Проблема со стиранием текста с зажатым Backspace
tarlax
07 июл 2020, 16:07
Версия OC: Linux Mint 20 x64
DE: Cinnamon
Моё железо (вывод inxi -Fxz):
Kernel: 5.4.0-40-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.6.6 Distro: Linux Mint 20 Ulyana
base: Ubuntu 20.04 focal
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter>
Mobo: Gigabyte model: 990XA-UD3 v: x.x serial: <filter>
BIOS: American Megatrends v: FD date: 02/04/2013
Topology: 8-Core model: AMD FX-8320 bits: 64 type: MCP arch: Bulldozer
L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 56258
Speed: 1575 MHz min/max: 1400/3500 MHz Core speeds (MHz): 1: 1407 2: 1408
3: 1406 4: 1392 5: 1408 6: 1417 7: 1452 8: 1409
Device-1: AMD Cedar [Radeon HD 5000/6000/7350/8350 Series]
vendor: Gigabyte driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1920x1080~60Hz, 1024x768~75Hz
OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 5.4.0-40-generic LLVM 10.0.0)
v: 3.3 Mesa 20.0.8 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:14.2
Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.4.0-40-generic
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus ID: 03:00.0
Local Storage: total: 1.82 TiB used: 10.11 GiB (0.5%)
ID-1: /dev/sda vendor: Toshiba model: DT01ACA200 size: 1.82 TiB
ID-1: / size: 196.04 GiB used: 10.11 GiB (5.2%) fs: ext4 dev: /dev/sda7
ID-2: swap-1 size: 3.81 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
System Temperatures: cpu: 34.8 C mobo: N/A gpu: radeon temp: 56 C
Processes: 254 Uptime: 29m Memory: 7.80 GiB used: 2.32 GiB (29.7%)
Init: systemd runlevel: 5 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.16
inxi: 3.0.38
Суть проблемы: Когда ввожу какой-то текст и пытаюсь стереть его, приходится для удаления каждого символа отдельно нажимать на клавишу backspace. Обыкновенно, как в принципе и должно быть, для стирания текста можно просто зажать backspace, и каждый символ последовательно, быстро начнёт стираться, пока backspace не будет разжат. Также имеется подобная проблема и с клавишами-стрелками: при зажатии любой из них, во время введения текста, текстовый курсор-мигающая-линия перемещается лишь на один символ или строку, а не, как должно бы быть, последовательно перемещается к каждому следующему символу, пока клавиша не будет разжата.
Решение symon2014 » 07 июл 2020, 16:22
tarlax, Меню - параметры - параметры клавиатуры - общие - повтор нажатой клавиши.
07 июл 2020, 16:12
tarlax, в чём?
tarlax
07 июл 2020, 16:22
07 июл 2020, 16:12
tarlax, в чём?
Вообще во всём, в любом приложении - от ввода текста в текстовом редакторе и работы в терминале до поля ввода запроса в Гугле и оформления этой темы. Везде не хочет стираться текст при зажатии бекспейса.
07 июл 2020, 16:22
tarlax
07 июл 2020, 16:34
07 июл 2020, 16:22
Спасибо, помогло.
07 июл 2020, 19:38
:close:
