Как изменить цвет фона всплывающих подсказок?
Vlixs
Благодарил (а): 6 раз
22 сен 2020, 10:15
Подскажите пожалуйста, как изменить цвет фона всплывающих подсказок? Выделил на скриншоте
Kernel: 5.4.0-48-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.6.7 Distro: Linux Mint 20 Ulyana
base: Ubuntu 20.04 focal
Type: Laptop System: SAMSUNG product: 355V4C/356V4C/3445VC/3545VC
v: P09AAN.031.CP serial: <filter>
Mobo: SAMSUNG model: NP355V5C-S0ARU v: BOARD REVISION 00 serial: <filter>
UEFI: American Megatrends v: P09AAN date: 07/04/2013
ID-1: BAT1 charge: 42.0 Wh condition: 42.0/48.8 Wh (86%)
model: COMPAL PABAS0241231 status: Full
Topology: Quad Core model: AMD A10-4600M APU with Radeon HD Graphics
bits: 64 type: MCP arch: Piledriver rev: 1 L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 18366
Speed: 1375 MHz min/max: 1400/2300 MHz Core speeds (MHz): 1: 1394 2: 1400
3: 2296 4: 2296
Device-1: AMD Trinity [Radeon HD 7660G] vendor: Samsung Co driver: radeon
v: kernel bus ID: 00:01.0
Device-2: AMD Thames [Radeon HD 7500M/7600M Series] vendor: Samsung Co
driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.4.0-48-generic LLVM 10.0.0)
v: 4.3 Mesa 20.0.8 direct render: Yes
Device-1: AMD Trinity HDMI Audio vendor: Samsung Co driver: snd_hda_intel
v: kernel bus ID: 00:01.1
Device-2: AMD FCH Azalia vendor: Samsung Co driver: snd_hda_intel
v: kernel bus ID: 00:14.2
Sound Server: ALSA v: k5.4.0-48-generic
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: Samsung Co driver: ath9k v: kernel port: e000 bus ID: 03:00.0
Device-2: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
bus ID: 2-4:16
Local Storage: total: 465.76 GiB used: 9.44 GiB (2.0%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
ID-1: / size: 456.96 GiB used: 9.43 GiB (2.1%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 51.2 C mobo: N/A
GPU: device: radeon temp: 40 C device: radeon temp: 49 C
Processes: 225 Uptime: 2h 19m Memory: 7.25 GiB used: 1.15 GiB (15.9%)
inxi: 3.0.38
Решение Vlixs » 23 сен 2020, 07:13
22 сен 2020, 10:29
Vlixs, Ох уж эти рюшечки. Посмотри темы оформления.
Vlixs
22 сен 2020, 10:36
symon2014, меня тема полностью устраивает кроме, вот этих подсказок
22 сен 2020, 11:00
Vlixs, скорее всего никак. Хотя возможно в css-файлах темы можно поискать и поправить цвет, но это если найдешь :crazy:
Vlixs
22 сен 2020, 11:04
rogoznik, полагаю вот это?
22 сен 2020, 11:07
Vlixs, возможно тут. Только сейчас у тебя файл открыт для чтения и не получится сохранить изменения. Ну посоветовал бы папку с темой сделать копию. И название изменить, чтоб было понятно что это твоя кастомная тема. Т.к. при каком-нибудь обновлении твои правки могут затереться
Vlixs
23 сен 2020, 07:13
23 сен 2020, 07:17
Vlixs писал(а):
23 сен 2020, 07:13
Я сделаль)
Теперь со страхом жди обновлений. :-D
Vlixs
23 сен 2020, 07:19
symon2014, это же отдельная тема, почему со страхом?
23 сен 2020, 07:21
Неисповедимы пути мэйнтейнерские. :hoho:
