CP2102 USB TTL нет ответа
wanoska
Благодарил (а): 40 раз
22 янв 2021, 09:58
не работает cp2102, драйвера вроде поставил а в putty просто черное окно и не чего не сыпится
Kernel: 5.4.0-54-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Xfce 4.14.2 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Type: Laptop System: HP product: HP Laptop 15-bs0xx
v: Type1ProductConfigId serial: <filter>
Mobo: HP model: 832C v: 25.53 serial: <filter> UEFI: Insyde v: F.52
date: 03/04/2019
Topology: Dual Core model: Intel Celeron N3060 bits: 64 type: MCP
arch: Airmont rev: 4 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 6400
Speed: 1757 MHz min/max: 480/2480 MHz Core speeds (MHz): 1: 2228 2: 2215
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (BSW) v: 4.6 Mesa 20.0.8
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.4.0-54-generic
Device-1: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_pci v: N/A port: 2000 bus ID: 02:00.0
vendor: Hewlett-Packard driver: r8169 v: kernel port: 1000 bus ID: 03:00.0
IF: eno1 state: down mac: <filter>
Local Storage: total: 111.80 GiB used: 73.50 GiB (65.7%)
ID-1: /dev/sda vendor: Western Digital model: WDS120G2G0A-00JH30
ID-1: / size: 36.42 GiB used: 10.30 GiB (28.3%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 70.03 GiB used: 63.19 GiB (90.2%) fs: ext4
dev: /dev/sda3
ID-3: swap-1 size: 2.79 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda4
System Temperatures: cpu: 35.0 C mobo: 27.8 C
Processes: 154 Uptime: 22m Memory: 3.75 GiB used: 1.25 GiB (33.2%)
inxi: 3.0.38
lsusb | grep UART
Bus 001 Device 004: ID 0bda:b009 Realtek Semiconductor Corp. CP2102 USB to UART Bridge Controller
Bus 001 Device 006: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
dmesg | grep UART
[ 1062.633250] usb 1-3: Product: CP2102 USB to UART Bridge Controller
22 янв 2021, 10:01
Благодарил (а): 1737 раз
22 янв 2021, 10:06
wanoska, dmesg при подключении покажи и ls /dev/tty*
wanoska
22 янв 2021, 10:07
22 янв 2021, 10:01
https://www.linux.org.ru/forum/general/14786316
пробовал не помогло
wanoska
22 янв 2021, 10:08
ls /dev/tty*
/dev/tty /dev/tty23 /dev/tty39 /dev/tty54 /dev/ttyS10 /dev/ttyS26
/dev/tty0 /dev/tty24 /dev/tty4 /dev/tty55 /dev/ttyS11 /dev/ttyS27
/dev/tty1 /dev/tty25 /dev/tty40 /dev/tty56 /dev/ttyS12 /dev/ttyS28
/dev/tty10 /dev/tty26 /dev/tty41 /dev/tty57 /dev/ttyS13 /dev/ttyS29
/dev/tty11 /dev/tty27 /dev/tty42 /dev/tty58 /dev/ttyS14 /dev/ttyS3
/dev/tty12 /dev/tty28 /dev/tty43 /dev/tty59 /dev/ttyS15 /dev/ttyS30
/dev/tty13 /dev/tty29 /dev/tty44 /dev/tty6 /dev/ttyS16 /dev/ttyS31
/dev/tty14 /dev/tty3 /dev/tty45 /dev/tty60 /dev/ttyS17 /dev/ttyS4
/dev/tty15 /dev/tty30 /dev/tty46 /dev/tty61 /dev/ttyS18 /dev/ttyS5
/dev/tty16 /dev/tty31 /dev/tty47 /dev/tty62 /dev/ttyS19 /dev/ttyS6
/dev/tty17 /dev/tty32 /dev/tty48 /dev/tty63 /dev/ttyS2 /dev/ttyS7
/dev/tty18 /dev/tty33 /dev/tty49 /dev/tty7 /dev/ttyS20 /dev/ttyS8
/dev/tty19 /dev/tty34 /dev/tty5 /dev/tty8 /dev/ttyS21 /dev/ttyS9
/dev/tty2 /dev/tty35 /dev/tty50 /dev/tty9 /dev/ttyS22 /dev/ttyUSB0
/dev/tty20 /dev/tty36 /dev/tty51 /dev/ttyprintk /dev/ttyS23
/dev/tty21 /dev/tty37 /dev/tty52 /dev/ttyS0 /dev/ttyS24
/dev/tty22 /dev/tty38 /dev/tty53 /dev/ttyS1 /dev/ttyS25
22 янв 2021, 10:06
wanoska
22 янв 2021, 10:13
[ 0.060214] percpu: Embedded 54 pages/cpu s184320 r8192 d28672 u524288
[ 0.060236] pcpu-alloc: s184320 r8192 d28672 u524288 alloc=1*2097152
[ 0.060240] pcpu-alloc: [0] 0 1 2 3
[ 0.060325] Built 1 zonelists, mobility grouping on. Total pages: 1007263
[ 0.060329] Policy zone: Normal
[ 0.060333] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4.0-54-generic root=/dev/sda2 ro quiet rootfstype=ext4 libahci.ignore_sss=1 raid=noautodetect selinux=0 plymouth.enable=0 lpj=6400000
[ 0.062185] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.062998] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.063085] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.088973] Calgary: detecting Calgary via BIOS EBDA area
[ 0.088977] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.124298] Memory: 3791008K/4097656K available (14339K kernel code, 2398K rwdata, 4956K rodata, 2716K init, 4988K bss, 306648K reserved, 0K cma-reserved)
[ 0.124315] random: get_random_u64 called from kmem_cache_open+0x2d/0x410 with crng_init=0
[ 0.124768] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.124805] Kernel/User page tables isolation: enabled
[ 0.124845] ftrace: allocating 44527 entries in 174 pages
[ 0.157702] rcu: Hierarchical RCU implementation.
[ 0.157708] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
[ 0.157710] Tasks RCU enabled.
[ 0.157712] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.157714] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.166499] NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
[ 0.167027] random: crng done (trusting CPU's manufacturer)
[ 0.167103] Console: colour dummy device 80x25
[ 0.167113] printk: console [tty0] enabled
[ 0.167175] ACPI: Core revision 20190816
[ 0.167548] APIC: Switch to symmetric I/O mode setup
[ 0.169327] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x171024fa93b, max_idle_ns: 440795253189 ns
[ 0.169338] Calibrating delay loop (skipped) preset value.. 3200.00 BogoMIPS (lpj=6400000)
[ 0.169344] pid_max: default: 32768 minimum: 301
[ 0.173331] LSM: Security Framework initializing
[ 0.173331] Yama: becoming mindful.
