Ошибки при загрузке Linux Mint 20
Pran
28 июл 2020, 18:24
Всем привет!
При загрузке LM 20 x64 Cinnamon на ноутбуке HP Probook 450 G7:
System: Kernel: 5.4.0-42-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 4.6.6
Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Machine: Type: Laptop System: HP product: HP ProBook 450 G7 v: N/A serial: <filter>
Mobo: HP model: 86A0 v: KBC Version 02.2A.00 serial: <filter> UEFI: HP v: S71 Ver. 01.05.04 date: 05/11/2020
Battery: ID-1: BAT0 charge: 35.6 Wh condition: 45.5/45.5 Wh (100%) model: Hewlett-Packard Primary status: Unknown
Device-1: hidpp_battery_0 model: Logitech MX Vertical Advanced Ergonomic Mouse charge: 55% (should be ignored)
status: Discharging
CPU: Topology: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP arch: Kaby Lake rev: C L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36799
Speed: 785 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Graphics: Device-1: Intel UHD Graphics vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard driver: N/A bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.0.8 direct render: Yes
Audio: Device-1: Intel vendor: Hewlett-Packard driver: sof-audio-pci bus ID: 00:1f.3
Sound Server: ALSA v: k5.4.0-42-generic
Network: Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 5000 bus ID: 00:14.3
IF: wlp0s20f3 state: up mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 3000 bus ID: 02:00.0
Drives: Local Storage: total: 476.94 GiB used: 95.04 GiB (19.9%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN520 SDAPNUW-512G-1006 size: 476.94 GiB
Partition: ID-1: / size: 205.77 GiB used: 94.95 GiB (46.1%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: swap-1 size: 30.52 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/nvme0n1p6
Sensors: System Temperatures: cpu: 50.0 C mobo: 45.0 C
Info: Processes: 310 Uptime: 19m Memory: 15.05 GiB used: 2.40 GiB (15.9%) Init: systemd runlevel: 5 Compilers: gcc: 9.3.0
Shell: bash v: 5.0.17 inxi: 3.0.38
вываливается куча ошибок:
июл 28 17:55:52 Pran-ProBook-Mint kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20190816/exoparg2-393)
июл 28 17:55:52 Pran-ProBook-Mint kernel: ACPI Error: Aborting method \_TZ.GETP due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
июл 28 17:55:52 Pran-ProBook-Mint kernel: ACPI Error: Aborting method \_TZ.CHGZ._CRT due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
июл 28 17:55:53 Pran-ProBook-Mint systemd[1]: Failed to start VirtualBox Web Service.
июл 28 17:55:53 Pran-ProBook-Mint kernel: sof-audio-pci 0000:00:1f.3: error: no reply expected, received 0x0
июл 28 17:55:53 Pran-ProBook-Mint kernel: iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
июл 28 17:55:53 Pran-ProBook-Mint wpa_supplicant[807]: nl80211: kernel reports: Attribute failed policy validation
июл 28 17:55:53 Pran-ProBook-Mint wpa_supplicant[807]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
июл 28 17:55:53 Pran-ProBook-Mint wpa_supplicant[807]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
июл 28 17:55:54 Pran-ProBook-Mint kernel: Bluetooth: hci0: Failed to send Intel_Write_DDC (-22)
июл 28 17:55:55 Pran-ProBook-Mint lightdm[1094]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
июл 28 17:55:55 Pran-ProBook-Mint lightdm[1094]: PAM adding faulty module: pam_kwallet.so
июл 28 17:55:55 Pran-ProBook-Mint lightdm[1094]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
июл 28 17:55:55 Pran-ProBook-Mint lightdm[1094]: PAM adding faulty module: pam_kwallet5.so
июл 28 17:55:55 Pran-ProBook-Mint lightdm[1205]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
июл 28 17:55:55 Pran-ProBook-Mint lightdm[1205]: PAM adding faulty module: pam_kwallet.so
июл 28 17:55:55 Pran-ProBook-Mint lightdm[1205]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
июл 28 17:55:55 Pran-ProBook-Mint lightdm[1205]: PAM adding faulty module: pam_kwallet5.so
июл 28 17:56:01 Pran-ProBook-Mint lightdm[1205]: gkr-pam: unable to locate daemon control file
июл 28 17:56:01 Pran-ProBook-Mint pulseaudio[1118]: Error opening PCM device hw:sofhdadsp,6: No such device
На работоспособность ОС это не влияет (или я не заметил пока), всё работает нормально - и звук, и микрофон тоже. Но загрузочные сообщения раздражают. Тем более, что при загрузке Винды нету никаких сообщений.
Что с этим вообще делать? Может кто-то уже разобрался с аналогичными сообщениями? Заранее благодарен за дельный совет!
28 июл 2020, 18:30
Pran писал(а):
28 июл 2020, 18:24
нашёл что сравнивать :joke: та и при желании ничего не напишет, минимум в логах код ошибки, который надо искать на сайте мелкомягких, максимум синий экран с таким же кодом :-D
Pran писал(а):
28 июл 2020, 18:24
на это забей, это так новые ядра у большинства показывают что не могут найти инструкций, которые должны быть, но производитель не подвёз :) тут или пересобирать ядро или забить...
остальные ошибки я так понимаю ты уже не видишь, но реально какой-то трэшак с безопасностью навертел...
Pran
28 июл 2020, 18:36
Остальные ошибки тоже вижу :-). Причём двумя порциями.
Первая:
Вторая:
28 июл 2020, 18:44
Pran писал(а):
28 июл 2020, 18:24
Подобными сообщениями забит весь интернет. Основных советов 2 , или забить на них , или по возможности отключить их появление.
https://bbs.archlinux.org/viewtopic.php?id=235231
https://www.google.com/search?q=ACPI+BI ... e&ie=UTF-8
Pran
28 июл 2020, 21:04
28 июл 2020, 18:44
Pran писал(а):
28 июл 2020, 18:24
Насчёт первых строк про ACPI - согласен. На них проще забить. Но затем идут какие-то страшилки про WiFi, аудио, bluetooth и какой-то PMA. При том, что всё вроде как работает нормально.
Долго искал инфу про строку ошибки VitrualBox. Нашёл всего пару старых постов и те не по делу.
Склоняюсь к мысли, что железо сильно новое, Линуксом ещё не усвоенное.
29 июл 2020, 07:29
Pran писал(а):
28 июл 2020, 21:04
Да я бы не сказал что прям что-то кардинально новое. Можно ядро 5.7 притащить, но ошибки остануться.
Pran писал(а):
28 июл 2020, 18:24
Это баг https://forums.linuxmint.com/viewtopic.php?t=286950
Про wifi, тоже, судя по всему баг https://bbs.archlinux.org/viewtopic.php?id=246507
ilikethat
Решено: 10
Благодарил (а): 128 раз
29 июл 2020, 08:04
Pran, сорри, не по теме вопрос.
У Вас масштабирование экрана включено, на работающем Cinnamon?
Насколько удобно пользоваться FulHD на 15 дюймах? В смысле не мелкое все?
Pran
29 июл 2020, 09:50
29 июл 2020, 07:29
Pran писал(а):
28 июл 2020, 21:04
Pran писал(а):
28 июл 2020, 18:24
Огромное спасибо за решение по сообщениям PAM. После его применения эти сообщения пропали.
Pran
29 июл 2020, 09:53
ilikethat писал(а):
29 июл 2020, 08:04
Масштабирование не использую. Большую часть времени нотик работает на внешний 24' монитор. Зрение у меня не очень хорошее, однако некоторое время нормально работаю и на штатном 15' мониторе. Однако через пару часов глаза устают.
