RGB last_frame=SANE_TRUE bytes_per_line=7488 pixels_per_line=2496 lines=3567 depth=8
[+18.36s] DEBUG: simple-scan.vala:349: Page is 2496 pixels wide, 3567 pixels high, 8 bits per pixel
[+18.39s] DEBUG: simple-scan.vala:283: Getting color profile for device xerox_mfp:libusb:001:003
[+18.64s] DEBUG: simple-scan.vala:303: Unable to find colord device xerox_mfp:libusb:001:003: property match 'Serial'='sane:xerox_mfp:libusb:001:003' does not exist
Linux Mint 18.1 x64 xfce - Simple scan 3.20.0 (простое сканирование) - цветное сканирование завершается успешно
[+0.00s] DEBUG: simple-scan.vala:674: Starting Simple Scan 3.20.0, PID=2223
[+0.00s] DEBUG: Connecting to session manager
[+0.12s] DEBUG: ui.vala:2032: Loading state from /home/mint/.cache/simple-scan/state
[+0.12s] DEBUG: ui.vala:1995: Restoring window to 600x400 pixels
[+0.12s] DEBUG: autosave-manager.vala:64: Loading autosave information
[+0.12s] DEBUG: autosave-manager.vala:259: Waiting to autosave...
[+0.12s] CRITICAL: gtk_event_controller_reset: assertion 'GTK_IS_EVENT_CONTROLLER (controller)' failed
[+0.22s] DEBUG: scanner.vala:1447: sane_init () -> SANE_STATUS_GOOD
[+0.22s] DEBUG: scanner.vala:1453: SANE version 1.0.25
[+0.22s] DEBUG: scanner.vala:1514: Requesting redetection of scan devices
[+0.22s] DEBUG: scanner.vala:803: Processing request
[+0.23s] DEBUG: autosave-manager.vala:281: Autosaving book information
[+0.35s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+1.30s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+1.52s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+1.73s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+2.37s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+4.22s] DEBUG: scanner.vala:338: sane_get_devices () -> SANE_STATUS_GOOD
[+4.22s] DEBUG: scanner.vala:350: Device: name="xerox_mfp:libusb:001:003" vendor="Xerox" model="Xerox WorkCentre 3210" type="multi-function peripheral"
[+7.60s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+7.73s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+9.76s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+10.61s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+13.99s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+18.57s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+19.46s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+19.80s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+20.93s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+21.67s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+21.84s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+21.98s] DEBUG: simple-scan.vala:404: Requesting scan at 300 dpi from device 'xerox_mfp:libusb:001:003'
[+21.98s] DEBUG: scanner.vala:1560: Scanner.scan ("xerox_mfp:libusb:001:003", dpi=300, scan_mode=ScanMode.COLOR, depth=8, type=ScanType.SINGLE, paper_width=2100, paper_height=2970, brightness=0, contrast=0)
[+21.98s] DEBUG: scanner.vala:803: Processing request
[+21.98s] DEBUG: scanner.vala:864: sane_open ("xerox_mfp:libusb:001:003") -> SANE_STATUS_GOOD
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (0)
[+21.98s] DEBUG: scanner.vala:735: Option 0: title='Number of options' type=int size=4 cap=soft-detect
[+21.98s] DEBUG: scanner.vala:738: Description: Read-only option that specifies how many options a specific devices supports.
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (1)
[+21.98s] DEBUG: scanner.vala:735: Option 1: name='standard' title='Standard' type=group size=4
[+21.98s] DEBUG: scanner.vala:738: Description: Source, mode and resolution options
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (2)
[+21.98s] DEBUG: scanner.vala:735: Option 2: name='resolution' title='Scan resolution' type=int size=4 unit=dpi values=[75, 100, 150, 200, 300, 600, 1200] cap=soft-select,soft-detect
[+21.98s] DEBUG: scanner.vala:738: Description: Sets the resolution of the scanned image.
