Initramfs unpacking failed: Decoding failed
Xen
19 июл 2020, 22:55
Всем привет!
Hw-probe - https://linux-hardware.org/?probe=8916655d52
Kernel: 5.4.0-40-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: MATE 1.24.0 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Type: Laptop System: Acer product: TravelMate P215-51G v: V1.08
serial: <filter>
Mobo: KBL model: Leo_KL v: V1.08 serial: <filter>
UEFI: American Megatrends v: 1.08 date: 08/13/2019
ID-1: BAT0 charge: 52.6 Wh condition: 52.6/51.5 Wh (102%) model: AP18H8L
status: Full
Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 6144 KiB
bogomips: 28800
Speed: 1471 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 803 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI
Device-2: NVIDIA GP108M [GeForce MX230] vendor: Acer Incorporated ALI
driver: nvidia v: 440.100 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: modesetting,nvidia
resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce MX230/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
Device-2: C-Media USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:2
Sound Server: ALSA v: k5.4.0-40-generic
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: d000
bus ID: 02:00.0
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: d000
bus ID: 03:00.0
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 1.14 TiB used: 181.02 GiB (15.5%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M8250G size: 232.89 GiB
ID-2: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
ID-1: / size: 46.68 GiB used: 16.57 GiB (35.5%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 46.68 GiB used: 10.25 GiB (22.0%) fs: ext4
dev: /dev/sda4
ID-3: swap-1 size: 16.39 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
System Temperatures: cpu: 55.0 C mobo: 27.8 C gpu: nvidia temp: 50 C
Processes: 268 Uptime: 7m Memory: 15.50 GiB used: 1.84 GiB (11.9%)
inxi: 3.0.38
Суть проблемы следующая.
Стоит HHD, на нём EFI + корень Mint 20, обновлённый из 19.3 + отдельно home + swap + ntfs разделы
Всё работает )))
Но я решил поставить m.2 NVMe SSD и завести систему уже там. Завести следующим образом - папку home подключить с HDD, старую систему не трогать, будет запасная. На новую систему хотел накатить образ из Timeshift, чтобы не переставлять весь софт. Ради прикола сделать там SWAP, посмотреть скорость работы при задействовании.
Устанавливаю в ручном режиме. Биос - AHCI. Второй режим - Intel Optane, он нам не нужен. Secure Boot отключен. После установки пишет мне Initramfs unpacking failed: Decoding failed, далее пишет, что не может найти раздел с определённым UUID, кидает на командную строку Initramfs.
Ошибка знакомая, но как решал - не помню. На всякий случай попробовал изменить компрессор на gzip и сделать rootdelay, переустановить grub через chroot - безрезультатно.
Fstab адекватный, запрашиваемого при загрузке UUID там не наблюдается и взяться ему неоткуда.
Помогает редактирование grub.cfg, где убирается строка root=UUID=62A4-EB15 . Тогда система грузится.
grub.cfg.zip
(2.33 КБ) 30 скачиваний
Вопрос 1 - как это сделать красиво, потому что при апдейте grub это дело слетит. Хотел бы понять суть проблемы.
Вопрос 2 - насколько реально накатить слепок с Timeshift и как лучше это сделать. Я включил перезапись Initramfs при восстановлении образа. Понятно, что корень восстанавливается в корень на другом харде, home сам в себя, а вот с EFI вопрос. Я пробовал с HDD на SDD. В итоге всё началось, но кончилось безжизненным чёрным экраном. Не утерпел, сделал reisub. Может зря. SSD перестал определятся, после обновления настроек биос завёлся. Правда не загружается, говорит ядра нет.
Заранее спасибо!
19 июл 2020, 23:52
Xen писал(а):
19 июл 2020, 22:55
https://wiki.archlinux.org/index.php/Fstab_(Русский) - теория здесь. И здесь: https://wiki.archlinux.org/index.php/GRUB_(Русский)
Читать внимательно, особенно части касающиеся UUID. До понимания и просветления - зачем они нужны, и почему отсутствие их в /etc/fstab - плохо, а не повод для гордости.
Xen писал(а):
19 июл 2020, 22:55
Что вы сделали? Сброс через SysRq?
