Kernel: 5.4.0-54-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.6.7 Distro: Linux Mint 20 Ulyana
base: Ubuntu 20.04 focal
Type: Desktop Mobo: BIOSTAR model: A320MH serial: <filter>
UEFI: American Megatrends v: 5.14 date: 09/25/2019
Topology: Quad Core model: AMD A8-9600 RADEON R7 10 COMPUTE CORES 4C+6G
bits: 64 type: MCP arch: Excavator rev: 1 L2 cache: 1024 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 24754
Speed: 1776 MHz min/max: 1400/3100 MHz Core speeds (MHz): 1: 2615 2: 1721
3: 2819 4: 1762
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics]
vendor: Biostar Microtech Intl Corp driver: amdgpu v: kernel
bus ID: 00:01.0
Display: x11 server: X.Org 1.20.8 driver: amdgpu,ati
unloaded: fbdev,modesetting,vesa resolution: 1680x1050~60Hz
OpenGL: renderer: AMD CARRIZO (DRM 3.35.0 5.4.0-54-generic LLVM 10.0.0)
v: 4.6 Mesa 20.0.8 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio driver: snd_hda_intel v: kernel
bus ID: 00:01.1
Device-2: AMD Family 15h Audio vendor: Biostar Microtech Intl Corp
driver: snd_hda_intel v: kernel bus ID: 00:09.2
Sound Server: ALSA v: k5.4.0-54-generic
vendor: Biostar Microtech Intl Corp driver: r8169 v: kernel port: e000
bus ID: 03:00.0
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus ID: 4-9.2:4
IF: wlxd037450594fc state: up mac: <filter>
Local Storage: total: 223.57 GiB used: 21.28 GiB (9.5%)
ID-1: /dev/sda vendor: Apacer model: AS350 240GB size: 223.57 GiB
temp: 33 C
ID-1: / size: 39.12 GiB used: 21.25 GiB (54.3%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 29.1 C mobo: N/A gpu: amdgpu temp: 29 C
Processes: 238 Uptime: 49m Memory: 6.74 GiB used: 1.87 GiB (27.7%)
inxi: 3.0.38
bogomips: 24754
3: 2819 4: 1762
bus ID: 00:01.0
bus ID: 00:01.1
bus ID: 03:00.0
temp: 33 C
inxi: 3.0.38
Не удалось соединиться с archive.ubuntu.com:80 (91.189.88.142): время ожидания для соединения истекло
Полный вывод команды sudo apt-get update :
Сущ:1 http://dl.google.com/linux/chrome/deb stable InRelease
Игн:2 http://packages.linuxmint.com ulyana InRelease
Сущ:3 http://packages.linuxmint.com ulyana Release
Ошб:5 http://archive.ubuntu.com/ubuntu focal InRelease
Невозможно инициализировать соединение с archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Невозможно инициализировать соединение с archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Не удалось соединиться с archive.ubuntu.com:80 (91.189.88.152): время ожидания для соединения истекло Не удалось соединиться с archive.ubuntu.com:80 (91.189.88.142): время ожидания для соединения истекло
Ошб:6 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Ошб:7 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Ошб:8 http://archive.canonical.com/ubuntu focal InRelease
Невозможно инициализировать соединение с archive.canonical.com:80 (2001:67c:1360:8c01::16). - connect (101: Network is unreachable) Невозможно инициализировать соединение с archive.canonical.com:80 (2001:67c:1562::1c). - connect (101: Network is unreachable) Невозможно инициализировать соединение с archive.canonical.com:80 (2001:67c:1360:8c01::1b). - connect (101: Network is unreachable) Не удалось соединиться с archive.canonical.com:80 (91.189.91.15): время ожидания для соединения истекло Не удалось соединиться с archive.canonical.com:80 (91.189.92.150): время ожидания для соединения истекло Не удалось соединиться с archive.canonical.com:80 (91.189.92.191): время ожидания для соединения истекло
Ошб:9 http://security.ubuntu.com/ubuntu focal-security InRelease
Невозможно инициализировать соединение с security.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Невозможно инициализировать соединение с security.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Невозможно инициализировать соединение с security.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Невозможно инициализировать соединение с security.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Не удалось соединиться с security.ubuntu.com:80 (91.189.91.38): время ожидания для соединения истекло Не удалось соединиться с security.ubuntu.com:80 (91.189.88.142): время ожидания для соединения истекло Не удалось соединиться с security.ubuntu.com:80 (91.189.88.152): время ожидания для соединения истекло Не удалось соединиться с security.ubuntu.com:80 (91.189.91.39): время ожидания для соединения истекло
W: Не удалось получить http://archive.ubuntu.com/ubuntu/dists/focal/InRelease Невозможно инициализировать соединение с archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Невозможно инициализировать соединение с archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Не удалось соединиться с archive.ubuntu.com:80 (91.189.88.152): время ожидания для соединения истекло Не удалось соединиться с archive.ubuntu.com:80 (91.189.88.142): время ожидания для соединения истекло
W: Не удалось получить http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease Невозможно инициализировать соединение с archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Невозможно инициализировать соединение с archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable)
W: Не удалось получить http://archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease Невозможно инициализировать соединение с archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Невозможно инициализировать соединение с archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable)
W: Не удалось получить http://security.ubuntu.com/ubuntu/dists/focal-security/InRelease Невозможно инициализировать соединение с security.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Невозможно инициализировать соединение с security.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Невозможно инициализировать соединение с security.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Невозможно инициализировать соединение с security.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Не удалось соединиться с security.ubuntu.com:80 (91.189.91.38): время ожидания для соединения истекло Не удалось соединиться с security.ubuntu.com:80 (91.189.88.142): время ожидания для соединения истекло Не удалось соединиться с security.ubuntu.com:80 (91.189.88.152): время ожидания для соединения истекло Не удалось соединиться с security.ubuntu.com:80 (91.189.91.39): время ожидания для соединения истекло
W: Не удалось получить http://archive.canonical.com/ubuntu/dists/focal/InRelease Невозможно инициализировать соединение с archive.canonical.com:80 (2001:67c:1360:8c01::16). - connect (101: Network is unreachable) Невозможно инициализировать соединение с archive.canonical.com:80 (2001:67c:1562::1c). - connect (101: Network is unreachable) Невозможно инициализировать соединение с archive.canonical.com:80 (2001:67c:1360:8c01::1b). - connect (101: Network is unreachable) Не удалось соединиться с archive.canonical.com:80 (91.189.91.15): время ожидания для соединения истекло Не удалось соединиться с archive.canonical.com:80 (91.189.92.150): время ожидания для соединения истекло Не удалось соединиться с archive.canonical.com:80 (91.189.92.191): время ожидания для соединения истекло
W: Некоторые индексные файлы скачать не удалось. Они были проигнорированы, или вместо них были использованы старые версии.