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (3)
[+21.98s] DEBUG: scanner.vala:735: Option 3: name='mode' title='Scan mode' type=string size=9 values=["Lineart", "Halftone", "Gray", "Color"] cap=soft-select,soft-detect
[+21.98s] DEBUG: scanner.vala:738: Description: Selects the scan mode (e.g., lineart, monochrome, or color).
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (4)
[+21.98s] DEBUG: scanner.vala:735: Option 4: name='highlight' title='Threshold' type=fixed size=4 unit=percent min=30.000000, max=70.000000, quant=655360 cap=soft-select,soft-detect,inactive
[+21.98s] DEBUG: scanner.vala:738: Description: Select minimum-brightness to get a white point
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (5)
[+21.98s] DEBUG: scanner.vala:735: Option 5: name='source' title='Scan source' type=string size=8 values=["Flatbed", "ADF", "Auto"] cap=soft-select,soft-detect
[+21.98s] DEBUG: scanner.vala:738: Description: Selects the scan source (such as a document-feeder).
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (6)
[+21.98s] DEBUG: scanner.vala:735: Option 6: name='geometry' title='Geometry' type=group size=4
[+21.98s] DEBUG: scanner.vala:738: Description: Scan area and media size options
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (7)
[+21.98s] DEBUG: scanner.vala:735: Option 7: name='tl-x' title='Top-left x' type=fixed size=4 unit=mm min=0.000000, max=215.899994, quant=65536 cap=soft-select,soft-detect
[+21.98s] DEBUG: scanner.vala:738: Description: Top-left x position of scan area.
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (8)
[+21.98s] DEBUG: scanner.vala:735: Option 8: name='tl-y' title='Top-left y' type=fixed size=4 unit=mm min=0.000000, max=297.179993, quant=65536 cap=soft-select,soft-detect
[+21.98s] DEBUG: scanner.vala:738: Description: Top-left y position of scan area.
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (9)
[+21.98s] DEBUG: scanner.vala:735: Option 9: name='br-x' title='Bottom-right x' type=fixed size=4 unit=mm min=0.000000, max=215.899994, quant=65536 cap=soft-select,soft-detect
[+21.98s] DEBUG: scanner.vala:738: Description: Bottom-right x position of scan area.
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (10)
[+21.98s] DEBUG: scanner.vala:735: Option 10: name='br-y' title='Bottom-right y' type=fixed size=4 unit=mm min=0.000000, max=297.179993, quant=65536 cap=soft-select,soft-detect
[+21.98s] DEBUG: scanner.vala:738: Description: Bottom-right y position of scan area.
[+21.98s] DEBUG: scanner.vala:885: sane_get_option_descriptor (11)
[+21.98s] DEBUG: scanner.vala:546: sane_control_option (5, SANE_ACTION_SET_VALUE, "Auto") -> (SANE_STATUS_GOOD, "Auto")
[+21.98s] DEBUG: scanner.vala:546: sane_control_option (3, SANE_ACTION_SET_VALUE, "Color") -> (SANE_STATUS_GOOD, "Color")
[+21.98s] DEBUG: scanner.vala:462: sane_control_option (2, SANE_ACTION_SET_VALUE, 300) -> (SANE_STATUS_GOOD, 300)
[+21.98s] DEBUG: scanner.vala:502: sane_control_option (9, SANE_ACTION_SET_VALUE, 210.000000) -> (SANE_STATUS_GOOD, 210.000000)
[+21.98s] DEBUG: scanner.vala:502: sane_control_option (10, SANE_ACTION_SET_VALUE, 297.000000) -> (SANE_STATUS_GOOD, 297.000000)
[+22.10s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+22.89s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+27.71s] DEBUG: scanner.vala:1213: sane_start (page=0, pass=0) -> SANE_STATUS_GOOD
[+27.71s] DEBUG: scanner.vala:1230: sane_get_parameters () -> SANE_STATUS_GOOD
[+27.71s] DEBUG: scanner.vala:1242: Parameters: format=SANE_FRAME_RGB last_frame=SANE_TRUE bytes_per_line=7488 pixels_per_line=2496 lines=3467 depth=8
[+27.71s] DEBUG: simple-scan.vala:348: Page is 2496 pixels wide, 3467 pixels high, 8 bits per pixel
[+27.73s] DEBUG: simple-scan.vala:282: Getting color profile for device xerox_mfp:libusb:001:003
[+27.75s] DEBUG: scanner.vala:1314: sane_read (7489) -> (SANE_STATUS_GOOD, 7489)
