после обновления с 19.1 до 19.3 отпадает Bluetoch
seregka
Благодарил (а): 2 раза
13 сен 2020, 13:53
Ноутбук Acer v3
System:    Host: Acer Kernel: 5.4.0-47-generic x86_64 bits: 64 compiler: gcc v: 7.5.0
           Desktop: Cinnamon 4.4.8 wm: muffin dm: LightDM Distro: Linux Mint 19.3 Tricia
           base: Ubuntu 18.04 bionic
Machine:   Type: Laptop System: Acer product: Aspire V3-551G v: V1.06 serial: <filter>
           Mobo: Acer model: VA50_CM serial: <filter> UEFI [Legacy]: Acer v: 1.06 date: 09/27/2012
Battery:   ID-1: BAT1 charge: 35.7 Wh condition: 35.7/47.5 Wh (75%) volts: 12.0/10.8
           model: SONY AS10D41 serial: <filter> status: Full
CPU:       Topology: Quad Core model: AMD A8-4500M APU with Radeon HD Graphics bits: 64 type: MCP
           arch: Piledriver rev: 1 L2 cache: 2048 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 15172
           Speed: 1897 MHz min/max: 1400/1900 MHz Core speeds (MHz): 1: 1897 2: 1897 3: 1406
           4: 1447
Graphics:  Device-1: AMD Trinity [Radeon HD 7640G] vendor: Acer Incorporated ALI driver: radeon
           v: kernel bus ID: 00:01.0 chip ID: 1002:9903
           Display: x11 server: X.Org 1.19.6 driver: ati,radeon unloaded: fbdev,modesetting,vesa
           resolution: 1366x768~60Hz
           OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.4.0-47-generic LLVM 10.0.0)
           v: 4.3 Mesa 20.0.8 compat-v: 3.1 direct render: Yes
Audio:     Device-1: AMD Trinity HDMI Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
           v: kernel bus ID: 00:01.1 chip ID: 1002:9902
           Device-2: AMD FCH Azalia vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
           bus ID: 00:14.2 chip ID: 1022:780d
           Sound Server: ALSA v: k5.4.0-47-generic
Network:   Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: Acer Incorporated ALI
           driver: atl1c v: 1.0.1.1-NAPI port: 3000 bus ID: 01:00.0 chip ID: 1969:1083
           Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Lite-On
           driver: ath9k v: kernel port: 3000 bus ID: 02:00.0 chip ID: 168c:0034
Drives:    Local Storage: total: 344.68 GiB used: 74.60 GiB (21.6%)
           ID-1: /dev/sda vendor: Kingston model: SV300S37A120G size: 111.79 GiB speed: 6.0 Gb/s
           serial: <filter>
           ID-2: /dev/sdb vendor: Western Digital model: WD2500LPCX-24C6HT0 size: 232.89 GiB
           speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 38.26 GiB used: 17.97 GiB (47.0%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 224.47 GiB used: 56.63 GiB (25.2%) fs: ext4 dev: /dev/sdb5
           ID-3: swap-1 size: 3.81 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdb1
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0 chip ID: 1d6b:0002
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0 chip ID: 1d6b:0002
           Device-1: 2-1:2 info: Sunplus Innovation type: Video driver: uvcvideo rev: 2.0
           chip ID: 1bcf:2c18
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 chip ID: 1d6b:0001
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 chip ID: 1d6b:0001
           Device-2: 4-4:3 info: Lite-On type: Bluetooth driver: btusb rev: 1.1 chip ID: 04ca:3006
           Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 chip ID: 1d6b:0003
           Hub: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 48.2 C mobo: N/A gpu: radeon temp: 43 C
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/atareao-telegram-bionic.list
           1: deb http: //ppa.launchpad.net/atareao/telegram/ubuntu bionic main
           2: deb-src http: //ppa.launchpad.net/atareao/telegram/ubuntu bionic main
           Active apt repos in: /etc/apt/sources.list.d/danielrichter2007-grub-customizer-bionic.list
           1: deb http: //ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu bionic main
           2: deb-src http: //ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu bionic main
           Active apt repos in: /etc/apt/sources.list.d/google-chrome.list
           1: deb [arch=amd64] http: //dl.google.com/linux/chrome/deb/ stable main
           Active apt repos in: /etc/apt/sources.list.d/kivy-team-kivy-bionic.list
           1: deb http: //ppa.launchpad.net/kivy-team/kivy/ubuntu bionic main
           2: deb-src http: //ppa.launchpad.net/kivy-team/kivy/ubuntu bionic main
           Active apt repos in: /etc/apt/sources.list.d/megasync.list