[ 0.173331] AppArmor: AppArmor initialized
[ 0.173331] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.173331] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.173331] *** VALIDATE tmpfs ***
[ 0.173331] *** VALIDATE proc ***
[ 0.173331] *** VALIDATE cgroup1 ***
[ 0.173331] *** VALIDATE cgroup2 ***
[ 0.173331] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.173331] process: using mwait in idle threads
[ 0.173331] Last level iTLB entries: 4KB 48, 2MB 0, 4MB 0
[ 0.173331] Last level dTLB entries: 4KB 256, 2MB 16, 4MB 16, 1GB 0
[ 0.173331] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.173331] Spectre V2 : Mitigation: Full generic retpoline
[ 0.173331] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.173331] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.173331] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.173331] MDS: Mitigation: Clear CPU buffers
[ 0.173331] Freeing SMP alternatives memory: 40K
[ 0.173331] smpboot: CPU0: Intel(R) Celeron(R) CPU N3060 @ 1.60GHz (family: 0x6, model: 0x4c, stepping: 0x4)
[ 0.173331] Performance Events: PEBS fmt2+, 8-deep LBR, Silvermont events, 8-deep LBR, full-width counters, Intel PMU driver.
[ 0.173331] ... version: 3
[ 0.173331] ... bit width: 40
[ 0.173331] ... generic registers: 2
[ 0.173331] ... value mask: 000000ffffffffff
[ 0.173331] ... max period: 0000007fffffffff
[ 0.173331] ... fixed-purpose events: 3
[ 0.173331] ... event mask: 0000000700000003
[ 0.173331] rcu: Hierarchical SRCU implementation.
[ 0.173331] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.173331] smp: Bringing up secondary CPUs ...
[ 0.173331] x86: Booting SMP configuration:
[ 0.173331] .... node #0, CPUs: #1
[ 0.176709] smp: Brought up 1 node, 2 CPUs
[ 0.176709] smpboot: Max logical packages: 2
[ 0.176709] smpboot: Total of 2 processors activated (6400.00 BogoMIPS)
[ 0.178082] devtmpfs: initialized
[ 0.178082] x86/mm: Memory block size: 128MB
[ 0.178915] PM: Registering ACPI NVS region [mem 0x0006f000-0x0006ffff] (4096 bytes)
[ 0.178915] PM: Registering ACPI NVS region [mem 0x7aebf000-0x7bfbefff] (17825792 bytes)
[ 0.178915] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.178915] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.178915] pinctrl core: initialized pinctrl subsystem
[ 0.181402] PM: RTC time: 06:33:57, date: 2021-01-22
[ 0.181728] NET: Registered protocol family 16
[ 0.182039] audit: initializing netlink subsys (disabled)
[ 0.182123] audit: type=2000 audit(1611297237.012:1): state=initialized audit_enabled=0 res=1
[ 0.182123] EISA bus registered
[ 0.182123] cpuidle: using governor ladder
[ 0.182123] cpuidle: using governor menu
[ 0.182123] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.182123] ACPI: bus type PCI registered
[ 0.182123] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.182123] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xe0000000-0xe3ffffff] (base 0xe0000000)
[ 0.182133] PCI: not using MMCONFIG
[ 0.182136] PCI: Using configuration type 1 for base access
[ 0.182722] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.187720] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.189622] ACPI: Added _OSI(Module Device)
[ 0.189625] ACPI: Added _OSI(Processor Device)
[ 0.189627] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.189629] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.189632] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.189634] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.189636] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.231626] ACPI: 9 ACPI AML tables successfully acquired and loaded
[ 0.238479] ACPI: Dynamic OEM Table Load:
[ 0.238498] ACPI: SSDT 0xFFFF8C93BA834000 0006B8 (v01 PmRef Cpu0Ist 00003000 INTL 20130117)
[ 0.242126] ACPI: Dynamic OEM Table Load:
[ 0.242142] ACPI: SSDT 0xFFFF8C93BB016000 0006BC (v01 PmRef Cpu0Cst 00003001 INTL 20130117)
[ 0.246229] ACPI: Dynamic OEM Table Load:
[ 0.246242] ACPI: SSDT 0xFFFF8C93BA896C00 00015F (v01 PmRef ApIst 00003000 INTL 20130117)
[ 0.248810] ACPI: Dynamic OEM Table Load:
[ 0.248823] ACPI: SSDT 0xFFFF8C93BA9D5300 00008D (v01 PmRef ApCst 00003000 INTL 20130117)
[ 0.252290] ACPI: EC: EC started
[ 0.252293] ACPI: EC: interrupt blocked
[ 0.253904] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[ 0.253909] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.253913] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[ 0.253914] ACPI: Interpreter enabled
[ 0.253983] ACPI: (supports S0 S3 S4 S5)
[ 0.253986] ACPI: Using IOAPIC for interrupt routing
[ 0.254106] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xe0000000-0xe3ffffff] (base 0xe0000000)
[ 0.258078] PCI: MMCONFIG at [mem 0xe0000000-0xe3ffffff] reserved in ACPI motherboard resources
[ 0.258106] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.259377] ACPI: Enabled 8 GPEs in block 00 to 3F
[ 0.263716] ACPI: Power Resource [USBC] (on)
[ 0.273282] ACPI: Power Resource [CLK0] (on)
[ 0.290293] ACPI: Power Resource [CLK0] (on)
[ 0.290420] ACPI: Power Resource [CLK1] (on)
[ 0.298610] ACPI: Power Resource [ID3C] (off)
[ 0.309818] ACPI: Power Resource [FN00] (off)
[ 0.311726] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.311743] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 0.311927] acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM
[ 0.311966] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.313239] PCI host bridge to bus 0000:00
[ 0.313246] pci_bus 0000:00: root bus resource [io 0x0070-0x0077]
[ 0.313250] pci_bus 0000:00: root bus resource [io 0x0000-0x006f window]
[ 0.313253] pci_bus 0000:00: root bus resource [io 0x0078-0x0cf7 window]
[ 0.313256] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.313260] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.313263] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.313266] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[ 0.313269] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.313273] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.313299] pci 0000:00:00.0: [8086:2280] type 00 class 0x060000
[ 0.313750] pci 0000:00:02.0: [8086:22b1] type 00 class 0x030000
[ 0.313779] pci 0000:00:02.0: reg 0x10: [mem 0x90000000-0x90ffffff 64bit]
[ 0.313794] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
[ 0.313805] pci 0000:00:02.0: reg 0x20: [io 0x3000-0x303f]
[ 0.313839] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.314171] pci 0000:00:0b.0: [8086:22dc] type 00 class 0x118000
[ 0.314199] pci 0000:00:0b.0: reg 0x10: [mem 0x91414000-0x91414fff 64bit]
[ 0.314586] pci 0000:00:13.0: [8086:22a3] type 00 class 0x010601
[ 0.314655] pci 0000:00:13.0: reg 0x20: [io 0x3060-0x307f]
[ 0.314668] pci 0000:00:13.0: reg 0x24: [mem 0x91415000-0x914157ff]
[ 0.314740] pci 0000:00:13.0: PME# supported from D3hot
[ 0.315121] pci 0000:00:14.0: [8086:22b5] type 00 class 0x0c0330
[ 0.315156] pci 0000:00:14.0: reg 0x10: [mem 0x91400000-0x9140ffff 64bit]
[ 0.315267] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.315627] pci 0000:00:1a.0: [8086:2298] type 00 class 0x108000
[ 0.315656] pci 0000:00:1a.0: reg 0x10: [mem 0x91300000-0x913fffff]
[ 0.315670] pci 0000:00:1a.0: reg 0x14: [mem 0x91200000-0x912fffff]
[ 0.315772] pci 0000:00:1a.0: PME# supported from D0 D3hot
[ 0.316077] pci 0000:00:1b.0: [8086:2284] type 00 class 0x040300
[ 0.316116] pci 0000:00:1b.0: reg 0x10: [mem 0x91410000-0x91413fff 64bit]
