Загрузочная флеха кердык
Tiborium
05 дек 2020, 17:18
Система
Kernel: 5.4.0-56-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Xfce 4.14.2 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Type: Laptop System: LENOVO product: 80E3 v: Lenovo G50-45
serial: <filter>
Mobo: LENOVO model: Lancer 5B2 v: SDK0F82990 WIN serial: <filter>
UEFI: LENOVO v: A2CN24WW(V1.06) date: 07/09/2014
ID-1: BAT1 charge: 13.7 Wh condition: 13.7/28.5 Wh (48%)
model: LENOVO PABAS0241231 status: Full
Topology: Dual Core model: AMD E1-6010 APU with AMD Radeon R2 Graphics
bits: 64 type: MCP arch: Puma rev: 1 L2 cache: 1024 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 5389
Speed: 1347 MHz min/max: 1000/1350 MHz Core speeds (MHz): 1: 1347 2: 1347
Device-1: AMD Mullins [Radeon R2 Graphics] vendor: Lenovo driver: radeon
v: kernel bus ID: 00:01.0
Display: x11 server: X.Org 1.20.8 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.4.0-56-generic LLVM 10.0.0)
v: 4.5 Mesa 20.0.8 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:01.1
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:14.2
Sound Server: ALSA v: k5.4.0-56-generic
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Lenovo Z50-75 driver: rtl8723be v: kernel port: 3000
bus ID: 01:00.0
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 02:00.0
Local Storage: total: 169.48 GiB used: 107.92 GiB (63.7%)
ID-1: /dev/sda vendor: Ricoh model: R5SL120G size: 111.79 GiB
ID-2: /dev/sdc type: USB model: Wilk USB DISK 3.0 size: 57.69 GiB
ID-1: / size: 109.04 GiB used: 53.95 GiB (49.5%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 56.5 C mobo: N/A gpu: radeon temp: 57 C
Processes: 207 Uptime: 1h 56m Memory: 1.66 GiB used: 946.3 MiB (55.8%)
inxi: 3.0.38
Суть вопроса.
У меня белиберда в системе и на флешке.
В файловом менеджере устройств показывает 2 лишних устройства+ флешка, из них одно вместе со флешкой появляется. (под рутом их вообще 6)
При форматировании и записи на флешку чего либо, после отсоединения флехи повторно изменить что-то нельзя. Права на запись отсутствуют, только чтение. Только форматировать по новой.
Вся это хрень появилась после того, как я дал полазить одному "спецу".Флеху он делал загрузочной, потом я просто её форматнул, думал прокатит, но походу нет. Теперь надо как-то убрать/починить это всё. Кто подскажет, куда копать?
Это без рута
Это под рутом
Это флешка вынута
Решение Tiborium » 11 дек 2020, 06:13
Так, как ни странно я решил проблему. Причём обе сразу. Был косяк в монтировании флехи. Я подредактировал файл /etc/fstab/ убрал все лишние настройки и фантомные устройства, занулил флеху, создал таблицу разделов MBR (msdos - через Gparted) форматнул в W95 FAT32 и перезагрузил комп. Всё... Все устройства левые исчезли, флеха нормально примонтировалась без всяких левых фантомных устройств. В списке устройств в файловом менеджере больше нет лишнего.
05 дек 2020, 17:21
Tiborium, воткни влеху и покажи вывод
sudo fdisk -l
Tiborium
05 дек 2020, 17:23
Диск /dev/sdc: 57,71 GiB, 61945675776 байт, 120987648 секторов
Disk model: USB DISK 3.0
Размер I/O (минимальный/оптимальный): 512 байт / 512 байт
Тип метки диска: dos
Идентификатор диска: 0x8f7e4ad6
Устр-во Загрузочный начало Конец Секторы Размер Идентификатор Тип
/dev/sdc1 2048 120987647 120985600 57,7G c W95 FAT32
05 дек 2020, 17:25
Tiborium, это что за обрезок вывода? Я где-то просил часть вывода? Ты определись тебе нужна помощь или ты сам все делаешь?
05 дек 2020, 17:25
sudo dd if=/dev/zero out=/dev/sdфлешка
Tiborium
05 дек 2020, 17:32
rogoznik, Как бы вот
05 дек 2020, 17:36
Tiborium, чет фигня какая-то. Куда из вывода делись остальные носители компа?(можешь не отвечать :) )
Вот то устройство в выводе - это флешка?
Tiborium
05 дек 2020, 17:44
rogoznik, Так... Я форматнул флеху. Перезапустил систему.
вот теперь выход вот
Диск /dev/sda: 111,81 GiB, 120034123776 байт, 234441648 секторов
Disk model: R5SL120G
Тип метки диска: gpt
Идентификатор диска: 20590D5A-C538-4A7A-910A-594F654E8825
Устр-во начало Конец Секторы Размер Тип
/dev/sda1 2048 1050623 1048576 512M EFI
/dev/sda2 1050624 234440703 233390080 111,3G Файловая система Linux
Диск /dev/sdb: 57,71 GiB, 61945675776 байт, 120987648 секторов
Идентификатор диска: 0x4c4890a7
/dev/sdb1 2048 120987647 120985600 57,7G c W95 FAT32
И ещё... записать что либо на флеху немогу....странно
05 дек 2020, 17:52
Tiborium писал(а):
05 дек 2020, 17:44
Ну теперь хоть нормальный вывод
Tiborium писал(а):
05 дек 2020, 17:44
Я правильно понял что флешка 60 гигов?
Помогло флешке или нет?
Если нет то в терминале выполнить
sudo dd if=/dev/zero of=/dev/sdb bs=1M status=progress
Это уничтожит на флешке все данные, разделы и таблицы разделов. Операция займет время.
По сути приведет флешку к состоянию как только купил. После этого в gparted(или любой другой удобной тебе программе для редактирования разделов) создать раздел на флешке с нужной ФС.
05 дек 2020, 17:57
05 дек 2020, 17:52
count=1 - не займёт времени))
Tiborium
05 дек 2020, 17:58
05 дек 2020, 17:57
уже позно, гигов 30 уже того, осилило
Tiborium
05 дек 2020, 18:00
rogoznik, флеха на 64...ну мы знаем что меньше, просто считает комп по другой системе исчисления) А с Gparted по подробнее, она есть, а чё там как.... я нуб просто)
05 дек 2020, 18:02
Tiborium писал(а):
05 дек 2020, 18:00
Не меньше. Гигабайты - гибибайты.
05 дек 2020, 18:03
Tiborium, https://losst.ru/kak-polzovatsya-gparted
05 дек 2020, 18:02
вот только они совсем не равны :)
05 дек 2020, 18:05
05 дек 2020, 17:57
Но если творится дичь, то лучше занулить весь диск. Потому - count=1 не совсем к месту.
05 дек 2020, 18:06
05 дек 2020, 18:03
Один удав равен 38 попугаям.
Tiborium
05 дек 2020, 18:18
slant, а вот вопрос к знатокам, с флехой вопрос решится, (или нет). Что делать с чехардой в системе.. С устройствами которых нет?
05 дек 2020, 18:19
Tiborium писал(а):
05 дек 2020, 18:18
с какими устройствами? у тебя что-то пропало из компа?
05 дек 2020, 18:20
А для начала с флехой разберитесь. С большой вероятностью - сами пропадут, т.к. это разделы на ней же, скорее всего. (Флешка - как и обычный винчестер может иметь несколько разделов)
Tiborium
05 дек 2020, 18:23
slant, так эти разделы и без втыкания флешки в системе оставались, это нормально?
