Проблема с настройкой кулеров
Krug
Благодарил (а): 2 раза
23 дек 2020, 20:37
Все привет!
Решил что пора бы уже настроить кулеры на своем ноуте и следую инструкции (ссылка) приступил.
После ввода команды
sudo pwmconfig
выдает ошибку:
There are no pwm-capable sensor modules installed
*полный вывод команды:
# pwmconfig version 3.6.0
This program will search your sensors for pulse width modulation (pwm)
controls, and test each one to see if it controls a fan on
your motherboard. Note that many motherboards do not have pwm
circuitry installed, even if your sensor chip supports pwm.
We will attempt to briefly stop each fan using the pwm controls.
The program will attempt to restore each fan to full speed
after testing. However, it is ** very important ** that you
physically verify that the fans have been to full speed
after the program has completed.
/usr/sbin/pwmconfig: There are no pwm-capable sensor modules installed
*о моем ноуте:
Kernel: 5.8.0-33-generic x86_64 bits: 64 compiler: N/A
Desktop: Xfce 4.14.2 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Type: Laptop System: ASUSTeK product: K501UQ v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K501UQ v: 1.0 serial: <filter>
UEFI: American Megatrends v: K501UQ.302 date: 04/18/2019
ID-1: BAT0 charge: 24.6 Wh condition: 24.6/48.3 Wh (51%)
model: ASUSTeK ASUS Battery status: Not charging
Topology: Dual Core model: Intel Core i3-6100U bits: 64 type: MT MCP
arch: Skylake rev: 3 L2 cache: 3072 KiB
bogomips: 18399
Speed: 500 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 500 2: 500
3: 500 4: 500
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
v: kernel bus ID: 00:02.0
Device-2: NVIDIA GM107 [GeForce 940MX] vendor: ASUSTeK driver: nvidia
v: 455.38 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.0.8
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
Sound Server: ALSA v: k5.8.0-33-generic
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 02:00.0
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: d000
bus ID: 03:00.0
Local Storage: total: 465.76 GiB used: 34.52 GiB (7.4%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
temp: 33 C
ID-1: / size: 456.96 GiB used: 34.52 GiB (7.6%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): cpu: 4100
Processes: 220 Uptime: 58m Memory: 7.21 GiB used: 1.70 GiB (23.6%)
inxi: 3.0.38
Ядро обновил , не помогло.
Кто знает решение , пожалуйста подскажите :help:
23 дек 2020, 20:48
sensors ещё покажи
Krug
23 дек 2020, 20:51
Вот
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +39.0°C
pch_skylake-virtual-0
temp1: +39.5°C
BAT0-acpi-0
Adapter: ACPI interface
in0: 11.40 V
asus-isa-0000
Adapter: ISA adapter
cpu_fan: 4100 RPM
temp1: +40.0°C
coretemp-isa-0000
Package id 0: +41.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +40.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +40.0°C (high = +100.0°C, crit = +100.0°C)
acpitz-acpi-0
temp1: +40.0°C (crit = +103.0°C)
23 дек 2020, 21:10
ну скорее всего у тебя вещь в себе неуправляемая извне...
Управление вращением куллера на ноутбуке (Пост wanoska #15193)
там в конце есть статья на хабр, может у тебя выйдет... я после месяца красноглазия забил
Krug
23 дек 2020, 22:29
Благодарю
Попробовал , не получилось
Попробовал еще этот способ , но тоже не получилось
This is where we get the first error that may not be obvious how to fix. What we are trying to do is to automatically have the fan speeds controlled by a sensor temperature. This can be set up using pwmconfig. When I first ran it, I got the error:
This can be fixed by relaxing an acpi check in the kernel (hmm), see https://hydra.geht.net/tino/howto/linux/fixes/w83627hf/ amongst others for more details. The way I fixed this is to edit /etc/default/grub to add acpi_enforce_resources=lax to the GRUB_CMDLINE_LINUX_DEFAULT giving:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_enforce_resources=lax"
Then need to update the boot configuration:
sudo update-grub
and reboot.
(ссылка)
может быть у тебя получится
Я так понимаю эта проблема будет на любом дистрибутиве линукс , а не только на убунту?