[ 0.316228] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.316540] pci 0000:00:1c.0: [8086:22c8] type 01 class 0x060400
[ 0.316687] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.317012] pci 0000:00:1c.2: [8086:22cc] type 01 class 0x060400
[ 0.317158] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.317484] pci 0000:00:1c.3: [8086:22ce] type 01 class 0x060400
[ 0.317628] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.317982] pci 0000:00:1f.0: [8086:229c] type 00 class 0x060100
[ 0.318421] pci 0000:00:1f.3: [8086:2292] type 00 class 0x0c0500
[ 0.318492] pci 0000:00:1f.3: reg 0x10: [mem 0x91416000-0x9141601f]
[ 0.318609] pci 0000:00:1f.3: reg 0x20: [io 0x3040-0x305f]
[ 0.319187] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.319343] pci 0000:02:00.0: [10ec:d723] type 00 class 0x028000
[ 0.319401] pci 0000:02:00.0: reg 0x10: [io 0x2000-0x20ff]
[ 0.319453] pci 0000:02:00.0: reg 0x18: [mem 0x91100000-0x9110ffff 64bit]
[ 0.319676] pci 0000:02:00.0: supports D1 D2
[ 0.319680] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.319982] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.319989] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff]
[ 0.319996] pci 0000:00:1c.2: bridge window [mem 0x91100000-0x911fffff]
[ 0.320144] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.320188] pci 0000:03:00.0: reg 0x10: [io 0x1000-0x10ff]
[ 0.320228] pci 0000:03:00.0: reg 0x18: [mem 0x91004000-0x91004fff 64bit]
[ 0.320253] pci 0000:03:00.0: reg 0x20: [mem 0x91000000-0x91003fff 64bit]
[ 0.320409] pci 0000:03:00.0: supports D1 D2
[ 0.320412] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.320668] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.320675] pci 0000:00:1c.3: bridge window [io 0x1000-0x1fff]
[ 0.320681] pci 0000:00:1c.3: bridge window [mem 0x91000000-0x910fffff]
[ 0.329064] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *7
[ 0.329361] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.329649] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *7
[ 0.329934] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.330225] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.330511] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.330795] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.331079] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.333237] ACPI: EC: interrupt unblocked
[ 0.333267] ACPI: EC: event unblocked
[ 0.333281] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.333285] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions and events
[ 0.333623] iommu: Default domain type: Translated
[ 0.333886] SCSI subsystem initialized
[ 0.333964] libata version 3.00 loaded.
[ 0.333964] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.333964] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.333964] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.333964] vgaarb: loaded
[ 0.333964] ACPI: bus type USB registered
[ 0.333964] usbcore: registered new interface driver usbfs
[ 0.333964] usbcore: registered new interface driver hub
[ 0.333964] usbcore: registered new device driver usb
[ 0.333964] pps_core: LinuxPPS API ver. 1 registered
[ 0.333964] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.333964] PTP clock support registered
[ 0.333964] EDAC MC: Ver: 3.0.0
[ 0.333964] Registered efivars operations
[ 0.333964] PCI: Using ACPI for IRQ routing
[ 0.337956] PCI: pci_cache_line_size set to 64 bytes
[ 0.338038] e820: reserve RAM buffer [mem 0x0006f000-0x0006ffff]
[ 0.338042] e820: reserve RAM buffer [mem 0x742f4018-0x77ffffff]
[ 0.338044] e820: reserve RAM buffer [mem 0x78857000-0x7bffffff]
[ 0.338046] e820: reserve RAM buffer [mem 0x7a40f000-0x7bffffff]
[ 0.338322] NetLabel: Initializing
[ 0.338325] NetLabel: domain hash size = 128
[ 0.338326] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.338361] NetLabel: unlabeled traffic allowed by default
[ 0.339396] clocksource: Switched to clocksource tsc-early
[ 0.372237] *** VALIDATE bpf ***
[ 0.372422] VFS: Disk quotas dquot_6.6.0
[ 0.372464] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.372527] *** VALIDATE ramfs ***
[ 0.372538] *** VALIDATE hugetlbfs ***
[ 0.372769] AppArmor: AppArmor Filesystem Enabled
[ 0.372863] pnp: PnP ACPI init
[ 0.373117] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.373122] system 00:00: [io 0x0400-0x047f] has been reserved
[ 0.373126] system 00:00: [io 0x0500-0x05fe] has been reserved
[ 0.373140] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.373317] pnp 00:01: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.373477] pnp 00:02: Plug and Play ACPI device, IDs SYN3252 PNP0f13 (active)
[ 0.386120] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.386409] system 00:04: [mem 0xe0000000-0xefffffff] could not be reserved
[ 0.386414] system 00:04: [mem 0xfea00000-0xfeafffff] has been reserved
[ 0.386418] system 00:04: [mem 0xfed01000-0xfed01fff] has been reserved
[ 0.386422] system 00:04: [mem 0xfed03000-0xfed03fff] has been reserved
[ 0.386425] system 00:04: [mem 0xfed06000-0xfed06fff] has been reserved
[ 0.386429] system 00:04: [mem 0xfed08000-0xfed09fff] has been reserved
[ 0.386433] system 00:04: [mem 0xfed80000-0xfedbffff] has been reserved
[ 0.386436] system 00:04: [mem 0xfed1c000-0xfed1cfff] has been reserved
[ 0.386440] system 00:04: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.386452] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.387047] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.388036] pnp: PnP ACPI: found 6 devices
[ 0.393188] thermal_sys: Registered thermal governor 'fair_share'
[ 0.393190] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.393193] thermal_sys: Registered thermal governor 'step_wise'
[ 0.393195] thermal_sys: Registered thermal governor 'user_space'
[ 0.393196] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.397815] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.397919] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 0.397926] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[ 0.397931] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[ 0.397954] pci 0000:00:1c.0: BAR 14: assigned [mem 0x91500000-0x916fffff]
[ 0.397965] pci 0000:00:1c.0: BAR 15: assigned [mem 0x91700000-0x918fffff 64bit pref]
[ 0.397972] pci 0000:00:1c.0: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.397978] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.397985] pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff]
[ 0.397993] pci 0000:00:1c.0: bridge window [mem 0x91500000-0x916fffff]
[ 0.397999] pci 0000:00:1c.0: bridge window [mem 0x91700000-0x918fffff 64bit pref]
[ 0.398009] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.398013] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff]
[ 0.398020] pci 0000:00:1c.2: bridge window [mem 0x91100000-0x911fffff]
[ 0.398032] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.398037] pci 0000:00:1c.3: bridge window [io 0x1000-0x1fff]
[ 0.398044] pci 0000:00:1c.3: bridge window [mem 0x91000000-0x910fffff]
[ 0.398057] pci_bus 0000:00: resource 4 [io 0x0070-0x0077]
[ 0.398060] pci_bus 0000:00: resource 5 [io 0x0000-0x006f window]
[ 0.398063] pci_bus 0000:00: resource 6 [io 0x0078-0x0cf7 window]
[ 0.398066] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.398070] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.398073] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.398076] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000fffff window]