[+27.75s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.76s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.77s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.78s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.79s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.80s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.81s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.82s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.83s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.84s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+27.84s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.85s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.86s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.87s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.88s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.89s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.90s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.90s] DEBUG: simple-scan.vala:302: Unable to find colord device xerox_mfp:libusb:001:003: property match 'Serial'='sane:xerox_mfp:libusb:001:003' does not exist
[+27.91s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.92s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.93s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.94s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.95s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.96s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.97s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.98s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+27.99s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.00s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.01s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.02s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.03s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.04s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.05s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.06s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.07s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.08s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.09s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.10s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.11s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.12s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.13s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.14s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.15s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.16s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 14976)
[+28.16s] DEBUG: scanner.vala:1314: sane_read (14976) -> (SANE_STATUS_GOOD, 7487)
[+28.19s] DEBUG: scanner.vala:1314: sane_read (14977) -> (SANE_STATUS_GOOD, 14977)
[+28.19s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.20s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.21s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.22s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.23s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.24s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.25s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.26s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.27s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.28s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.29s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.30s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.31s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.32s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.33s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.34s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.35s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.36s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.37s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.38s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.39s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.40s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.41s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.42s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.43s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.44s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.45s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.46s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.47s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.48s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.49s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.50s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.51s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.52s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.53s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.54s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.55s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.56s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.57s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.58s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.59s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.60s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22464)
