Система не видит SD-карточку Linux Mint 18.1 Serena
Sergey_1973
Благодарил (а): 46 раз
22 янв 2017, 14:09
Система не видит SD-карту при включении её в слот.
Где посмотреть и поправить настройки? Что делать чтобы заработало?
System: Host: asus Kernel: 4.4.0-59-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.1) dm: mdm Distro: Linux Mint 18.1 Serena
Machine: System: ASUSTeK (portable) product: E502SA v: 1.0
Mobo: ASUSTeK model: E502SA v: 1.0 Bios: American Megatrends v: E502SA.210 date: 04/13/2016
CPU: Quad core Intel Pentium N3700 (-MCP-) cache: 1024 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 12799
clock speeds: min/max: 480/2400 MHz 1: 2273 MHz 2: 2136 MHz 3: 2342 MHz 4: 2355 MHz
Graphics: Card: Intel Device 22b1 bus-ID: 00:02.0 chip-ID: 8086:22b1
Resolution: 1366x768@60.05hz
GLX Renderer: Mesa DRI Intel HD Graphics (Cherryview)
GLX Version: 3.0 Mesa 11.2.0 Direct Rendering: Yes
Audio: Card Intel Device 2284 driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:2284
Sound: Advanced Linux Sound Architecture v: k4.4.0-59-generic
Network: Card-1: Realtek RTL8723BE PCIe Wireless Network Adapter
driver: rtl8723be port: e000 bus-ID: 02:00.0 chip-ID: 10ec:b723
Card-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.2 chip-ID: 10ec:8136
IF: enp3s0f2 state: down mac: <filter>
Drives: HDD Total Size: 128.0GB (12.2% used)
ID-1: /dev/sda model: TS128GSSD360S size: 128.0GB serial: D067851033
Partition: ID-1: / size: 65G used: 11G (18%) fs: ext4 dev: /dev/sda5
ID-2: swap-1 size: 4.19GB used: 0.00GB (0%) fs: swap dev: /dev/sda4
RAID: System: supported: N/A
No RAID devices: /proc/mdstat, md_mod kernel module present
Unused Devices: none
Sensors: System Temperatures: cpu: 6280.0C mobo: 54.0C
Fan Speeds (in rpm): cpu: 0
Repos: Active apt sources in file: /etc/apt/sources.list.d/official-package-repositories.list
deb http: //mirror.yandex.ru/linuxmint-packages serena main upstream import backport
deb http: //archive.ubuntu.com/ubuntu xenial main restricted universe multiverse
deb http: //archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
deb http: //archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse
deb http: //security.ubuntu.com/ubuntu/ xenial-security main restricted universe multiverse
deb http: //archive.canonical.com/ubuntu/ xenial partner
Info: Processes: 192 Uptime: 33 min Memory: 1052.6/3852.9MB
Init: systemd v: 229 runlevel: 5 default: 2 Gcc sys: 5.4.0
Client: Unknown python2.7 client inxi: 2.2.35
22 янв 2017, 15:27
Покажи lsblk
Sergey_1973
22 янв 2017, 19:55
sergey@asus ~ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 119,2G 0 disk
├─sda1 8:1 0 512M 0 part /boot/efi
├─sda2 8:2 0 16M 0 part
├─sda3 8:3 0 48,8G 0 part
├─sda4 8:4 0 3,9G 0 part [SWAP]
└─sda5 8:5 0 66G 0 part /
mmcblk0 179:0 0 29G 1 disk
└─mmcblk0p1 179:
22 янв 2017, 20:01
Флешка, подозоеваю, на 32Гб?
Sergey_1973
22 янв 2017, 20:03
Да
22 янв 2017, 20:10
ну тогда сложность что весь выхлоп не влез в предыдущем посте,
хотя уже можно наудачу дать mount на /dev/mmcblk0p1 наудачу, зная ФС, и что этот первый раздел является нужным :smile:
Sergey_1973
22 янв 2017, 20:24
Сделал, ничего не подключилось
sergey@asus ~ $ lsblk
├─sda3 8:3 0 48,8G 0 part /media/sergey/30FC9441FC940370
mmcblk0 179:8 0 29G 1 disk
└─mmcblk0p1 179:9 0 29G 1 part
sergey@asus ~ $ mount /dev/mmcblk0p1
mount: can't find /dev/mmcblk0p1 in /etc/fstab
22 янв 2017, 20:40
Sergey_1973, надо бы еще точку монтирования указать, оттого и не дал общую команду.
к примеру
sudo mkdir /mnt/sdcard
sudo chmod 777 /mnt/sdcard
sudo mount /dev/mmcblk0p1 /mnt/sdcard
И то не факт, что без указания ФС сам подцепит
Sergey_1973
22 янв 2017, 20:52
sergey@asus ~ $ sudo mount /dev/mmcblk0p1 /mnt/sdcard
mount: /dev/mmcblk0p1 is write-protected, mounting read-only
mount: /dev/mmcblk0p1: can't read superblock
Sergey_1973
22 янв 2017, 20:52
Файловая система NTFS
Sergey_1973
22 янв 2017, 20:59
Но и с FAT32 то же самое
Sergey_1973
22 янв 2017, 21:06
Проверил в Windows10 (стоит на этом же ноуте как вторая систем) - обе карточки прекрасно автоматически монтируются.
Sergey_1973
22 янв 2017, 21:12
И вот еще:
sergey@asus ~ $
22 янв 2017, 22:06
а почему mnt то? у меня в media как и все нормальные девайсы. Когда подключаешь флешку она определяется в media. /media/ Я там в свое время создал папку usb - /media/usb и монтировал флешки в нее когда игрался в консоли.
sudo mount /dev/sdc /media/usb
А что, файловый менеджер не видит подключенный диск?
22 янв 2017, 22:11
Dja, директорию я привел по своей привычке, она роли не сыграет (FHS тоже не совсем однозначем по этому поводу). Проблема тут именно в ошибке при попытке монтирования, плясать стоит от неё
Sergey_1973
22 янв 2017, 22:44
Мало понял. Напиши комманды: что делать?
Для меня же терминал - чёрное окно - как магия... :blush:
Последний раз редактировалось пользователем 1 Sergey_1973; всего редактировалось раз: 22
Sergey_1973
22 янв 2017, 22:46
Нет разницы между флешкой и SD карточкой? Флешки автоматически монтируются нормально и без проблем.
22 янв 2017, 22:49
Sergey_1973, по идее разницы быть не должно
пробуем
sudo mkdir /media/mmc
sudo mount /dev/mmcblk0 /media/mmc
не получается - пробуем так
sudo mount /dev/mmcblk0p1 /media/mmc
но должно получиться по первому.
Sergey_1973
22 янв 2017, 22:51
А она есть... :write:
Restart1566
22 янв 2017, 22:55
У меня похожая хрень. Быстрее всего, некорректная поддержка картридера.
Приходится через УСБ-картридер с этими картами работать