[ 0.398079] pci_bus 0000:00: resource 11 [mem 0x80000000-0xdfffffff window]
[ 0.398082] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ 0.398085] pci_bus 0000:01: resource 1 [mem 0x91500000-0x916fffff]
[ 0.398089] pci_bus 0000:01: resource 2 [mem 0x91700000-0x918fffff 64bit pref]
[ 0.398092] pci_bus 0000:02: resource 0 [io 0x2000-0x2fff]
[ 0.398095] pci_bus 0000:02: resource 1 [mem 0x91100000-0x911fffff]
[ 0.398098] pci_bus 0000:03: resource 0 [io 0x1000-0x1fff]
[ 0.398101] pci_bus 0000:03: resource 1 [mem 0x91000000-0x910fffff]
[ 0.398459] NET: Registered protocol family 2
[ 0.399046] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.399155] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.399438] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.399618] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.399767] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.399832] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.400011] NET: Registered protocol family 1
[ 0.400028] NET: Registered protocol family 44
[ 0.400060] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.402563] PCI: CLS 64 bytes, default 64
[ 0.402724] Trying to unpack rootfs image as initramfs...
[ 1.097399] Freeing initrd memory: 83824K
[ 1.097462] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.097470] software IO TLB: mapped [mem 0x6c1ce000-0x701ce000] (64MB)
[ 1.097658] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x171024fa93b, max_idle_ns: 440795253189 ns
[ 1.097691] clocksource: Switched to clocksource tsc
[ 1.097855] check: Scanning for low memory corruption every 60 seconds
[ 1.098949] Initialise system trusted keyrings
[ 1.098984] Key type blacklist registered
[ 1.099103] workingset: timestamp_bits=36 max_order=20 bucket_order=0
[ 1.102858] zbud: loaded
[ 1.103884] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.104436] fuse: init (API version 7.31)
[ 1.104483] *** VALIDATE fuse ***
[ 1.104487] *** VALIDATE fuse ***
[ 1.104765] Platform Keyring initialized
[ 1.111661] Key type asymmetric registered
[ 1.111664] Asymmetric key parser 'x509' registered
[ 1.111686] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.111792] io scheduler mq-deadline registered
[ 1.113168] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.113324] efifb: probing for efifb
[ 1.113414] efifb: showing boot graphics
[ 1.115566] efifb: framebuffer at 0x80000000, using 4128k, total 4128k
[ 1.115569] efifb: mode is 1366x768x32, linelength=5504, pages=1
[ 1.115570] efifb: scrolling: redraw
[ 1.115573] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.115686] fbcon: Deferring console take-over
[ 1.115689] fb0: EFI VGA frame buffer device
[ 1.115710] intel_idle: MWAIT substates: 0x33000020
[ 1.115712] intel_idle: v0.4.1 model 0x4C
[ 1.116024] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 1.116455] ACPI: AC Adapter [ACAD] (on-line)
[ 1.116614] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0D:00/input/input0
[ 1.116659] ACPI: Lid Switch [LID0]
[ 1.116772] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 1.116870] ACPI: Power Button [PWRB]
[ 1.116961] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.117030] ACPI: Power Button [PWRF]
[ 1.123935] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.123939] ACPI: Thermal Zone [TZ01] (27 C)
[ 1.124265] thermal LNXTHERM:01: registered as thermal_zone1
[ 1.124268] ACPI: Thermal Zone [TZ02] (28 C)
[ 1.125382] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.129762] battery: ACPI: Battery Slot [BAT1] (battery absent)
[ 1.145980] serial8250: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.164215] Linux agpgart interface v0.103
[ 1.200686] loop: module loaded
[ 1.201645] libphy: Fixed MDIO Bus: probed
[ 1.201648] tun: Universal TUN/TAP device driver, 1.6
[ 1.202316] PPP generic driver version 2.4.2
[ 1.204116] VFIO - User Level meta-driver version: 0.3
[ 1.204449] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.204470] ehci-pci: EHCI PCI platform driver
[ 1.204502] ehci-platform: EHCI generic platform driver
[ 1.204533] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.204541] ohci-pci: OHCI PCI platform driver
[ 1.204561] ohci-platform: OHCI generic platform driver
[ 1.204579] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.205049] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.205066] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.206218] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081509810
[ 1.206343] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.206759] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 1.206764] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.206767] usb usb1: Product: xHCI Host Controller
[ 1.206770] usb usb1: Manufacturer: Linux 5.4.0-54-generic xhci-hcd
[ 1.206772] usb usb1: SerialNumber: 0000:00:14.0
[ 1.207830] hub 1-0:1.0: USB hub found
[ 1.207867] hub 1-0:1.0: 7 ports detected
[ 1.209903] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.209913] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.209922] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 1.210037] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 1.210041] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.210044] usb usb2: Product: xHCI Host Controller
[ 1.210047] usb usb2: Manufacturer: Linux 5.4.0-54-generic xhci-hcd
[ 1.210050] usb usb2: SerialNumber: 0000:00:14.0
[ 1.210971] hub 2-0:1.0: USB hub found
[ 1.211006] hub 2-0:1.0: 6 ports detected
[ 1.212923] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.233221] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.233232] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.234742] mousedev: PS/2 mouse device common for all mice
[ 1.237830] rtc_cmos 00:05: RTC can wake from S4
[ 1.238974] rtc_cmos 00:05: registered as rtc0
[ 1.239031] rtc_cmos 00:05: alarms up to one month, y3k, 242 bytes nvram
[ 1.239053] i2c /dev entries driver
[ 1.239200] device-mapper: uevent: version 1.0.3
[ 1.240027] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[ 1.240140] platform eisa.0: Probing EISA bus 0
[ 1.240145] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 1.240149] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 1.240152] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 1.240155] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 1.240158] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 1.240161] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 1.240163] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 1.240166] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 1.240169] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 1.240172] platform eisa.0: EISA: Detected 0 cards
[ 1.240182] intel_pstate: Intel P-state driver initializing
[ 1.241088] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.241095] EFI Variables Facility v0.08 2004-May-17
[ 1.248990] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 1.278002] drop_monitor: Initializing network drop monitor service
[ 1.278352] NET: Registered protocol family 10
[ 1.299940] Segment Routing with IPv6
[ 1.300028] NET: Registered protocol family 17
[ 1.300262] Key type dns_resolver registered
[ 1.300874] RAS: Correctable Errors collector initialized.
[ 1.301133] microcode: sig=0x406c4, pf=0x1, revision=0x411
[ 1.301209] microcode: Microcode Update Driver: v2.2.
[ 1.301217] IPI shorthand broadcast: enabled
[ 1.301233] sched_clock: Marking stable (1298072950, 2453125)->(1317075500, -16549425)
[ 1.301409] registered taskstats version 1
[ 1.301431] Loading compiled-in X.509 certificates
[ 1.305170] Loaded X.509 cert 'Build time autogenerated kernel key: bd334ace607c9c7df3dc03da0f59a188ad749ce1'
[ 1.305249] zswap: loaded using pool lzo/zbud
[ 1.305602] Key type ._fscrypt registered
[ 1.305604] Key type .fscrypt registered
[ 1.324689] Key type big_key registered
[ 1.324701] Key type trusted registered
[ 1.334807] Key type encrypted registered
[ 1.334823] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.336218] integrity: Loading X.509 certificate: UEFI:db
[ 1.336313] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 1.336314] integrity: Loading X.509 certificate: UEFI:db
[ 1.336361] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 1.336362] integrity: Loading X.509 certificate: UEFI:db
[ 1.336405] integrity: Loaded X.509 cert 'Hewlett-Packard Company: HP UEFI Secure Boot 2013 DB key: 1d7cf2c2b92673f69c8ee1ec7063967ab9b62bec'
[ 1.336590] integrity: Loading X.509 certificate: UEFI:MokListRT
[ 1.336677] integrity: Loaded X.509 cert 'SomeOrg: shim: a01ee84e9b37ace407961cc468c5909447878469'
[ 1.336679] integrity: Loading X.509 certificate: UEFI:MokListRT
[ 1.337523] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[ 1.339220] ima: Allocated hash algorithm: sha1
[ 1.377874] ima: No architecture policies found
[ 1.377935] evm: Initialising EVM extended attributes:
[ 1.377938] evm: security.selinux
[ 1.377939] evm: security.SMACK64
[ 1.377940] evm: security.SMACK64EXEC
[ 1.377941] evm: security.SMACK64TRANSMUTE
[ 1.377944] evm: security.SMACK64MMAP
[ 1.377945] evm: security.apparmor
[ 1.377946] evm: security.ima
[ 1.377947] evm: security.capability
[ 1.377949] evm: HMAC attrs: 0x1
[ 1.379217] PM: Magic number: 5:286:570
[ 1.379633] rtc_cmos 00:05: setting system clock to 2021-01-22T06:33:58 UTC (1611297238)
[ 1.389280] Freeing unused decrypted memory: 2040K
[ 1.390933] Freeing unused kernel image memory: 2716K
[ 1.391184] Write protecting the kernel read-only data: 22528k
[ 1.392819] Freeing unused kernel image memory: 2008K
[ 1.393948] Freeing unused kernel image memory: 1188K
[ 1.416841] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.417200] x86/mm: Checking user space page tables
[ 1.439498] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.439505] Run /init as init process
[ 1.549396] usb 1-5: new high-speed USB device number 2 using xhci_hcd
[ 1.698779] usb 1-5: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=88.32
[ 1.698783] usb 1-5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.698786] usb 1-5: Product: USB2.0 Hub
[ 1.699651] hub 1-5:1.0: USB hub found
[ 1.699945] hub 1-5:1.0: 4 ports detected
[ 1.758955] wmi_bus wmi_bus-PNP0C14:00: WQBJ data block query control method not found
[ 1.827471] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[ 1.827545] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 1.837165] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 1.841481] cryptd: max_cpu_qlen set to 1000
[ 1.856043] libphy: r8169: probed
[ 1.856357] r8169 0000:03:00.0 eth0: RTL8168h/8111h, ac:e2:d3:75:b8:7f, XID 541, IRQ 119
[ 1.856360] r8169 0000:03:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 1.857192] ahci 0000:00:13.0: version 3.0
[ 1.857617] ahci 0000:00:13.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 1.857622] ahci 0000:00:13.0: flags: 64bit ncq led clo only pio slum part deso sadm apst
[ 1.868433] scsi host0: ahci
[ 1.873649] scsi host1: ahci
[ 1.873810] ata1: SATA max UDMA/133 abar m2048@0x91415000 port 0x91415100 irq 120
[ 1.873814] ata2: SATA max UDMA/133 abar m2048@0x91415000 port 0x91415180 irq 120
[ 1.892639] SSE version of gcm_enc/dec engaged.
[ 1.919426] r8169 0000:03:00.0 eno1: renamed from eth0
[ 1.971677] checking generic (80000000 408000) vs hw (80000000 10000000)
[ 1.971680] fb0: switching to inteldrmfb from EFI VGA
[ 1.971836] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 1.971955] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.971956] [drm] Driver supports precise vblank timestamp query.
[ 1.974398] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 1.989552] usb 1-5.2: new high-speed USB device number 3 using xhci_hcd
[ 2.012830] [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
[ 2.015216] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 2.018132] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
[ 2.162604] usb 1-5.2: New USB device found, idVendor=0408, idProduct=5220, bcdDevice= 0.09
[ 2.162610] usb 1-5.2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.162614] usb 1-5.2: Product: HP Webcam
[ 2.162618] usb 1-5.2: Manufacturer: Generic
[ 2.162621] usb 1-5.2: SerialNumber: 0x0001
[ 2.187161] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.187229] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.188495] ata1.00: ATA-9: WDC WDS120G2G0A-00JH30, UE510000, max UDMA/133
[ 2.188501] ata1.00: 234455040 sectors, multi 1: LBA48 NCQ (depth 32)
[ 2.193793] ata1.00: configured for UDMA/133
[ 2.194170] scsi 0:0:0:0: Direct-Access ATA WDC WDS120G2G0A- 0000 PQ: 0 ANSI: 5
[ 2.194678] scsi 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.194982] sd 0:0:0:0: [sda] 234455040 512-byte logical blocks: (120 GB/112 GiB)
[ 2.195006] sd 0:0:0:0: [sda] Write Protect is off
[ 2.195010] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.195051] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.213764] fbcon: i915drmfb (fb0) is primary device
[ 2.213766] fbcon: Deferring console take-over
[ 2.213772] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[ 2.227680] sda: sda1 sda2 sda3 sda4
[ 2.228740] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.273396] usb 1-5.3: new full-speed USB device number 4 using xhci_hcd
[ 2.428645] usb 1-5.3: New USB device found, idVendor=0bda, idProduct=b009, bcdDevice= 2.00
[ 2.428650] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.428654] usb 1-5.3: Product: 802.11n WLAN Adapter
[ 2.428658] usb 1-5.3: Manufacturer: Realtek
[ 2.428661] usb 1-5.3: SerialNumber: 00e04c000001
[ 2.669015] psmouse serio1: synaptics: queried max coordinates: x [..5648], y [..4826]
[ 2.700346] psmouse serio1: synaptics: queried min coordinates: x [1292..], y [1026..]