[+28.60s] DEBUG: scanner.vala:1314: sane_read (22464) -> (SANE_STATUS_GOOD, 22463)
[+28.64s] DEBUG: scanner.vala:1314: sane_read (22465) -> (SANE_STATUS_GOOD, 22465)
[+28.65s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.66s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.67s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.68s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.70s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.71s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.72s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.73s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.75s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.76s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.77s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.78s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.80s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.81s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.82s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.83s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.85s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.86s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.87s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.88s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.90s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.91s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.92s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.93s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.95s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.96s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.97s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+28.98s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+29.00s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+29.01s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+29.02s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+29.03s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+29.05s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 29952)
[+29.05s] DEBUG: scanner.vala:1314: sane_read (29952) -> (SANE_STATUS_GOOD, 7487)
[+29.08s] DEBUG: scanner.vala:1314: sane_read (29953) -> (SANE_STATUS_GOOD, 29953)
[+29.09s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.10s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.12s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.14s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.15s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.17s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.18s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.20s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.21s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.23s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.25s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.26s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.28s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.29s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.31s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.32s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.34s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.35s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.37s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.39s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.40s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.42s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.43s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.45s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.46s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.48s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.49s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 37440)
[+29.49s] DEBUG: scanner.vala:1314: sane_read (37440) -> (SANE_STATUS_GOOD, 7487)
[+29.52s] DEBUG: scanner.vala:1314: sane_read (37441) -> (SANE_STATUS_GOOD, 37441)
