Нужна помощь с настройкой экрана(пока только 640х480)
vityel
28 июл 2020, 18:52
Установил Linux Mint 18.3 на ноутбук Asus A4L (старенький ноутбук с памятью 960 Мбт). Не могу изменить разрешение экрана - доступно только 640х480.
Вот параметры системы:
elena@elena-A4L ~ $ inxi -Fxz
System: Host: elena-A4L Kernel: 4.10.0-38-generic i686 (32 bit gcc: 5.4.0)
Desktop: MATE 1.18.0 (Gtk 3.18.9-1ubuntu3.3)
Machine: System: ASUSTeK (portable) product: A4L v: 1.0
Mobo: ASUSTeK model: A4L v: 1.0
Bios: American Megatrends v: 0214 date: 03/31/2005
CPU: Single core Mobile Intel Pentium 4 (-HT-) cache: 1024 KB
flags: (pae sse sse2 sse3) bmips: 6133
clock speeds: max: 3059 MHz 1: 3059 MHz 2: 2394 MHz
Graphics: Card: Silicon Integrated Systems [SiS] 661/741/760 PCI/AGP or 662/761Gx PCIE VGA Display Adapter
bus-ID: 01:00.0
Display Server: X.Org 1.18.4 drivers: fbdev (unloaded: vesa)
Resolution: 640x480@73.00hz
GLX Renderer: llvmpipe (LLVM 6.0, 128 bits)
GLX Version: 3.0 Mesa 18.0.5 Direct Rendering: Yes
Audio: Card Silicon Integrated Systems [SiS] SiS7012 AC'97 Sound Controller
driver: snd_intel8x0 ports: e800 ec00 bus-ID: 00:02.7
Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Network: Card-1: Silicon Integrated Systems [SiS] SiS900 PCI Fast Ethernet
driver: sis900 port: d800 bus-ID: 00:04.0
IF: enp0s4 state: up speed: 100 Mbps duplex: full mac: <filter>
Card-2: Silicon Integrated Systems SiS162 usb Wireless LAN Adapter
usb-ID: 001-003
IF: null-if-id state: N/A mac: N/A
Drives: HDD Total Size: 60.0GB (13.0% used)
ID-1: /dev/sda model: IC25N060ATMR04 size: 60.0GB
Partition: ID-1: / size: 54G used: 6.4G (13%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 1.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 59.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 150 Uptime: 27 min Memory: 395.2/934.7MB
elena@elena-A4L ~ $ xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 480, current 640 x 480, maximum 640 x 480
default connected primary 640x480+0+0 0mm x 0mm
640x480 73.00*
Очень хочется чтобы он работал , но с таким разрешением работать практически невозможно..
Пробовал обновиться до ядра 4.15 - он не работает на нем, пришлось откатить на 4.10.
Очень нужна помощь.
Спасибо!
28 июл 2020, 18:53
vityel, 4.4 ядро попробуй...
vityel
28 июл 2020, 18:56
Ставил также 18.1 - с ядром по-моему 4.5 - таже проблема
29 июл 2020, 11:30
vityel, ты, случайно, не из запасника музея какого-нибудь музея сей ноут вынес?
vityel писал(а):
28 июл 2020, 18:52
Тут дистрибутив какой-нибудь нужен старый с ядром 2.6 и старыми иксами.
Хотя бы по форуму посмотрел что ли - https://www.linuxmint.com.ru/viewtopic.php?t=1729
vityel
29 июл 2020, 13:15
Я понимаю что с другим ноутбуком проблем нет, когда есть мерседес кого беспокоит проблемы с жигулями..
Но вопрос поставлен - есть Linux Mint 18.3 который прекрасно работает на этом ноутбуке, только проблема с разрешением.
Надеюсь что действительно разбирающиеся люди ответят......
29 июл 2020, 13:19
29 июл 2020, 13:36
vityel, тебе уже дали ссылку почитать в #4
vityel
30 июл 2020, 19:50
Спасибо, попробую поменять
vityel
31 июл 2020, 22:03
На все попытки xrandr --addmode "1280x800_60.00"
выдает ошибку:
не получается...
При этом больше не загружается.. зависает
01 авг 2020, 08:45
vityel, а оно тебе и не поможет - не то читал. Я же написал в каком сообщении дали ссылку. Нужна помощь с настройкой экрана(пока только 640х480) (Пост Unborn #103748)