           1: deb https: //mega.nz/linux/MEGAsync/xUbuntu_18.04/ ./
           Active apt repos in: /etc/apt/sources.list.d/nilarimogard-webupd8-bionic.list
           1: deb http: //ppa.launchpad.net/nilarimogard/webupd8/ubuntu bionic main
           2: deb-src http: //ppa.launchpad.net/nilarimogard/webupd8/ubuntu bionic main
           Active apt repos in: /etc/apt/sources.list.d/noobslab-apps-bionic.list
           1: deb-src http: //ppa.launchpad.net/noobslab/apps/ubuntu bionic main
           1: deb http: //packages.linuxmint.com tricia main upstream import backport #id:linuxmint_main
           2: deb http: //archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
           3: deb http: //archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
           4: deb http: //archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
           5: deb http: //security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
           6: deb http: //archive.canonical.com/ubuntu/ bionic partner
           Active apt repos in: /etc/apt/sources.list.d/opera-stable.list
           1: deb https: //deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
           Active apt repos in: /etc/apt/sources.list.d/skype-stable.list
           1: deb [arch=amd64] https: //repo.skype.com/deb stable main
           Active apt repos in: /etc/apt/sources.list.d/sublime-text.list
           1: deb https: //download.sublimetext.com/ apt/stable/
           Active apt repos in: /etc/apt/sources.list.d/team-xbmc-ppa-bionic.list
           1: deb http: //ppa.launchpad.net/team-xbmc/ppa/ubuntu bionic main
           2: deb-src http: //ppa.launchpad.net/team-xbmc/ppa/ubuntu bionic main
           Active apt repos in: /etc/apt/sources.list.d/windscribe-repo.list
           1: deb https: //repo.windscribe.com/ubuntu zesty main
Info:      Processes: 216 Uptime: 1m Memory: 7.26 GiB used: 970.2 MiB (13.0%) Init: systemd v: 237
           runlevel: 5 Compilers: gcc: 7.5.0 alt: 7 Client: Unknown python3.6 client inxi: 3.0.32
По блютузу подключена мышь немного работает потом коннект пропадат, помогает только выкл-вкл модулю блютуз
вот отчет об ошибке
 Info
           PID: 13933 (bt-adapter)
           UID: 1000 (seregka)
           GID: 1000 (seregka)
        Signal: 6 (ABRT)
     Timestamp: Sun 2020-09-13 11:26:42 +05 (4h 9min ago)
  Command Line: bt-adapter -i
    Executable: /usr/bin/bt-adapter
 Control Group: /user.slice/user-1000.slice/session-c2.scope
          Unit: session-c2.scope
         Slice: user-1000.slice
       Session: c2
     Owner UID: 1000 (seregka)
       Boot ID: 95b41870622a4ebb8b890a0dd9d15e71
    Machine ID: 82929df7ee394b73b81252fe3b4e5020
      Hostname: Acer
       Storage: /var/lib/systemd/coredump/core.bt-adapter.1000.95b41870622a4ebb8b890a0dd9d15e71.13933.1599978402000000.lz4
       Message: Process 13933 (bt-adapter) of user 1000 dumped core.
                Stack trace of thread 13933:
                #0  0x00007efe687a6f47 __GI_raise (libc.so.6)
                #1  0x00007efe687a88b1 __GI_abort (libc.so.6)
                #2  0x00007efe691cb315 g_assertion_message (libglib-2.0.so.0)
                #3  0x00007efe691cb37a g_assertion_message_expr (libglib-2.0.so.0)
                #4  0x0000557d6eaa3eeb n/a (bt-adapter)
                #5  0x0000557d6ea9f719 n/a (bt-adapter)
                #6  0x00007efe68789b97 __libc_start_main (libc.so.6)
                #7  0x0000557d6ea9fd5a n/a (bt-adapter)
                Stack trace of thread 13936:
                #0  0x00007efe6887ccf9 __GI___poll (libc.so.6)
                #1  0x00007efe691a45c9 n/a (libglib-2.0.so.0)
                #2  0x00007efe691a46dc g_main_context_iteration (libglib-2.0.so.0)
                #3  0x00007efe691a4721 n/a (libglib-2.0.so.0)
                #4  0x00007efe691cc175 n/a (libglib-2.0.so.0)
                #5  0x00007efe682d76db start_thread (libpthread.so.0)
                #6  0x00007efe68889a3f __clone (libc.so.6)
                Stack trace of thread 13937:
                #2  0x00007efe691a4962 g_main_loop_run (libglib-2.0.so.0)
                #3  0x00007efe68e87276 n/a (libgio-2.0.so.0)
 GDB Log
[New LWP 13933]
[New LWP 13936]
[New LWP 13937]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `bt-adapter -i'.
Program terminated with signal SIGABRT, Aborted.
#0  __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:51
51	../sysdeps/unix/sysv/linux/raise.c: No such file or directory.
