Установка или удаление пакетов программ не удалось.
cdmitriy
16 июл 2020, 19:15
Здравствуйте.
Сегодня скачал на linux mint cisco packet tracer. При попытке установить эту программу возникла ошибка.
Версия ОС:
Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
Desktop: Xfce 4.14.1 tk: Gtk 3.22.30 wm: xfwm4 dm: LightDM
[b]Вывод inxi -Fxz:[/b]
  Host:  Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: Xfce 4.14.1 Distro: Linux Mint 19.3 Tricia
  base: Ubuntu 18.04 bionic
  Type: Laptop System: Hewlett-Packard product: HP ProBook 4740s
  v: A1019D1103 serial: <filter>
  Mobo: Hewlett-Packard model: 1846 v: KBC Version 58.1D serial: <filter>
  BIOS: Hewlett-Packard v: 68IRR Ver. F.40 date: 01/29/2013
  ID-1: BAT0 charge: 0% condition: 73.4/73.4 Wh (100%)
  model: Hewlett-Packard Primary status: Unknown
  Topology: Quad Core model: Intel Core i7-3632QM bits: 64 type: MT MCP
  arch: Ivy Bridge rev: 9 L2 cache: 6144 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 35123
  Speed: 1413 MHz min/max: 1200/3200 MHz Core speeds (MHz): 1: 1413 2: 1276
  3: 1377 4: 1334 5: 1311 6: 1386 7: 1381 8: 1319
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
  Device-2: AMD Thames [Radeon HD 7550M/7570M/7650M] vendor: Hewlett-Packard
  driver: radeon v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.8 driver: ati,modesetting,radeon
  unloaded: fbdev,vesa resolution: 1600x900~60Hz
  OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 19.2.8
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe
  vendor: Hewlett-Packard driver: rt2800pci v: 2.3.0 port: 3000
  bus ID: 04:00.0
  IF: wlo1 state: down mac: <filter>
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 2000 bus ID: 05:00.0
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 465.76 GiB used: 75.04 GiB (16.1%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
  ID-1: / size: 18.21 GiB used: 6.87 GiB (37.7%) fs: ext4 dev: /dev/sda5
  ID-2: /home size: 62.43 GiB used: 34.09 GiB (54.6%) fs: ext4
  dev: /dev/sda7
  ID-3: swap-1 size: 5.59 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-0
  System Temperatures: cpu: 43.0 C mobo: N/A gpu: radeon temp: 48 C
  Processes: 244 Uptime: 10h 16m Memory: 5.70 GiB used: 2.37 GiB (41.7%)
  inxi: 3.0.32
Сама суть ошибки:
При попытке установить программу выдаётся ошибка:
(Reading database ...
(Reading database ... 5%%
(Reading database ... 10%%
(Reading database ... 15%%
(Reading database ... 20%%
(Reading database ... 25%%
(Reading database ... 30%%
(Reading database ... 35%%
(Reading database ... 40%%
(Reading database ... 45%%
(Reading database ... 50%%
(Reading database ... 55%%
(Reading database ... 60%%
(Reading database ... 65%%
(Reading database ... 70%%
(Reading database ... 75%%
(Reading database ... 80%%
(Reading database ... 85%%
(Reading database ... 90%%
(Reading database ... 95%%
(Reading database ... 100%%
(Reading database ... 261968 files and directories currently installed.)
Preparing to unpack .../PacketTracer_730_amd64.deb ...
dpkg: error processing archive /home/sdl/Downloads/PacketTracer_730_amd64.deb (--install):
 new packettracer package pre-installation script subprocess returned error exit status 1
gtk-update-icon-cache: Cache file created successfully.
Попробовал погуглить. Что пробовал сделать:
/var/lib/dpkg/info/ - думал тут найти пакеты связанные с packet tracer, но тут ничего нет.
/var/cache/apt/archives/ - аналогично пробовал тут искать, но ничего не нашел.
Подскажите пожалуйста где копать? Как я понял проблема возникает с каким-то скриптом.
16 июл 2020, 19:31
cdmitriy, Прежде чем что то делать , надо обновить систему после установки. Для начала.
И соблюдать форматирование в теме.
cdmitriy
16 июл 2020, 20:34
16 июл 2020, 19:31
Сама система стоит уже около полу года. Сейчас обновил систему через терминал, но увы не помогло.
16 июл 2020, 20:44
cdmitriy
16 июл 2020, 21:51
16 июл 2020, 20:44
https://zenway.ru/forum/viewtopic.php?id=623
Спасибо большое! Помогло.
16 июл 2020, 21:52
cdmitriy писал(а):
16 июл 2020, 21:51
Помогло.
Опиши , что именно.
Вернуться в «Xfce»