[+29.53s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.55s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.57s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.59s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.61s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.63s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.65s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.66s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.68s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.70s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.72s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.74s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.76s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.78s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.80s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.81s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.83s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.85s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.87s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.89s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.91s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.93s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 44928)
[+29.93s] DEBUG: scanner.vala:1314: sane_read (44928) -> (SANE_STATUS_GOOD, 22463)
[+29.96s] DEBUG: scanner.vala:1314: sane_read (44929) -> (SANE_STATUS_GOOD, 44929)
[+29.98s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.00s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.02s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.04s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.06s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.08s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.11s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.13s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.15s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.17s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.19s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.22s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.24s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.26s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.28s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.30s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.33s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.35s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.37s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 52416)
[+30.37s] DEBUG: scanner.vala:1314: sane_read (52416) -> (SANE_STATUS_GOOD, 7487)
[+30.41s] DEBUG: scanner.vala:1314: sane_read (52417) -> (SANE_STATUS_GOOD, 52417)
[+30.45s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.48s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.50s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.53s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.55s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.58s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.60s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.63s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.65s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.68s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.70s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.73s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.75s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.78s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.80s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.82s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 59904)
[+30.82s] DEBUG: scanner.vala:1314: sane_read (59904) -> (SANE_STATUS_GOOD, 37439)
[+30.88s] DEBUG: scanner.vala:1314: sane_read (59905) -> (SANE_STATUS_GOOD, 59905)
[+30.91s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+30.93s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+30.96s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+30.99s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+31.02s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+31.04s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+31.07s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+31.10s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+31.13s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+31.16s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+31.18s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+31.21s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+31.24s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+31.26s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 67392)
