Не обновляется система
JoJocage
30 авг 2020, 23:25
Всем привет!
Заметил, что система давно не выводила в правом нижнем углу экрана уведомление об обновлении того или иного приложения.
Linux Mint 19.3 Cinnamon.
Host: Notebook Kernel: 5.3.0-53-generic i686 bits: 32 compiler: gcc
v: 7.5.0 Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Laptop System: Acer product: Aspire ES1-511 v: V1.03
serial: <filter>
Mobo: Acer model: Aspire ES1-511 v: V1.03 serial: <filter>
UEFI [Legacy]: Acer v: 1.03 date: 05/09/2014
ID-1: BAT1 charge: 50.9 Wh condition: 50.9/53.4 Wh (95%)
model: SANYO PABAS0241231 status: Full
Topology: Dual Core model: Intel Celeron N2830 bits: 64 type: MCP
arch: Silvermont rev: 8 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8666
Speed: 1139 MHz min/max: 500/2416 MHz Core speeds (MHz): 1: 1219 2: 1270
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel Bay Trail x86/MMX/SSE2 v: 4.2 Mesa 19.2.8
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
bus ID: 00:1b.0
Sound Server: ALSA v: k5.3.0-53-generic
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 1000
bus ID: 01:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Foxconn driver: ath9k v: kernel port: 1000 bus ID: 02:00.0
Local Storage: total: 298.09 GiB used: 49.18 GiB (16.5%)
ID-1: /dev/sda vendor: Western Digital model: WD3200BPVT-22JJ5T0
size: 298.09 GiB temp: 35 C
ID-1: / size: 291.43 GiB used: 49.16 GiB (16.9%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 1.89 GiB used: 21.0 MiB (1.1%) fs: swap dev: /dev/sda5
System Temperatures: cpu: 57.0 C mobo: N/A
Processes: 183 Uptime: 1h 19m Memory: 1.79 GiB used: 736.4 MiB (40.3%)
inxi: 3.0.32
sudo apt update
выдаёт
/usr/bin/apt: 17: /usr/bin/apt: Syntax error: EOF in backquote substitution
Что это значит?
30 авг 2020, 23:59
JoJocage писал(а):
30 авг 2020, 23:25
Что это значит?
Синтаксическая ошибка. По крайней мере, так говорят результаты запроса в поисковике.
warning
Решено: 7
Благодарил (а): 161 раз
31 авг 2020, 01:23
покажи
file /usr/bin/apt
hw-probe: тыц!