[ 2.700364] psmouse serio1: synaptics: Your touchpad (PNP: SYN3252 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[ 2.762345] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.2, id: 0x1e2b1, caps: 0xf00123/0x840300/0x2e800/0x400000, board id: 3320, fw id: 2548310
[ 2.801785] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input5
[ 2.853745] raid6: sse2x4 gen() 1231 MB/s
[ 2.901633] raid6: sse2x4 xor() 1194 MB/s
[ 2.949574] raid6: sse2x2 gen() 1486 MB/s
[ 2.997531] raid6: sse2x2 xor() 2860 MB/s
[ 3.045535] raid6: sse2x1 gen() 2348 MB/s
[ 3.093514] raid6: sse2x1 xor() 2584 MB/s
[ 3.093515] raid6: using algorithm sse2x1 gen() 2348 MB/s
[ 3.093516] raid6: .... xor() 2584 MB/s, rmw enabled
[ 3.093518] raid6: using ssse3x2 recovery algorithm
[ 3.101454] xor: measuring software checksum speed
[ 3.141512] prefetch64-sse: 9265.000 MB/sec
[ 3.181616] generic_sse: 8162.000 MB/sec
[ 3.181617] xor: using function: prefetch64-sse (9265.000 MB/sec)
[ 3.226238] Btrfs loaded, crc32c=crc32c-intel
[ 3.350817] fbcon: Taking over console
[ 3.885412] Console: switching to colour frame buffer device 170x48
[ 3.934383] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.365469] systemd[1]: Inserted module 'autofs4'
[ 4.405404] usb 1-2: new full-speed USB device number 5 using xhci_hcd
[ 4.490521] systemd[1]: systemd 245.4-4ubuntu3.3 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 4.510052] systemd[1]: Detected architecture x86-64.
[ 4.527456] systemd[1]: Set hostname to <wanoska>.
[ 4.555512] usb 1-2: New USB device found, idVendor=062a, idProduct=4101, bcdDevice= 3.12
[ 4.555516] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.555519] usb 1-2: Product: 2.4G Keyboard Mouse
[ 4.555520] usb 1-2: Manufacturer: MOSART Semi.
[ 4.804572] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[ 4.958796] systemd[1]: Created slice system-modprobe.slice.
[ 4.959972] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.960889] systemd[1]: Created slice User and Session Slice.
[ 4.961109] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.961740] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.961904] systemd[1]: Reached target User and Group Name Lookups.
[ 4.961947] systemd[1]: Reached target Remote File Systems.
[ 4.961980] systemd[1]: Reached target Slices.
[ 4.962233] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.962532] systemd[1]: Listening on LVM2 poll daemon socket.
[ 4.964601] systemd[1]: Listening on Syslog Socket.
[ 4.968662] systemd[1]: Listening on Process Core Dump Socket.
[ 4.968910] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.969082] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.969652] systemd[1]: Listening on Journal Audit Socket.
[ 4.969907] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.970221] systemd[1]: Listening on Journal Socket.
[ 4.970505] systemd[1]: Listening on udev Control Socket.
[ 4.970690] systemd[1]: Listening on udev Kernel Socket.
[ 4.973986] systemd[1]: Mounting Huge Pages File System...
[ 4.977575] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.981275] systemd[1]: Mounting Kernel Debug File System...
[ 4.985038] systemd[1]: Mounting Kernel Trace File System...
[ 4.990871] systemd[1]: Starting Journal Service...
[ 4.996268] systemd[1]: Starting Availability of block devices...
[ 5.000239] systemd[1]: Starting Set the console keyboard layout...
[ 5.006825] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 5.015258] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 5.015426] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 5.017865] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 5.017994] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 5.024557] systemd[1]: Starting Load Kernel Modules...
[ 5.028109] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.034006] systemd[1]: Starting udev Coldplug all Devices...
[ 5.037516] systemd[1]: Starting Uncomplicated firewall...
[ 5.048961] systemd[1]: Mounted Huge Pages File System.
[ 5.049413] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.049773] systemd[1]: Mounted Kernel Debug File System.
[ 5.050070] systemd[1]: Mounted Kernel Trace File System.
[ 5.051729] systemd[1]: Finished Availability of block devices.
[ 5.057171] systemd[1]: Finished Uncomplicated firewall.
[ 5.062786] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 5.102219] usbcore: registered new interface driver usbserial_generic
[ 5.102236] usbserial: USB Serial support registered for generic
[ 5.105381] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[ 5.109681] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 5.113374] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 5.113517] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 5.116494] systemd[1]: Starting Load/Save Random Seed...
[ 5.119758] cp210x: loading out-of-tree module taints kernel.
[ 5.119887] cp210x: module verification failed: signature and/or required key missing - tainting kernel
[ 5.120245] usbcore: registered new interface driver cp210x
[ 5.120270] usbserial: USB Serial support registered for cp210x
[ 5.120844] systemd[1]: Starting Create System Users...
[ 5.169455] systemd[1]: Finished Create System Users.
[ 5.173200] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.179890] lp: driver loaded but no devices found
[ 5.188503] systemd[1]: Finished Load/Save Random Seed.
[ 5.202463] ppdev: user-space parallel port driver
[ 5.211953] systemd[1]: Finished Load Kernel Modules.
[ 5.215589] systemd[1]: Mounting FUSE Control File System...
[ 5.225081] systemd[1]: Mounting Kernel Configuration File System...
[ 5.230774] systemd[1]: Starting Apply Kernel Variables...
[ 5.233095] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 5.248165] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 5.252337] systemd[1]: Starting udev Kernel Device Manager...
[ 5.265780] systemd[1]: Mounted FUSE Control File System.
[ 5.267092] systemd[1]: Mounted Kernel Configuration File System.
[ 5.313891] systemd[1]: Finished Apply Kernel Variables.
[ 5.567337] systemd[1]: Started udev Kernel Device Manager.
[ 5.601829] systemd[1]: Started Journal Service.
[ 5.634444] systemd-journald[302]: Received client request to flush runtime journal.