[+31.26s] DEBUG: scanner.vala:1314: sane_read (67392) -> (SANE_STATUS_GOOD, 44927)
[+31.32s] DEBUG: scanner.vala:1314: sane_read (67393) -> (SANE_STATUS_GOOD, 67393)
[+31.35s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.38s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.41s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.44s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.47s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.51s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.54s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.57s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.60s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.63s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.66s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.69s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.71s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 74880)
[+31.71s] DEBUG: scanner.vala:1314: sane_read (74880) -> (SANE_STATUS_GOOD, 7487)
[+31.76s] DEBUG: scanner.vala:1314: sane_read (74881) -> (SANE_STATUS_GOOD, 74881)
[+31.79s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 82368)
[+31.83s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 82368)
[+31.86s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 82368)
[+31.90s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 82368)
[+31.93s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 82368)
[+31.96s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 82368)
[+32.00s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 82368)
[+32.03s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 82368)
[+32.07s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 82368)
[+32.10s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 82368)
[+32.14s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 82368)
[+32.15s] DEBUG: scanner.vala:1314: sane_read (82368) -> (SANE_STATUS_GOOD, 67391)
[+32.20s] DEBUG: scanner.vala:1314: sane_read (82369) -> (SANE_STATUS_GOOD, 82369)
[+32.24s] DEBUG: scanner.vala:1314: sane_read (89856) -> (SANE_STATUS_GOOD, 89856)
[+32.27s] DEBUG: scanner.vala:1314: sane_read (89856) -> (SANE_STATUS_GOOD, 89856)
[+32.31s] DEBUG: scanner.vala:1314: sane_read (89856) -> (SANE_STATUS_GOOD, 89856)
[+32.35s] DEBUG: scanner.vala:1314: sane_read (89856) -> (SANE_STATUS_GOOD, 89856)
[+32.39s] DEBUG: scanner.vala:1314: sane_read (89856) -> (SANE_STATUS_GOOD, 89856)
[+32.42s] DEBUG: scanner.vala:1314: sane_read (89856) -> (SANE_STATUS_GOOD, 89856)
[+32.46s] DEBUG: scanner.vala:1314: sane_read (89856) -> (SANE_STATUS_GOOD, 89856)
[+32.50s] DEBUG: scanner.vala:1314: sane_read (89856) -> (SANE_STATUS_GOOD, 89856)
[+32.54s] DEBUG: scanner.vala:1314: sane_read (89856) -> (SANE_STATUS_GOOD, 89856)
[+32.57s] DEBUG: scanner.vala:1314: sane_read (89856) -> (SANE_STATUS_GOOD, 89856)
[+32.57s] DEBUG: scanner.vala:1314: sane_read (89856) -> (SANE_STATUS_GOOD, 37439)
[+32.63s] DEBUG: scanner.vala:1314: sane_read (89857) -> (SANE_STATUS_GOOD, 89857)
[+32.67s] DEBUG: scanner.vala:1314: sane_read (97344) -> (SANE_STATUS_GOOD, 97344)
[+32.71s] DEBUG: scanner.vala:1314: sane_read (97344) -> (SANE_STATUS_GOOD, 97344)
[+32.75s] DEBUG: scanner.vala:1314: sane_read (97344) -> (SANE_STATUS_GOOD, 97344)
[+32.79s] DEBUG: scanner.vala:1314: sane_read (97344) -> (SANE_STATUS_GOOD, 97344)
[+32.83s] DEBUG: scanner.vala:1314: sane_read (97344) -> (SANE_STATUS_GOOD, 97344)
[+32.87s] DEBUG: scanner.vala:1314: sane_read (97344) -> (SANE_STATUS_GOOD, 97344)
[+32.91s] DEBUG: scanner.vala:1314: sane_read (97344) -> (SANE_STATUS_GOOD, 97344)
[+32.95s] DEBUG: scanner.vala:1314: sane_read (97344) -> (SANE_STATUS_GOOD, 97344)
[+32.99s] DEBUG: scanner.vala:1314: sane_read (97344) -> (SANE_STATUS_GOOD, 97344)
[+33.02s] DEBUG: scanner.vala:1314: sane_read (97344) -> (SANE_STATUS_GOOD, 82367)
[+33.07s] DEBUG: scanner.vala:1314: sane_read (97345) -> (SANE_STATUS_GOOD, 97345)
[+33.11s] DEBUG: scanner.vala:1314: sane_read (104832) -> (SANE_STATUS_GOOD, 104832)
[+33.16s] DEBUG: scanner.vala:1314: sane_read (104832) -> (SANE_STATUS_GOOD, 104832)
[+33.20s] DEBUG: scanner.vala:1314: sane_read (104832) -> (SANE_STATUS_GOOD, 104832)
[+33.24s] DEBUG: scanner.vala:1314: sane_read (104832) -> (SANE_STATUS_GOOD, 104832)
[+33.29s] DEBUG: scanner.vala:1314: sane_read (104832) -> (SANE_STATUS_GOOD, 104832)
[+33.33s] DEBUG: scanner.vala:1314: sane_read (104832) -> (SANE_STATUS_GOOD, 104832)
