Виснет Linux Mint
Loki77
Виснет Linux Mint
13 дек 2020, 19:15
Установил Linux Mint Cinnamon 20 х64. При просмотре контента в интернете система начинает виснуть.
Железо
  Kernel: 5.4.0-58-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: Cinnamon 4.6.7 Distro: Linux Mint 20 Ulyana
  base: Ubuntu 20.04 focal
  Message: No machine data: try newer kernel. Is dmidecode installed? Try -M
  --dmidecode.
  Topology: Quad Core model: AMD A10-5750M APU with Radeon HD Graphics
  bits: 64 type: MCP arch: Piledriver rev: 1 L2 cache: 2048 KiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 19961
  Speed: 1391 MHz min/max: 1400/2500 MHz Core speeds (MHz): 1: 1483 2: 1491
  3: 1311 4: 1349
  Device-1: AMD Richland [Radeon HD 8650G] vendor: Lenovo driver: radeon
  v: kernel bus ID: 00:01.0
  Device-2: AMD Sun PRO [Radeon HD 8570A/8570M] vendor: Lenovo
  driver: radeon v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.8 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.4.0-58-generic LLVM 10.0.0)
  v: 4.3 Mesa 20.0.8 direct render: Yes
  Device-1: AMD Trinity HDMI Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus ID: 00:01.1
  Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
  bus ID: 00:14.2
  Sound Server: ALSA v: k5.4.0-58-generic
  Device-1: Qualcomm Atheros QCA8172 Fast Ethernet vendor: Lenovo
  driver: alx v: kernel port: 2000 bus ID: 02:00.0
  Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lenovo
  driver: ath9k v: kernel port: 2000 bus ID: 03:00.0
  Device-3: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
  bus ID: 3-3:3
  Local Storage: total: 469.50 GiB used: 20.07 GiB (4.3%)
  ID-1: /dev/sda vendor: Western Digital model: WD5000LPLX-22ZNTT0
  ID-2: /dev/sdb type: USB vendor: Verbatim model: STORE N GO size: 3.73 GiB
  ID-1: / size: 455.29 GiB used: 8.76 GiB (1.9%) fs: ext4 dev: /dev/dm-1
  ID-2: /boot size: 704.5 MiB used: 204.8 MiB (29.1%) fs: ext4
  dev: /dev/sda2
  ID-3: swap-1 size: 980.0 MiB used: 518.2 MiB (52.9%) fs: swap
  dev: /dev/dm-2
  System Temperatures: cpu: 43.5 C mobo: N/A
  GPU: device: radeon temp: 46 C device: radeon temp: 43 C
  Processes: 223 Uptime: 39m Memory: 1.65 GiB used: 1.14 GiB (69.1%)
  inxi: 3.0.38
Виснет Linux Mint
13 дек 2020, 19:24
Loki77 писал(а):
13 дек 2020, 19:15
Loki77 писал(а):
13 дек 2020, 19:15
Loki77 писал(а):
13 дек 2020, 19:15
Шибко бюджетнй ноут ноунейм с 2 гигами памяти. Или памяти добавить или систему полегче. Лучше добавить памяти , браузеры сейчас прожорливые.
Виснет Linux Mint
13 дек 2020, 19:40
13 дек 2020, 19:24
Судя по тому что виснет у ТС именно в интернете - это единственный вариант. Т.к. аппетит броузера от системы особо не зависит...
Loki77
Виснет Linux Mint
13 дек 2020, 19:42
13 дек 2020, 19:24
Loki77 писал(а):
13 дек 2020, 19:15
Loki77 писал(а):
13 дек 2020, 19:15
Loki77 писал(а):
13 дек 2020, 19:15
Под добавление памяти вы подразумеваете замену оперативной памяти на более мощную? Так же итересует какие системы есть полегче чем Linux Mint
Виснет Linux Mint
13 дек 2020, 19:43
Loki77 писал(а):
13 дек 2020, 19:42
Увеличить кол-во оперативной памяти
Loki77 писал(а):
13 дек 2020, 19:42
Тебе это не поможет, т.к. браузерам и сайтам современным нужны тонны ОЗУ
Виснет Linux Mint
13 дек 2020, 19:54
Loki77 писал(а):
13 дек 2020, 19:42
Не мощную, а объемную. Чтобы хотя бы минимально иметь что-то удобоваримое для интернета, сейчас требуется минимум 2 гигабайта памяти на борту. И то, это медленно и печально, с постоянными лазаниями в своп по любому поводу. Фейсбук, например, на такой машине все равно вешает систему если смотреть его ленту далеко назад - их макаки так наговнокодили, что память обратно не отдается пропавшими из вида сообщениями, только отжирается новая для более старых на которые страница скроллится. На пике наблюдал отожранные 4 гига. С трудом объяснил человеку, что с машиной все нормально - просто у кого-то руки растут оттуда, что и говорить то стыдно, даже в обществе где на мат лишь косятся. :)
Хотите комфорта в интернете - 4 гигабайта ОЗУ это необходимость уже...
Loki77 писал(а):
13 дек 2020, 19:42
antiX - https://antixlinux.com/download/
Но с интернетом не поможет. Тут сам броузер (точнее страницы сайтов) память хотят.
Loki77
Виснет Linux Mint
13 дек 2020, 20:00
Благодарю всех за ответы
Виснет Linux Mint
29 мар 2021, 22:51
Для десктопчика домашнего 8 гиг лучше тем более если с корицей. Там двойной аэродром.
