Черный экран после чистой уставновки.
Pel'meshka
01 авг 2020, 00:44
Всем привет!
Система LM 20 Uliana Xfce
  Kernel: 5.4.0-26-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: Xfce 4.14.2 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
  Type: Laptop System: LENOVO product: 20255 v: Lenovo G505s
  serial: <filter>
  Mobo: LENOVO model: Lenovo G505s v: 31900004Std serial: <filter>
  UEFI [Legacy]: LENOVO v: 83CN16WW(V1.05) date: 09/18/2013
  ID-1: BAT1 charge: 0 Wh condition: 3.4/37.5 Wh (9%)
  model: SIMPLO PABAS0241231 status: Unknown
  Topology: Quad Core model: AMD A8-4500M APU with Radeon HD Graphics
  bits: 64 type: MCP arch: Piledriver rev: 1 L2 cache: 2048 KiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 15170
  Speed: 1374 MHz min/max: 1400/1900 MHz Core speeds (MHz): 1: 1375 2: 1377
  3: 1369 4: 1367
  Device-1: AMD Trinity [Radeon HD 7640G] vendor: Lenovo driver: radeon
  v: kernel bus ID: 00:01.0
  Device-2: AMD Sun PRO [Radeon HD 8570A/8570M] vendor: Lenovo
  driver: radeon v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.8 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.4.0-26-generic LLVM 9.0.1)
  v: 4.3 Mesa 20.0.4 direct render: Yes
  Device-1: AMD Trinity HDMI Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus ID: 00:01.1
  Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
  bus ID: 00:14.2
  Device-3: C-Media USB Audio Device type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 5-1:3
  Sound Server: ALSA v: k5.4.0-26-generic
  Device-1: Qualcomm Atheros QCA8172 Fast Ethernet vendor: Lenovo
  driver: alx v: kernel port: 2000 bus ID: 02:00.0
  Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lenovo
  driver: ath9k v: kernel port: 2000 bus ID: 03:00.0
  Device-3: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
  bus ID: 3-3:4
  Local Storage: total: 480.78 GiB used: 1.89 GiB (0.4%)
  ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
  ID-2: /dev/sdb type: USB model: AI Mass size: 15.02 GiB
  ID-1: / size: 3.49 GiB used: 71.9 MiB (2.0%) fs: overlay source: ERR-102
  System Temperatures: cpu: 48.1 C mobo: N/A
  GPU: device: radeon temp: 46 C device: radeon temp: 46 C
  Processes: 210 Uptime: 5m Memory: 6.99 GiB used: 1.08 GiB (15.4%)
  Init: systemd runlevel: 5 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.16
  inxi: 3.0.38
Решил освоить новое и поставтиь Linux. В установщике выбрал стирание диска и установку. Все успешно установилось. При перезагрузке(и обычном запуске) ничего не происходит. Нет даже курсора. При выборе жесткого диска из boot menu появляется grub. Есть выбор LM 20, LM 20(восставление). Куда не нажимай, все равно черный экран который никак не меняется. Загрузочная флешка загружается.
В grub пробовал нажать клавишу е. Вписывал в предпоследнюю строчку самые разные вариации по типу nomodeset, nouveau.modeset=0. Так советовал гугл и ютуб.
Я только делаю первые шаги в постижении Linux. :hi3: Спасибо всем за внимание и за ответы!
Slav164
Благодарил (а): 12 раз
01 авг 2020, 03:14
Чем и как писал флешку?
01 авг 2020, 03:21
Я бы попробовал убрать в параметре загрузки ядра quiet splash и посмотреть где "спотыкается".
01 авг 2020, 07:12
Pel'meshka писал(а):
01 авг 2020, 00:44
Вот в этом месте собака порылась. При возможности покажите здесь фотки BIOS.
Благодарил (а): 794 раза
01 авг 2020, 08:42
01 авг 2020, 07:12
Это в лайв-сессии.
Pel'meshka, в UEFI необходимо отключить SecureBoot, включить загрузку в режиме uefi. В лайв-сессии запустить gparted(можно найти в меню программ), там выбрать свой ssd и сделать скриншот окна, чтоб можно было увидеть что там с разметкой диска.
01 авг 2020, 12:39
01 авг 2020, 08:42
Значит ты знаешь, что здесь -
01 авг 2020, 00:44
квадратные скобки означают.
Флешку для загрузки и установки в УЕФИ нужно сделать.
Pel'meshka
01 авг 2020, 18:52
Slav164 писал(а):
01 авг 2020, 03:14
UltraISO -> записать образ.
01 авг 2020, 18:55
Pel'meshka, Выбрал для ответа самый "крутой" вопрос?
Pel'meshka
01 авг 2020, 18:56
madesta писал(а):
01 авг 2020, 03:21
Пробовал. Никаких сообщений. Все тот же черный экран.
Pel'meshka
01 авг 2020, 19:02
01 авг 2020, 18:55
Я хочу ответить на все что понимаю. Что не понимаю, понять и ответить. UEFI, Secure boot, grub это пятна покрытые туманом. Я отвечу как могу всем. Тебе тоже. Спасибо за комменты, друг.
01 авг 2020, 19:05
01 авг 2020, 19:02
http://pogugli.com/?357071
Белый Кролик
Решено: 10
Благодарил (а): 354 раза
01 авг 2020, 19:21
Зайди в биос и в измени порядок загрузки, первым поставь "network boot", следом твой жесткий диск.
Slav164
01 авг 2020, 19:40
Pel'meshka, Запиши rufus'ом и выбери GPT.
Pel'meshka
01 авг 2020, 20:26
01 авг 2020, 08:42
01 авг 2020, 07:12
Это в лайв-сессии.
Спасибо друг. Если одновременно включить UEFI и выключить Boot Security, тогда происходила магия - диск переставало видеть, хотя полностью черный экран пропадал. Что-то писалось.
Но если выбрать только включить UEFI и оставить включенным Boot Security, то все заработало! :yahoo:
Вот разбивка в gparted. Ничего не менял как поставил LM в режиме чистой установки так и осталось.
01 авг 2020, 20:32
Pel'meshka, А кто надоумил делать на диске таблицу разделов MBR ?
Pel'meshka
01 авг 2020, 20:34
01 авг 2020, 07:12
01 авг 2020, 00:44
Вот он мой биос(который был до изменений). Может кому пригодится.
01 авг 2020, 20:41
01 авг 2020, 20:34
Я бы не посоветовал. Получилась смесь ежа и ужа. MBR , secure boot , Legacy support и UEFI First.
Pel'meshka
01 авг 2020, 20:45
01 авг 2020, 20:32
Я загуглил в одной из первых ссылок говорилось что так лучше, лучше стандартизация. Не помню где выбирать что выбрать GPT или MBR. В установщике этого не было. Может быть в консоли нашайтанил или в gparted.
Pel'meshka
01 авг 2020, 20:49
01 авг 2020, 20:41
01 авг 2020, 20:34
То был биос до изменений(на фото). Потом поставил UEFI вместо Legacy. Получается MBR, secure boot, UEFI. Что может произойти? И какая схема наиболее оптимальна.
01 авг 2020, 20:53
01 авг 2020, 20:49
Получается MBR
лучше GPT , MBR уже морально устарело.
Secure boot не позволит установить посторонний драйвер , если понадобится.