[ 7.146079] input: HP Wireless hotkeys as /devices/virtual/input/input7
[ 7.685774] proc_thermal 0000:00:0b.0: Creating sysfs group for PROC_THERMAL_PCI
[ 7.955037] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.955534] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.295775] rtw_pci 0000:02:00.0: Firmware version 48.0.0, H2C version 0
[ 8.534300] hidraw: raw HID events driver (C) Jiri Kosina
[ 8.536525] Bluetooth: Core ver 2.22
[ 8.536571] NET: Registered protocol family 31
[ 8.536573] Bluetooth: HCI device and connection manager initialized
[ 8.536580] Bluetooth: HCI socket layer initialized
[ 8.536584] Bluetooth: L2CAP socket layer initialized
[ 8.536593] Bluetooth: SCO socket layer initialized
[ 8.571944] input: HP WMI hotkeys as /devices/virtual/input/input8
[ 8.596130] mc: Linux media interface: v0.10
[ 8.609828] usbcore: registered new interface driver usbhid
[ 8.609831] usbhid: USB HID core driver
[ 8.613141] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 8.617756] usbcore: registered new interface driver btusb
[ 8.630687] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000d lmp_ver=08 lmp_subver=8723
[ 8.630947] videodev: Linux video capture interface: v2.00
[ 8.631361] Bluetooth: hci0: RTL: rom_version status=0 version=2
[ 8.631364] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723d_fw.bin
[ 8.634425] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723d_config.bin
[ 8.635626] Bluetooth: hci0: RTL: cfg_sz 10, total sz 33266
[ 8.676832] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3227: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 8.676838] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 8.676840] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 8.676842] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 8.676844] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 8.676847] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 8.676849] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 8.746561] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 8.746674] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 8.747413] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 8.782762] uvcvideo: Found UVC 1.00 device HP Webcam (0408:5220)
[ 8.786043] uvcvideo 1-5.2:1.0: Entity type for entity Extension 4 was not initialized!
[ 8.786048] uvcvideo 1-5.2:1.0: Entity type for entity Processing 2 was not initialized!
[ 8.786051] uvcvideo 1-5.2:1.0: Entity type for entity Camera 1 was not initialized!
[ 8.786202] input: HP Webcam: HP Webcam as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.2/1-5.2:1.0/input/input12
[ 8.786368] usbcore: registered new interface driver uvcvideo
[ 8.786370] USB Video Class driver (1.1.1)
[ 8.904357] Bluetooth: hci0: RTL: fw version 0x828a96f1
[ 8.914410] Adding 2928636k swap on /dev/sda4. Priority:-2 extents:1 across:2928636k SSFS
[ 9.022506] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 9.195945] intel_rapl_common: Found RAPL domain package
[ 9.195949] intel_rapl_common: Found RAPL domain core
[ 9.198619] audit: type=1400 audit(1611297246.316:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=590 comm="apparmor_parser"
[ 9.211906] audit: type=1400 audit(1611297246.328:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=591 comm="apparmor_parser"
[ 9.245097] audit: type=1400 audit(1611297246.360:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=593 comm="apparmor_parser"
[ 9.280080] audit: type=1400 audit(1611297246.396:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=597 comm="apparmor_parser"
[ 9.280089] audit: type=1400 audit(1611297246.396:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=597 comm="apparmor_parser"
[ 9.280094] audit: type=1400 audit(1611297246.396:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=597 comm="apparmor_parser"
[ 9.292746] audit: type=1400 audit(1611297246.408:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=594 comm="apparmor_parser"
[ 9.292755] audit: type=1400 audit(1611297246.408:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=594 comm="apparmor_parser"
[ 9.292760] audit: type=1400 audit(1611297246.408:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd//third_party" pid=594 comm="apparmor_parser"
[ 9.294789] audit: type=1400 audit(1611297246.412:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=598 comm="apparmor_parser"
[ 11.429730] rtw_pci 0000:02:00.0 wlo1: renamed from wlan0
[ 11.660775] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.660779] Bluetooth: BNEP filters: protocol multicast
[ 11.660788] Bluetooth: BNEP socket layer initialized
[ 11.666736] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:062A:4101.0001/input/input13
[ 11.744005] NET: Registered protocol family 38
[ 11.771612] hid-generic 0003:062A:4101.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-0000:00:14.0-2/input0
[ 11.784933] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:062A:4101.0002/input/input14
[ 11.845713] input: MOSART Semi. 2.4G Keyboard Mouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:062A:4101.0002/input/input15
[ 11.849891] input: MOSART Semi. 2.4G Keyboard Mouse System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:062A:4101.0002/input/input16
[ 11.860733] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:062A:4101.0002/input/input17
[ 11.870799] hid-generic 0003:062A:4101.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-0000:00:14.0-2/input1
[ 12.068898] Generic FE-GE Realtek PHY r8169-300:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
[ 12.186821] r8169 0000:03:00.0 eno1: Link is Down
[ 12.724211] rtw_pci 0000:02:00.0: start vif d4:6a:6a:78:3a:c5 on port 0
[ 14.969272] Bluetooth: RFCOMM TTY layer initialized
[ 14.969285] Bluetooth: RFCOMM socket layer initialized
[ 14.969298] Bluetooth: RFCOMM ver 1.11
[ 19.363452] wlo1: authenticate with d4:21:22:f1:19:0c
[ 19.652391] wlo1: send auth to d4:21:22:f1:19:0c (try 1/3)
[ 19.654658] wlo1: authenticated
[ 19.657065] wlo1: associate with d4:21:22:f1:19:0c (try 1/3)
[ 19.661125] wlo1: RX AssocResp from d4:21:22:f1:19:0c (capab=0x411 status=0 aid=1)
[ 19.661154] rtw_pci 0000:02:00.0: sta d4:21:22:f1:19:0c joined with macid 0
[ 19.661461] wlo1: associated
[ 19.783070] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 22.419695] vboxdrv: Found 2 processor cores
[ 22.449014] vboxdrv: TSC mode is Invariant, tentative frequency 1599934477 Hz
[ 22.449017] vboxdrv: Successfully loaded version 6.1.10_Ubuntu (interface 0x002d0001)
[ 22.539290] VBoxNetFlt: Successfully started.
[ 22.608962] VBoxNetAdp: Successfully started.
