Двойная загрузка компьютера: "Mint 20 Cinnamon" и "Windows 10" после обновления Windows 10.
konstantin
Благодарил (а): 33 раза
20 дек 2020, 15:15
Linux Mint 20 Cinnamon 64-bit -- основная Операционная Система ;
Windows 10 Education 64-bit (версия 1903) ;
Ноутбук ASUS K53SD ;
О компьютере:
bkl@bkl-K53SD:~$ inxi -Fxz
Kernel: 5.4.0-58-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.6.7 Distro: Linux Mint 20 Ulyana
base: Ubuntu 20.04 focal
Type: Laptop System: ASUSTeK product: K53SD v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K53SD v: 1.0 serial: <filter>
BIOS: American Megatrends v: K53SD.205 date: 03/06/2012
ID-1: BAT0 charge: 56.0 Wh condition: 56.3/57.2 Wh (98%)
model: ASUSTek K53--52 status: Unknown
Topology: Dual Core model: Intel Core i3-2310M bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 16762
Speed: 798 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 798 2: 798
3: 798 4: 798
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GF119M [GeForce 610M] vendor: ASUSTeK driver: nvidia
v: 390.138 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1366x768~60Hz, 1440x900~60Hz
OpenGL: renderer: GeForce 610M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.138
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-2: C-Media Audio Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-1.2.4:5
Sound Server: ALSA v: k5.4.0-58-generic
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: AzureWave AW-NB037H 802.11bgn driver: ath9k v: kernel port: d000
bus ID: 03:00.0
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
driver: atl1c v: 1.0.1.1-NAPI port: 9000 bus ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-3: Qualcomm Atheros AR3011 Bluetooth type: USB driver: btusb
bus ID: 1-1.1:5
Local Storage: total: 2.11 TiB used: 372.17 GiB (17.2%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD032 size: 298.09 GiB
ID-2: /dev/sdb type: USB vendor: Toshiba model: External USB 3.0
ID-1: / size: 111.26 GiB used: 48.85 GiB (43.9%) fs: ext4 dev: /dev/sda6
ID-2: swap-1 size: 3.78 GiB used: 9.0 MiB (0.2%) fs: swap dev: /dev/sda5
System Temperatures: cpu: 64.0 C mobo: N/A gpu: nvidia temp: 63 C
Fan Speeds (RPM): cpu: 3100
Processes: 221 Uptime: 56m Memory: 3.62 GiB used: 1.73 GiB (47.7%)
inxi: 3.0.38
bkl@bkl-K53SD:~$
Почему и как исправить : не включается через Grub 2 вторая Операционная Система ?
В компьютере две Операционные Системы: основная Mint 20 Cinnamon и вторая Windows 10. Выбор Операционной Системы при запуске компьютера осуществляется через загрузчик Grub 2. По умолчанию запускается Mint.
После последнего обновления Windows 10 при выборе в меню загрузчика пункта "Windows 10" компьютер выдаёт на чёрном фоне рекомендации использовать установочный диск, но после продолжения "запустить Windows 10" компьютер начинает запускаться полностью заново с начальной заставки фирмы производителя и снова открывается меню Grub 2 -- и так по кругу всякий раз(делал несколько попыток).
Делал обновление загрузчика через терминал вводя команду :
sudo update-grub
Там в завершении обновления в выводе в терминале было "обнаружен загрузчик Windows 10".
Но ничего не изменилось - пункт "Windows 10" заново ведёт компьютер опять до появления меню Grub 2.
Судя по всему загрузчик Windows 10 после обновления оказался перед загрузчиком Grub 2.
Можно ли переустановить Grub 2 находясь в Mint 20 Cinnamon с целью вернуть его на прежнюю позицию впереди загрузчика Windows 10 ?
Последний раз редактировалось пользователем 1 konstantin; всего редактировалось раз: 20
20 дек 2020, 15:25
Ты решил размножать темы черенками?
 ! Сообщение из: symon2014
viewtopic.php?f=7&t=738
20 дек 2020, 16:35
konstantin писал(а):
20 дек 2020, 15:15
Можно
20 дек 2020, 16:39
20 дек 2020, 15:15
Исключительно только по твоему мнению.
20 дек 2020, 16:35
Можно
Только пофигу)
20 дек 2020, 17:10
20 дек 2020, 16:39
Только пофигу)
Какой вопрос - такой ответ на него
20 дек 2020, 17:37
20 дек 2020, 15:15
Это вообще проблема Windows а не загрузчика или линукс. Видимо, при обновлении windows что-то поломалось в ней настолько, что она теперь при загрузке в BSOD падает, а по умолчанию винда при этом падении сразу уходит в перезагрузку, автоматически. Ни к линуксу вообще, ни к загрузчикам в частности, эта проблема отношения не имеет, обратитесь на профильный ресурс.
konstantin
20 дек 2020, 17:59
20 дек 2020, 17:37
20 дек 2020, 15:15
Спасибо за пояснение. Вы имеете ввиду какой именно профильный ресурс в вашем ответе ?
20 дек 2020, 18:03
20 дек 2020, 17:59
Виндовый
konstantin
26 дек 2020, 20:58
Решил вопрос восстановлением логического диска С: , на котором "Windows 10" . С помощью резервной копии , сделанной всего недели три назад специальной программой. Имелся и диск аварийной загрузки, который делается заранее той же программой резервного копирования. А на профильном ресурсе Microsoft Community направили на другой профильный ресурс для профессионалов компьютерщиков, где я просто посмотрел похожие темы. Но именно ответы на нашем ресурсе являются полными и содержат все стороны решённой проблемы.
Итог такой : если Windows не запускается никак по причине вызванной обновлением или вирусной программой, то только восстановление с помощью диска (или флэшки) восстановления решает проблему. В моём случае логотип Windows 10 всё же мелькал на дисплее.
СПАСИБО всем, кто участвовал в обсуждении и делился ответом!
