МФУ Xerox B205 - драйвера для принтера и сканера установлены, принтер определяется при подключении его через USB, но печатать и сканировать отказывается.
LM 20 x64 Cinnamon.
Kernel: 5.4.0-39-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.6.6 Distro: Linux Mint 20 Ulyana
base: Ubuntu 20.04 focal
Type: Desktop Mobo: ASUSTeK model: H170-PRO v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 3805 date: 05/16/2018
Topology: Quad Core model: Intel Core i5-6600 bits: 64 type: MCP
arch: Skylake-S rev: 3 L2 cache: 6144 KiB
bogomips: 26399
Speed: 800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800
Device-1: NVIDIA GM206 [GeForce GTX 950] vendor: Gigabyte driver: nvidia
v: 440.100 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 950/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
Device-2: NVIDIA GM206 High Definition Audio vendor: Gigabyte
Sound Server: ALSA v: k5.4.0-39-generic
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 04:00.0
Local Storage: total: 2.04 TiB used: 477.78 GiB (22.9%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO M.2 120GB
ID-2: /dev/sdb vendor: Western Digital model: WD20EARS-00MVWB0
ID-3: /dev/sdc vendor: Western Digital model: WDS120G2G0A-00JH30
ID-1: / size: 109.53 GiB used: 17.62 GiB (16.1%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 53 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Processes: 247 Uptime: 52m Memory: 15.57 GiB used: 1.72 GiB (11.0%)
inxi: 3.0.38
bogomips: 26399
3: 800 4: 800
inxi: 3.0.38
Xerox B205 Linux PrintDriver_Utilities