Если да, то это не должно приводить к не определяющемуся диску даже в самом худшем случае. Максисмум - слетающая разметка и файловая система. А если вообще диск перестал определяться - это уже проблемы с железом, скорее всего...
Xen
20 июл 2020, 08:44
19 июл 2020, 23:52
Xen писал(а):
19 июл 2020, 22:55
Xen писал(а):
19 июл 2020, 22:55
Я, наверное, неправильно выразился.
Ничего лишнего в Fstab - это значит, что всё на месте. Всё, что должно быть. А вот UUID, который так требует GRUB, там нет. И не только там. Вообще непонятно, откуда он берёт этот UUID. Нет у меня таких разделов.
Да, SysRq. Диск потом завёлся.
Всё, я понял, он запрашивает UUID установочной флэшки с какого-то перепуга. Сейчас проверил - точно флэшка.
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-688ad9d2-8769-4a31-b7e9-6cb752830388' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_gpt
insmod ext2
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root 688ad9d2-8769-4a31-b7e9-6cb752830388
else
fi
linux /boot/vmlinuz-5.4.0-26-generic root=UUID=688ad9d2-8769-4a31-b7e9-6cb752830388 ro ignore_bootid live-media-path=/multibootusb/linuxmint-20-mate-64bit/casper floppy.allowed_drive_mask=0 ignore_uuid root=UUID=62A4-EB15 quiet splash $vt_handoff
initrd /boot/initrd.img-5.4.0-26-generic
Ну не должно быть два раза в одном пункте меню root=UUID , это глюк какой-то.
Xen
20 июл 2020, 22:12
Это default/grub, убрал там root=UUID=62A4-EB15, что бы при генерации grub.cfg было норм. Пробовал сносить grub через purge и ставить заново - та же картина. Откуда-то тянет root=UUID=62A4-EB15 всё равно.
# /boot/grub/grub.cfg.
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_CMDLINE_LINUX="ignore_bootid live-media-path=/multibootusb/linuxmint-20-mate-64bit/casper floppy.allowed_drive_mask=0 ignore_uuid root=UUID=62A4-EB15"
#GRUB_TERMINAL=console
#GRUB_GFXMODE=640x480
#GRUB_DISABLE_LINUX_UUID=true
#GRUB_DISABLE_RECOVERY="true"
#GRUB_INIT_TUNE="480 440 1"
20 июл 2020, 22:13
Xen писал(а):
20 июл 2020, 22:12
А это кто?
Xen
20 июл 2020, 22:16
20 июл 2020, 22:13
Xen писал(а):
20 июл 2020, 22:12
А это кто?
Ну как я понимаю, default/grub генерит grub.cfg . В default/grub эта строчка, как я понимаю, установочная флэшка. А почему она тут записана и откуда тянется при переустановке grub - вот тут и вопрос.
20 июл 2020, 22:18
приведи строку к виду GRUB_CMDLINE_LINUX="" и сделай апдейт.
Xen
21 июл 2020, 12:05
20 июл 2020, 22:18
Да, это поможет. Сейчас так и работаю. Просто вопрос, почему при полном сносе grub через purge и установке заново строка опять появляется. Откуда-то тянет её. И почему она вообще появилась.
21 июл 2020, 12:08
Xen писал(а):
21 июл 2020, 12:05
Непонятное действо. Что и как означает снос груб?
Xen
21 июл 2020, 12:11
21 июл 2020, 12:08
Xen писал(а):
21 июл 2020, 12:05
Точную команду не помню, через Boot Repair делал. Что-то типа purge grub* Он там просит в CMD ввести команды для сноса, потом ставит заново.
21 июл 2020, 12:12
Xen писал(а):
21 июл 2020, 12:11
Не читайте до обеда советских газет. :hoho:
Xen
21 июл 2020, 21:36
В общем, ставил я 20 mint, и 19 mint, и с общим home и с разными. Максимум, до чего я дошёл - установка дров на видяху. Всё равно, наступает момент, когда при перезагрузке система виснет, а при загрузке начинает жаловаться на SSD. В последний раз это было при первой накатке обновлений после установки. Лично я понял так, что данный SSD не очень совместим с Linux. Либо какой-то брак. Либо пока я его терзал, как половцы и печенеги, у него что-то поднакрылось. В общем, пойду возвращать, а там как выйдет.
