Проблемы со звуком
Tiborium
Проблемы со звуком
03 ноя 2020, 11:44
Здравствуйте.
Система
Kernel: 5.4.0-52-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Xfce 4.14.2 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Type: Laptop System: LENOVO product: 80E3 v: Lenovo G50-45
serial: <filter>
Mobo: LENOVO model: Lancer 5B2 v: SDK0F82990 WIN serial: <filter>
UEFI: LENOVO v: A2CN24WW(V1.06) date: 07/09/2014
ID-1: BAT1 charge: 13.7 Wh condition: 13.7/28.5 Wh (48%)
model: LENOVO PABAS0241231 status: Full
Topology: Dual Core model: AMD E1-6010 APU with AMD Radeon R2 Graphics
bits: 64 type: MCP arch: Puma rev: 1 L2 cache: 1024 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 5389
Speed: 1216 MHz min/max: 1000/1350 MHz Core speeds (MHz): 1: 1216 2: 1218
Device-1: AMD Mullins [Radeon R2 Graphics] vendor: Lenovo driver: radeon
v: kernel bus ID: 00:01.0
Display: server: X.Org 1.20.8 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.4.0-52-generic LLVM 10.0.0)
v: 4.5 Mesa 20.0.8 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:01.1
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:14.2
Sound Server: ALSA v: k5.4.0-52-generic
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Lenovo Z50-75 driver: rtl8723be v: kernel port: 3000
bus ID: 01:00.0
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 02:00.0
Local Storage: total: 111.79 GiB used: 74.45 GiB (66.6%)
ID-1: /dev/sda vendor: Ricoh model: R5SL120G size: 111.79 GiB temp: 52 C
ID-1: / size: 109.04 GiB used: 37.22 GiB (34.1%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 52.9 C mobo: N/A gpu: radeon temp: 53 C
Processes: 182 Uptime: 1h 57m Memory: 1.66 GiB used: 841.5 MiB (49.6%)
inxi: 3.0.38
Проблема в том, что при выборе порта в PulseAudio при заходе в систему всегда стоит наушники, а должны стоять динамики. И они не переключаются если я вставляю наушники, или вытаскиваю их. Что делать? куда копать. Хоть я и новичок, я уже пару тройку форумов облазил то, либо находил отдалённо похожее, но не мог применить, либо совсем не то что нужно. Не могу понять, что прописать, где отключить/включить. Подскажите?
Так при входе в систему стоит
А так должно быть
Проблемы со звуком
03 ноя 2020, 20:59
Tiborium писал(а):
03 ноя 2020, 11:44
Подскажите?
Может в самом гнезде переключатель заклинил.
Tiborium
Проблемы со звуком
04 ноя 2020, 09:43
Unborn писал(а):
03 ноя 2020, 20:59
Tiborium писал(а):
03 ноя 2020, 11:44
Подскажите?
Да то что не переключается, ладно. Я это обрисовал не как причину, а как подробности к проблеме.
Необходимо мне понять, как сделать так, чтоб при входе в систему по умолчанию стояли динамики, а не наушники.
Я их в ручную переключаю постоянно при заходе.
sheridan
Решено: 14
Благодарил (а): 901 раз
Проблемы со звуком
04 ноя 2020, 12:16
В Вашем случае не устройство вывода а раздел конфигурации, выставите нужное устройство и перезагрузитесь
Tiborium
Проблемы со звуком
04 ноя 2020, 15:02
sheridan писал(а):
04 ноя 2020, 12:16
Окей, что тут?
Здесь только переключение HDMI (2.1/5.1/7.1).
А ниже вход, выход, и дуплекс.
Ввод только микрофон.
Вывод динамики и наушники.
Дуплекс соединение этих режимов.
Проблемы со звуком
04 ноя 2020, 15:09
Tiborium писал(а):
04 ноя 2020, 15:02
Включить. Дуплекс - это не динамики с наушниками а одновременный ввод-вывод.
Tiborium
Проблемы со звуком
04 ноя 2020, 19:58
04 ноя 2020, 15:09
Tiborium писал(а):
04 ноя 2020, 15:02
Ну выразился не правильно, но суть та же. И я уже делал так. Дуплекс стоит, я перезапускал. Ставил порт динамика перед перезагрузкой, не помогает. Не сохраняется так выбранный порт.
Tiborium
Проблемы со звуком
04 ноя 2020, 20:18
Я походу вроде понял. Так как наушники имеют статус "plugged in" (что с переводчика означает подключено) они ставятся по умолчанию. В свою очередь динамики имеют статус "unavailable" (что с переводчика означает недоступен) так как другое устройство(наушники) имеют высший приоритет по выводу. Хотя и ничего не вставлено в композитный порт, система пишет что что-то есть. Скорее всего там обломанный кусок 3.5 jack'а замыкающий контакты, определяющие 'устройство' в системе. Если в порте ничего нет, то просто накрылось гнездо, и его под замену. Пока буду размышлять в эту сторону если никто не подкинет идей. Тема пока открыта до решение проблемы.
Проблемы со звуком
04 ноя 2020, 20:20
Tiborium, pavucontrol стоит ?
sheridan
Решено: 14
Проблемы со звуком
04 ноя 2020, 20:59
На первых рисунках очень похоже на pavucontrol
Tiborium
Проблемы со звуком
05 ноя 2020, 06:16
sheridan писал(а):
04 ноя 2020, 20:59
Не похоже, это и есть pavucontrol. PulseAudioVolUmeCONTROL
Tiborium
Проблемы со звуком
18 ноя 2020, 19:15
Может быть кто подскажет, как удалить наушники из устройств, чтоб выбора не было, и всегда по умолчанию ставились динамики?
Вернуться в «Xfce»