[+33.38s] DEBUG: scanner.vala:1314: sane_read (104832) -> (SANE_STATUS_GOOD, 104832)
[+33.42s] DEBUG: scanner.vala:1314: sane_read (104832) -> (SANE_STATUS_GOOD, 104832)
[+33.46s] DEBUG: scanner.vala:1314: sane_read (104832) -> (SANE_STATUS_GOOD, 104832)
[+33.46s] DEBUG: scanner.vala:1314: sane_read (104832) -> (SANE_STATUS_GOOD, 7487)
[+33.52s] DEBUG: scanner.vala:1314: sane_read (104833) -> (SANE_STATUS_GOOD, 104833)
[+33.57s] DEBUG: scanner.vala:1314: sane_read (112320) -> (SANE_STATUS_GOOD, 112320)
[+33.61s] DEBUG: scanner.vala:1314: sane_read (112320) -> (SANE_STATUS_GOOD, 112320)
[+33.66s] DEBUG: scanner.vala:1314: sane_read (112320) -> (SANE_STATUS_GOOD, 112320)
[+33.71s] DEBUG: scanner.vala:1314: sane_read (112320) -> (SANE_STATUS_GOOD, 112320)
[+33.75s] DEBUG: scanner.vala:1314: sane_read (112320) -> (SANE_STATUS_GOOD, 112320)
[+33.80s] DEBUG: scanner.vala:1314: sane_read (112320) -> (SANE_STATUS_GOOD, 112320)
[+33.85s] DEBUG: scanner.vala:1314: sane_read (112320) -> (SANE_STATUS_GOOD, 112320)
[+33.89s] DEBUG: scanner.vala:1314: sane_read (112320) -> (SANE_STATUS_GOOD, 112320)
[+33.91s] DEBUG: scanner.vala:1314: sane_read (112320) -> (SANE_STATUS_GOOD, 44927)
[+33.97s] DEBUG: scanner.vala:1314: sane_read (112321) -> (SANE_STATUS_GOOD, 112321)
[+34.04s] DEBUG: scanner.vala:1314: sane_read (119808) -> (SANE_STATUS_GOOD, 119808)
[+34.09s] DEBUG: scanner.vala:1314: sane_read (119808) -> (SANE_STATUS_GOOD, 119808)
[+34.14s] DEBUG: scanner.vala:1314: sane_read (119808) -> (SANE_STATUS_GOOD, 119808)
[+34.19s] DEBUG: scanner.vala:1314: sane_read (119808) -> (SANE_STATUS_GOOD, 119808)
[+34.24s] DEBUG: scanner.vala:1314: sane_read (119808) -> (SANE_STATUS_GOOD, 119808)
[+34.29s] DEBUG: scanner.vala:1314: sane_read (119808) -> (SANE_STATUS_GOOD, 119808)
[+34.34s] DEBUG: scanner.vala:1314: sane_read (119808) -> (SANE_STATUS_GOOD, 119808)
[+34.36s] DEBUG: scanner.vala:1314: sane_read (119808) -> (SANE_STATUS_GOOD, 97343)
[+34.44s] DEBUG: scanner.vala:1314: sane_read (119809) -> (SANE_STATUS_GOOD, 119809)
[+34.49s] DEBUG: scanner.vala:1314: sane_read (127296) -> (SANE_STATUS_GOOD, 127296)
[+34.54s] DEBUG: scanner.vala:1314: sane_read (127296) -> (SANE_STATUS_GOOD, 127296)
[+34.59s] DEBUG: scanner.vala:1314: sane_read (127296) -> (SANE_STATUS_GOOD, 127296)
[+34.64s] DEBUG: scanner.vala:1314: sane_read (127296) -> (SANE_STATUS_GOOD, 127296)
[+34.69s] DEBUG: scanner.vala:1314: sane_read (127296) -> (SANE_STATUS_GOOD, 127296)
[+34.75s] DEBUG: scanner.vala:1314: sane_read (127296) -> (SANE_STATUS_GOOD, 127296)
[+34.79s] DEBUG: scanner.vala:1314: sane_read (127296) -> (SANE_STATUS_GOOD, 127296)
[+34.79s] DEBUG: scanner.vala:1314: sane_read (127296) -> (SANE_STATUS_GOOD, 37439)
[+34.86s] DEBUG: scanner.vala:1314: sane_read (127297) -> (SANE_STATUS_GOOD, 127297)
[+34.91s] DEBUG: scanner.vala:1314: sane_read (134784) -> (SANE_STATUS_GOOD, 134784)
[+34.97s] DEBUG: scanner.vala:1314: sane_read (134784) -> (SANE_STATUS_GOOD, 134784)
[+35.02s] DEBUG: scanner.vala:1314: sane_read (134784) -> (SANE_STATUS_GOOD, 134784)
[+35.07s] DEBUG: scanner.vala:1314: sane_read (134784) -> (SANE_STATUS_GOOD, 134784)
[+35.13s] DEBUG: scanner.vala:1314: sane_read (134784) -> (SANE_STATUS_GOOD, 134784)
[+35.18s] DEBUG: scanner.vala:1314: sane_read (134784) -> (SANE_STATUS_GOOD, 134784)
[+35.21s] DEBUG: scanner.vala:1314: sane_read (134784) -> (SANE_STATUS_GOOD, 112319)
[+35.29s] DEBUG: scanner.vala:1314: sane_read (134785) -> (SANE_STATUS_GOOD, 134785)
[+35.35s] DEBUG: scanner.vala:1314: sane_read (142272) -> (SANE_STATUS_GOOD, 142272)
[+35.40s] DEBUG: scanner.vala:1314: sane_read (142272) -> (SANE_STATUS_GOOD, 142272)
[+35.46s] DEBUG: scanner.vala:1314: sane_read (142272) -> (SANE_STATUS_GOOD, 142272)
[+35.52s] DEBUG: scanner.vala:1314: sane_read (142272) -> (SANE_STATUS_GOOD, 142272)
[+35.57s] DEBUG: scanner.vala:1314: sane_read (142272) -> (SANE_STATUS_GOOD, 142272)
[+35.63s] DEBUG: scanner.vala:1314: sane_read (142272) -> (SANE_STATUS_GOOD, 142272)
[+35.64s] DEBUG: scanner.vala:1314: sane_read (142272) -> (SANE_STATUS_GOOD, 59903)
[+35.72s] DEBUG: scanner.vala:1314: sane_read (142273) -> (SANE_STATUS_GOOD, 142273)
[+35.78s] DEBUG: scanner.vala:1314: sane_read (149760) -> (SANE_STATUS_GOOD, 149760)
[+35.84s] DEBUG: scanner.vala:1314: sane_read (149760) -> (SANE_STATUS_GOOD, 149760)
[+35.90s] DEBUG: scanner.vala:1314: sane_read (149760) -> (SANE_STATUS_GOOD, 149760)
