Подключение к ноутбуку монитора по HDMI
VA_Makarov
08 ноя 2020, 09:43
Здравствуйте, при подключении к ноутбуку Dell 5587 монитора через HDMI появляется сообщение - "No External dislpay":
Kernel: 5.4.0-52-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: MATE 1.24.0 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Type: Laptop System: Dell product: G5 5587 v: N/A serial: <filter>
Mobo: Dell model: 032G38 v: A00 serial: <filter> UEFI: Dell v: 1.14.0
date: 06/19/2020
ID-1: BAT0 charge: 34.7 Wh condition: 34.7/56.0 Wh (62%)
model: Samsung SDI DELL W7NKD8A status: Full
Topology: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 8192 KiB
bogomips: 36799
Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell driver: N/A
bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
v: 4.6 Mesa 20.3.0-devel (git-b7793e3 2020-11-07 focal-oibaf-ppa)
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.4.0-52-generic
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
v: kernel port: 5000 bus ID: 00:14.3
IF: wlp0s20f3 state: up mac: <filter>
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Dell
driver: alx v: kernel port: 3000 bus ID: 3b:00.0
IF: enp59s0 state: down mac: <filter>
Local Storage: total: 232.89 GiB used: 11.70 GiB (5.0%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO M.2 250GB
ID-1: / size: 106.20 GiB used: 11.69 GiB (11.0%) fs: ext4 dev: /dev/sda3
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 241 Uptime: 14m Memory: 15.33 GiB used: 1.56 GiB (10.2%)
inxi: 3.0.38
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 60.02*+ 60.01 59.97 59.96 59.93 48.02
1680x1050 59.95 59.88
1600x1024 60.17
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 59.97 59.81 59.91
1152x864 60.00
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
dpkg -l | grep nvidia
ii libnvidia-cfg1-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-450 450.80.02-0ubuntu0.20.04.2 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA libcompute package
ii libnvidia-compute-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVIDIA libcompute package
ii libnvidia-decode-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-450:amd64 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii libnvidia-ifr1-450:i386 450.80.02-0ubuntu0.20.04.2 i386 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii nvidia-compute-utils-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA compute utilities
ii nvidia-dkms-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA DKMS package
ii nvidia-driver-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-450 450.80.02-0ubuntu0.20.04.2 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.14 all Tools to enable NVIDIA's Prime
ii nvidia-prime-applet 1.2.3 all An applet for NVIDIA Prime
ii nvidia-settings 440.82-0ubuntu0.20.04.1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18build1 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-450 450.80.02-0ubuntu0.20.04.2 amd64 NVIDIA binary Xorg driver
dpkg- l | grep intel
ii intel-media-va-driver:amd64 20.1.1+dfsg1-1 amd64 VAAPI driver for the Intel GEN8+ Graphics family
ii intel-microcode 3.20200609.0ubuntu0.20.04.2 amd64 Processor microcode firmware for Intel CPUs
ii libdrm-intel1:amd64 2.4.103+git2011061830.fc479e~oibaf~f amd64 Userspace interface to intel-specific kernel DRM services -- runtime
ii libdrm-intel1:i386 2.4.103+git2011061830.fc479e~oibaf~f i386 Userspace interface to intel-specific kernel DRM services -- runtime
ii xserver-xorg-video-intel 2:2.99.917+git20200226-1 amd64 X.Org X server -- Intel i8xx, i9xx display driver
Установил проприетарные драйвера от intel:
sudo add-apt-repository ppa:oibaf/graphics-drivers
sudo apt-get dist-upgrade
sudo apt-get update
Параметры монитора
Очень смущает то, что драйвера якобы не установлены:
Последний раз редактировалось пользователем 1 VA_Makarov; всего редактировалось раз: 8
08 ноя 2020, 12:59
08 ноя 2020, 13:02
VA_Makarov писал(а):
08 ноя 2020, 09:43
Ну его действительно нет. Что-то при установке пошло не так и модуль не собрался или собрался криво.
VA_Makarov
08 ноя 2020, 17:04
Драйвер для nvidia устанавливал несколько раз, вчера 450, сегодня 455 командами:
1. ubuntu-drivers devices
2. sudo ubuntu-drivers autoinstall
3. Ввел пароля для UEFI Secure Boot
4. reboot
5. В окне Perform MOK managment выбрал первый пункт "continue boot".
Что-то не так делаю?
08 ноя 2020, 17:06
08 ноя 2020, 17:04
У тебя secureboot включен, а должен быть выключен :hoho:
VA_Makarov
08 ноя 2020, 18:07
08 ноя 2020, 17:06
Исправил. Не особо помогло:)
nvidia-settings
08 ноя 2020, 18:35
VA_Makarov, а драйвер то переустановил?
VA_Makarov
08 ноя 2020, 19:30
Драйвер конечно переустановил, сообщения о запросе пароля не было.
08 ноя 2020, 19:41
08 ноя 2020, 19:30
дурная манера так отвечать. Покажи inxi -G
VA_Makarov
11 ноя 2020, 10:22
Переустановил ОС, установил драйвер на nvidia 450 (рекомендуемый), перезагрузил, монитор подключенный к ноутбуку заработал без дополнительных настроек.
Вернуться в «Видеокарты»