[ 50.976254] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 83.230920] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 84.682692] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 85.266700] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 119.415709] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 217.516891] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 285.250263] rtw_pci 0000:02:00.0: sta d4:21:22:f1:19:0c with macid 0 left
[ 292.858742] wlo1: authenticate with d4:21:22:f1:19:0c
[ 293.128830] wlo1: send auth to d4:21:22:f1:19:0c (try 1/3)
[ 293.130305] wlo1: authenticated
[ 293.141981] wlo1: associate with d4:21:22:f1:19:0c (try 1/3)
[ 293.148002] wlo1: RX AssocResp from d4:21:22:f1:19:0c (capab=0x411 status=0 aid=1)
[ 293.148035] rtw_pci 0000:02:00.0: sta d4:21:22:f1:19:0c joined with macid 0
[ 293.148343] wlo1: associated
[ 325.901644] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 390.616657] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 391.836876] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 392.656953] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 463.018217] rtw_pci 0000:02:00.0: failed to send h2c command
[ 491.445006] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 491.976741] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 492.116749] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 590.896758] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 622.239627] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 622.379493] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 623.215481] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 623.355488] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 657.521898] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 658.054055] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 822.403558] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 921.255459] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 921.395272] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 922.227432] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 922.367399] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 922.823529] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 923.327474] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 944.170525] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 944.310567] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 944.782712] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 945.310662] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 945.810234] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 946.310223] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 946.906426] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 950.066011] wlo1: deauthenticating from d4:21:22:f1:19:0c by local choice (Reason: 3=DEAUTH_LEAVING)
[ 950.066378] rtw_pci 0000:02:00.0: sta d4:21:22:f1:19:0c with macid 0 left
[ 950.330730] wlo1: authenticate with e2:62:67:66:0e:96
[ 950.589003] wlo1: send auth to e2:62:67:66:0e:96 (try 1/3)
[ 950.592108] wlo1: authenticated
[ 950.601990] wlo1: associate with e2:62:67:66:0e:96 (try 1/3)
[ 950.609208] wlo1: RX AssocResp from e2:62:67:66:0e:96 (capab=0x411 status=0 aid=1)
[ 950.609245] rtw_pci 0000:02:00.0: sta e2:62:67:66:0e:96 joined with macid 0
[ 950.609577] wlo1: associated
[ 950.670956] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 1062.451970] usb 1-3: new full-speed USB device number 6 using xhci_hcd
[ 1062.633220] usb 1-3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
[ 1062.633239] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1062.633262] usb 1-3: Manufacturer: Silicon Labs
[ 1062.633271] usb 1-3: SerialNumber: 0001
[ 1062.648261] cp210x 1-3:1.0: cp210x converter detected
[ 1062.651661] usb 1-3: cp210x converter now attached to ttyUSB0
[ 1075.983544] rtw_pci 0000:02:00.0: failed to send h2c command
[ 1560.993682] perf: interrupt took too long (2544 > 2500), lowering kernel.perf_event_max_sample_rate to 78500
[ 1613.138027] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 1613.614261] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 1681.975006] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 1682.474515] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 1697.197652] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 1725.460224] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 1762.458596] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 1764.158277] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 1778.501606] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 1779.473600] rtw_pci 0000:02:00.0: timed out to flush queue 1
[ 1786.097524] rtw_pci 0000:02:00.0: firmware failed to restore hardware setting
[ 1936.116479] rtw_pci 0000:02:00.0: firmware failed to restore hardware setting
[ 2061.424101] usb 1-3: USB disconnect, device number 6
[ 2061.424943] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
[ 2061.425088] cp210x 1-3:1.0: device disconnected
[ 2066.758416] usb 1-3: new full-speed USB device number 7 using xhci_hcd
[ 2066.938375] usb 1-3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
[ 2066.938387] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2066.938395] usb 1-3: Product: CP2102 USB to UART Bridge Controller
[ 2066.938402] usb 1-3: Manufacturer: Silicon Labs
[ 2066.938409] usb 1-3: SerialNumber: 0001
[ 2066.950455] cp210x 1-3:1.0: cp210x converter detected
[ 2066.953235] usb 1-3: cp210x converter now attached to ttyUSB0
[ 2137.219254] usb 1-3: USB disconnect, device number 7
[ 2137.220039] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
[ 2137.220171] cp210x 1-3:1.0: device disconnected
[ 2139.988571] usb 1-3: new full-speed USB device number 8 using xhci_hcd
[ 2140.167221] usb 1-3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
[ 2140.167226] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2140.167228] usb 1-3: Product: CP2102 USB to UART Bridge Controller
[ 2140.167231] usb 1-3: Manufacturer: Silicon Labs
[ 2140.167233] usb 1-3: SerialNumber: 0001
[ 2140.176498] cp210x 1-3:1.0: cp210x converter detected
[ 2140.178400] usb 1-3: cp210x converter now attached to ttyUSB0
[ 2150.076748] perf: interrupt took too long (3232 > 3180), lowering kernel.perf_event_max_sample_rate to 61750
[ 2165.952445] rtw_pci 0000:02:00.0: failed to send h2c command
[ 2222.467048] usb 1-3: USB disconnect, device number 8
[ 2222.467932] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
[ 2222.468080] cp210x 1-3:1.0: device disconnected
[ 2225.918346] usb 1-3: new full-speed USB device number 9 using xhci_hcd
[ 2226.099298] usb 1-3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
[ 2226.099317] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2226.099330] usb 1-3: Product: CP2102 USB to UART Bridge Controller
[ 2226.099342] usb 1-3: Manufacturer: Silicon Labs
[ 2226.099351] usb 1-3: SerialNumber: 0001
[ 2226.111954] cp210x 1-3:1.0: cp210x converter detected
[ 2226.114209] usb 1-3: cp210x converter now attached to ttyUSB0
22 янв 2021, 10:15
wanoska, ну драйвер стоит и нормально линкуется :)
добавь себя в группу dialout и всё должно заработать...
wanoska
22 янв 2021, 10:16
WWolf, ользователь «wanoska» уже является членом группы «dialout»
22 янв 2021, 10:18
wanoska, ну тогда проверяй соединение :) самое простое в начале - rx tx замкни и должен получить эхо символов... ну а дальше уже проверять на устройстве
wanoska
22 янв 2021, 10:29
тишина
22 янв 2021, 10:37
у меня правда cp2104 с китайскими вендор и айди, но всё тип топ
wanoska
22 янв 2021, 10:41
:blink2: какая то фигня
22 янв 2021, 10:43
wanoska, а ты точно тот девайс мучаешь? а то у тебя их два ж
wanoska писал(а):
22 янв 2021, 09:58
22 янв 2021, 10:46
22 янв 2021, 10:01
норм тема, а я дурилко вечно драйвер пересобираю :-D
wanoska
22 янв 2021, 10:47
вот тоже вопрос я походу два драйвера влупил
22 янв 2021, 11:09
wanoska писал(а):
22 янв 2021, 10:47
драйвер у них один... а вот устройств у тебя два...
так что надо определиться какой ты открываешь и какой из них по факту не работает - потому что ttyUSB у тебя только для одного создался, для второго должен был появиться ttyUSB1 и так далее...
wanoska
22 янв 2021, 11:11
я когда его вынимаю у меня оба проподают
CP2102 USB TTL нет ответа
22 янв 2021, 11:16
wanoska, эм... а ну кинь норм фотку девайса или лучше ссылку на него... может там хаб стоит и два преобразователя?
и тогда вопрос
wanoska писал(а):
22 янв 2021, 10:07
пробовал не помогло
что именно не помогло?
через echo у меня тоже отказ доступа, а через xed всё чётко заработало
wanoska
Благодарил (а): 40 раз
22 янв 2021, 11:29
wanoska
22 янв 2021, 11:35
22 янв 2021, 11:16
modprobe cp210x
echo 0b00 3070 >/sys/bus/usb-serial/drivers/cp210x/new_id
в new_id не чего не сохраняется после перезагрузки