[Current thread is 1 (Thread 0x7efe6966f880 (LWP 13933))]
 GDB Backtrace
[New LWP 13933]
[New LWP 13936]
[New LWP 13937]
#1  0x00007efe687a88b1 in __GI_abort () at abort.c:79
#2  0x00007efe691cb315 in g_assertion_message () from /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#3  0x00007efe691cb37a in g_assertion_message_expr () from /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#4  0x0000557d6eaa3eeb in ?? ()
#5  0x0000557d6ea9f719 in ?? ()
#6  0x00007efe68789b97 in __libc_start_main (main=0x557d6ea9f160, argc=2, argv=0x7ffe83c051a8, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=0x7ffe83c05198) at ../csu/libc-start.c:310
#7  0x0000557d6ea9fd5a in ?? ()
 GDB Backtrace (all threads)
[New LWP 13933]
[New LWP 13936]
[New LWP 13937]
Thread 3 (Thread 0x7efe66186700 (LWP 13937)):
#0  0x00007efe6887ccf9 in __GI___poll (fds=0x557d6f090290, nfds=2, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
        resultvar = 18446744073709551100
        sc_cancel_oldtype = 0
        sc_ret = <optimized out>
#1  0x00007efe691a45c9 in ?? () from /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
No symbol table info available.
#2  0x00007efe691a4962 in g_main_loop_run () from /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#3  0x00007efe68e87276 in ?? () from /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0
#4  0x00007efe691cc175 in ?? () from /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#5  0x00007efe682d76db in start_thread (arg=0x7efe66186700) at pthread_create.c:463
        pd = 0x7efe66186700
        now = <optimized out>
        unwind_buf = {cancel_jmp_buf = {{jmp_buf = {139631099668224, 8408667812057724970, 139631099666048, 0, 93997222039712, 140731108839088, -8553080189381887958, -8553102566862211030}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
        not_first_call = <optimized out>
#6  0x00007efe68889a3f in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
No locals.
Thread 2 (Thread 0x7efe66987700 (LWP 13936)):
#0  0x00007efe6887ccf9 in __GI___poll (fds=0x557d6f0797e0, nfds=1, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
#2  0x00007efe691a46dc in g_main_context_iteration () from /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#3  0x00007efe691a4721 in ?? () from /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#5  0x00007efe682d76db in start_thread (arg=0x7efe66987700) at pthread_create.c:463
        pd = 0x7efe66987700
        unwind_buf = {cancel_jmp_buf = {{jmp_buf = {139631108060928, 8408667812057724970, 139631108058752, 0, 93997222039552, 140731108838704, -8553079090407131094, -8553102566862211030}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
No locals.
Thread 1 (Thread 0x7efe6966f880 (LWP 13933)):
        set = {__val = {0, 93997216018800, 93997216036340, 139631150420031, 93997222166852, 24, 2064, 124, 93997216017760, 140731108839360, 139631143500864, 139631139997768, 569146081280, 2048, 345807781888, 7}}
        pid = <optimized out>
        tid = <optimized out>
        save_stage = 1
        act = {__sigaction_handler = {sa_handler = 0xfed0, sa_sigaction = 0xfed0}, sa_mask = {__val = {139630863211328, 0, 140731108839360, 140728898420737, 8396822946021167360, 72057594037927936, 16777216, 6917529027641081856, 93997372538880, 139630863211328, 0, 0, 8396822946021167360, 93997216017760, 139630863211328, 97}}, sa_flags = 1766252000, sa_restorer = 0x7ffe83c04fc0}
        sigs = {__val = {32, 0 <repeats 15 times>}}
        __cnt = <optimized out>
        __set = <optimized out>
        self = <optimized out>
        __self = <optimized out>
        result = <optimized out>
        unwind_buf = {cancel_jmp_buf = {{jmp_buf = {0, -2428764535550232534, 93997215907120, 140731108839840, 0, 0, -8409186621452830678, -8553102997856962518}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x7efe69480783 <_dl_init+259>, 0x7efe6914d5b8}, data = {prev = 0x0, cleanup = 0x0, canceltype = 1766328195}}}
 ! Сообщение из: symon2014
viewtopic.php?t=738
Будьте добрее к этому миру, даже если мир не добр к вам.
seregka
13 сен 2020, 14:20
lspci -knn | grep Net -A3; rfkill list
02:00.0 Network controller [0280]: Qualcomm Atheros AR9462 Wireless Network Adapter [168c:0034] (rev 01)
	Subsystem: Lite-On Communications Inc AR9462 Wireless Network Adapter [11ad:6621]
	Kernel driver in use: ath9k
	Kernel modules: ath9k
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5209 PCI Express Card Reader [10ec:5209] (rev 01)
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
1: acer-wireless: Wireless LAN
	Soft blocked: no
	Hard blocked: no
2: acer-bluetooth: Bluetooth
	Soft blocked: no
	Hard blocked: no
3: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
Я буду за тебя форматировать? Смотри ссылку постом выше.
