Kernel: 5.4.0-48-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Xfce 4.14.2 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Type: Desktop System: Hewlett-Packard product: HP Compaq dc5750 Microtower
v: N/A serial: <filter>
Mobo: Hewlett-Packard model: 0A64h serial: <filter> BIOS: Hewlett-Packard
v: 786E3 v02.10 date: 01/25/2007
Topology: Dual Core model: AMD Athlon 64 X2 3800+ bits: 64 type: MCP
arch: K8 rev.F+ rev: 2 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 svm bogomips: 7979
Speed: 1000 MHz min/max: 1000/2000 MHz Core speeds (MHz): 1: 1000 2: 1000
Device-1: NVIDIA GT215 [GeForce GT 320]
vendor: PC Partner Limited / Sapphire driver: nvidia v: 340.108
bus ID: 02:00.0
Display: x11 server: X.Org 1.20.8 driver: nvidia resolution: 1366x768~60Hz
OpenGL: renderer: GeForce GT 320/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108
Device-1: AMD SBx00 Azalia vendor: Hewlett-Packard DC5750 Microtower
driver: snd_hda_intel v: kernel bus ID: 00:14.2
Device-2: NVIDIA High Definition Audio
vendor: PC Partner Limited / Sapphire driver: snd_hda_intel v: kernel
bus ID: 02:00.1
Sound Server: ALSA v: k5.4.0-48-generic
Device-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
driver: 8139too v: 0.9.28 port: 1100 bus ID: 07:04.0
IF: enp7s4 state: unknown speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom and subsidiaries NetXtreme BCM5755 Gigabit Ethernet PCI
Express
vendor: Hewlett-Packard DC5750 Microtower driver: tg3 v: 3.137 port: 1100
bus ID: 3f:00.0
IF: enp63s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 149.05 GiB used: 20.00 GiB (13.4%)
ID-1: /dev/sda vendor: Hitachi model: HDS721616PLA380 size: 149.05 GiB
ID-1: / size: 50.90 GiB used: 11.57 GiB (22.7%) fs: ext4 dev: /dev/sda6
ID-2: /boot size: 1.85 GiB used: 207.1 MiB (11.0%) fs: ext4 dev: /dev/sda5
ID-3: /home size: 85.67 GiB used: 8.22 GiB (9.6%) fs: ext4 dev: /dev/sda7
ID-4: swap-1 size: 7.63 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 58 C
Processes: 188 Uptime: 6m Memory: 2.92 GiB used: 1.46 GiB (50.1%)
inxi: 3.0.38
bus ID: 02:00.0
bus ID: 02:00.1
Express
bus ID: 3f:00.0
inxi: 3.0.38