[+35.96s] DEBUG: scanner.vala:1314: sane_read (149760) -> (SANE_STATUS_GOOD, 149760)
[+36.02s] DEBUG: scanner.vala:1314: sane_read (149760) -> (SANE_STATUS_GOOD, 149760)
[+36.07s] DEBUG: scanner.vala:1314: sane_read (149760) -> (SANE_STATUS_GOOD, 149760)
[+36.07s] DEBUG: scanner.vala:1314: sane_read (149760) -> (SANE_STATUS_GOOD, 7487)
[+36.14s] DEBUG: scanner.vala:1314: sane_read (149761) -> (SANE_STATUS_GOOD, 149761)
[+36.20s] DEBUG: scanner.vala:1314: sane_read (157248) -> (SANE_STATUS_GOOD, 157248)
[+36.26s] DEBUG: scanner.vala:1314: sane_read (157248) -> (SANE_STATUS_GOOD, 157248)
[+36.33s] DEBUG: scanner.vala:1314: sane_read (157248) -> (SANE_STATUS_GOOD, 157248)
[+36.39s] DEBUG: scanner.vala:1314: sane_read (157248) -> (SANE_STATUS_GOOD, 157248)
[+36.45s] DEBUG: scanner.vala:1314: sane_read (157248) -> (SANE_STATUS_GOOD, 157248)
[+36.49s] DEBUG: scanner.vala:1314: sane_read (157248) -> (SANE_STATUS_GOOD, 112319)
[+36.56s] DEBUG: scanner.vala:1314: sane_read (157249) -> (SANE_STATUS_GOOD, 157249)
[+36.63s] DEBUG: scanner.vala:1314: sane_read (164736) -> (SANE_STATUS_GOOD, 164736)
[+36.69s] DEBUG: scanner.vala:1314: sane_read (164736) -> (SANE_STATUS_GOOD, 164736)
[+36.75s] DEBUG: scanner.vala:1314: sane_read (164736) -> (SANE_STATUS_GOOD, 164736)
[+36.82s] DEBUG: scanner.vala:1314: sane_read (164736) -> (SANE_STATUS_GOOD, 164736)
[+36.89s] DEBUG: scanner.vala:1314: sane_read (164736) -> (SANE_STATUS_GOOD, 164736)
[+36.90s] DEBUG: scanner.vala:1314: sane_read (164736) -> (SANE_STATUS_GOOD, 67391)
[+36.99s] DEBUG: scanner.vala:1314: sane_read (164737) -> (SANE_STATUS_GOOD, 164737)
[+37.06s] DEBUG: scanner.vala:1314: sane_read (172224) -> (SANE_STATUS_GOOD, 172224)
[+37.13s] DEBUG: scanner.vala:1314: sane_read (172224) -> (SANE_STATUS_GOOD, 172224)
[+37.19s] DEBUG: scanner.vala:1314: sane_read (172224) -> (SANE_STATUS_GOOD, 172224)
[+37.26s] DEBUG: scanner.vala:1314: sane_read (172224) -> (SANE_STATUS_GOOD, 172224)
[+37.32s] DEBUG: scanner.vala:1314: sane_read (172224) -> (SANE_STATUS_GOOD, 164735)
[+37.41s] DEBUG: scanner.vala:1314: sane_read (172225) -> (SANE_STATUS_GOOD, 172225)
[+37.50s] DEBUG: scanner.vala:1314: sane_read (179712) -> (SANE_STATUS_GOOD, 179712)
[+37.57s] DEBUG: scanner.vala:1314: sane_read (179712) -> (SANE_STATUS_GOOD, 179712)
[+37.64s] DEBUG: scanner.vala:1314: sane_read (179712) -> (SANE_STATUS_GOOD, 179712)
[+37.71s] DEBUG: scanner.vala:1314: sane_read (179712) -> (SANE_STATUS_GOOD, 179712)
[+37.75s] DEBUG: scanner.vala:1314: sane_read (179712) -> (SANE_STATUS_GOOD, 157247)
[+37.86s] DEBUG: scanner.vala:1314: sane_read (179713) -> (SANE_STATUS_GOOD, 179713)
[+37.93s] DEBUG: scanner.vala:1314: sane_read (187200) -> (SANE_STATUS_GOOD, 187200)
[+38.00s] DEBUG: scanner.vala:1314: sane_read (187200) -> (SANE_STATUS_GOOD, 187200)
[+38.08s] DEBUG: scanner.vala:1314: sane_read (187200) -> (SANE_STATUS_GOOD, 187200)
[+38.15s] DEBUG: scanner.vala:1314: sane_read (187200) -> (SANE_STATUS_GOOD, 187200)
[+38.17s] DEBUG: scanner.vala:1314: sane_read (187200) -> (SANE_STATUS_GOOD, 119807)
[+38.28s] DEBUG: scanner.vala:1314: sane_read (187201) -> (SANE_STATUS_GOOD, 187201)
[+38.36s] DEBUG: scanner.vala:1314: sane_read (194688) -> (SANE_STATUS_GOOD, 194688)
[+38.44s] DEBUG: scanner.vala:1314: sane_read (194688) -> (SANE_STATUS_GOOD, 194688)
[+38.50s] DEBUG: scanner.vala:1314: sane_read (194688) -> (SANE_STATUS_GOOD, 194688)
[+38.50s] DEBUG: scanner.vala:1314: sane_read (194688) -> (SANE_STATUS_GOOD, 14975)
[+38.50s] DEBUG: scanner.vala:1314: sane_read (194689) -> (SANE_STATUS_GOOD, 74880)
[+38.51s] DEBUG: scanner.vala:1314: sane_read (194689) -> (SANE_STATUS_EOF, 0)
[+38.51s] DEBUG: scanner.vala:1186: sane_cancel ()
[+38.51s] DEBUG: autosave-manager.vala:349: Autosaving page pixels to /home/mint/.cache/simple-scan/autosaves/1429598080.pixels
[+38.53s] DEBUG: autosave-manager.vala:281: Autosaving book information
[+38.53s] DEBUG: autosave-manager.vala:298: Autosaving page page-0
[+38.65s] DEBUG: ui.vala:2124: Saving state to /home/mint/.cache/simple-scan/state
[+45.20s] DEBUG: autosave-manager.vala:195: Deleting autosave records
[+45.21s] DEBUG: scanner.vala:1587: Stopping scan thread
[+45.21s] DEBUG: scanner.vala:803: Processing request
[+45.21s] DEBUG: scanner.vala:765: sane_cancel ()
[+45.21s] DEBUG: scanner.vala:768: sane_close ()
[+45.21s] DEBUG: scanner.vala:1598: sane_exit ()
