Не работает HDMI порт в Linux Mint
albana
09 окт 2020, 12:31
Добрый день. Решил подключить второй монитор к ноутбуку Lenovo Ideapad S340-14IWL с процессором Intel Pentium Gold 5405U. Стоит LM Cinammon x64 последней версии.
System: Kernel: 5.4.0-48-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.6.7 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Machine: Type: Laptop System: LENOVO product: 81N7 v: Lenovo IdeaPad S340-14IWL
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO
v: ALCN28WW(V2.05) date: 11/25/2019
Battery: ID-1: BAT1 charge: 25.6 Wh condition: 51.7/52.5 Wh (98%)
model: 74726570786C6543 374650334338314C status: Charging
CPU: Topology: Dual Core model: Intel Pentium 5405U bits: 64 type: MT MCP arch: Kaby Lake
rev: C L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18399
Speed: 800 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics: Device-1: Intel vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 610 (WHL GT1) v: 4.6 Mesa 20.0.8
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
Sound Server: ALSA v: k5.4.0-48-generic
Network: Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo
driver: ath10k_pci v: kernel port: 3040 bus ID: 02:00.0
Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-10:4
Drives: Local Storage: total: 119.24 GiB used: 114.91 GiB (96.4%)
ID-1: /dev/nvme0n1 vendor: Lenovo O.E.M. model: RPFTJ128PDD2EWX size: 119.24 GiB
Partition: ID-1: / size: 36.42 GiB used: 16.68 GiB (45.8%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /home size: 79.73 GiB used: 49.11 GiB (61.6%) fs: ext4 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 39.0 C mobo: N/A
Info: Processes: 222 Uptime: 33m Memory: 7.50 GiB used: 1.58 GiB (21.1%) Init: systemd
runlevel: 5 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.17 inxi: 3.0.38
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
1920x1080 60.01*+ 60.01 59.97 59.96 59.93
1680x1050 59.95 59.88
1600x1024 60.17
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 59.97 59.81 59.91
1152x864 60.00
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
Как видно xrandr не отображается HDMI порт, есть только DP-1, что это я так и не понял. Разъем под вывод видео только HDMI, других нет. Перелопатил интернет, решения не нашел. Проверил три кабеля, все три рабочие, но с ноутбуком не пашут. Вывод на мониторе правильный, все доступные настройки монитора проверил. Прошу помощи в решении данного вопроса.
09 окт 2020, 12:41
DP-1 - это экран ноутбука. Dispaly Panel. eDP-1 - это тоже оно, но чуток разное по нюансам, обычно настоящая панель или там, или там.
Если xrandr не видит порт вообще - тут IMHO проблема обычно может быть двух видов - либо используемый драйвер не полностью поддерживает устройство, либо порт отключен аппаратно (на самом нотбуке комбинацией с Fn клавишей, или в прошивке BIOS/UEFI опция). Ну, или сгорел.
Если здесь первый вариант, т.к. у вас интел, решить скорее всего не удастся т.к. альтернативных драйверов нету, только попробовать ядро поновее поставить.
Ну а второй - смотрите документацию к ноуту.
albana
09 окт 2020, 16:22
09 окт 2020, 12:41
Спасибо за наводку! В биосе переставил режим с Legacy на UEFI и все заработало.
