Не видит wifi
Paquito
Не видит wifi
26 июн 2020, 18:35
Здравствуйте.
Установил и обновил Linux Mint 19.3 "Tricia" - Cinnamon (64-bit)
Host: paco Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Laptop System: Acer product: Nitro AN515-54 v: V1.09
serial: <filter>
Mobo: CFL model: Octavia_CFS v: V1.09 serial: <filter> UEFI: Insyde
v: 1.09 date: 08/02/2019
ID-1: BAT1 charge: 59.8 Wh condition: 59.8/58.8 Wh (102%)
model: Simplo PABAS0241231 status: Unknown
Topology: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
arch: Kaby Lake rev: D L2 cache: 8192 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38400
Speed: 900 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 915 2: 900
3: 986 4: 900 5: 920 6: 924 7: 940 8: 962
Device-1: Intel vendor: Acer Incorporated ALI driver: i915 v: kernel
bus ID: 00:02.0
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: N/A bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics 630 (Coffeelake 3x8 GT2)
v: 4.5 Mesa 19.2.8 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 01:00.1
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-2: Intel driver: N/A port: 3000 bus ID: 07:00.0
IF-ID-1: enp0s20f0u1 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 931.51 GiB used: 6.87 GiB (0.7%)
ID-1: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
RAID:
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 bus ID: 00:17.0
ID-1: / size: 913.75 GiB used: 6.78 GiB (0.7%) fs: ext4 dev: /dev/dm-1
ID-2: /boot size: 704.5 MiB used: 83.9 MiB (11.9%) fs: ext4 dev: /dev/sda2
ID-3: swap-1 size: 976.0 MiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-2
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 252 Uptime: 21m Memory: 15.51 GiB used: 1.63 GiB (10.5%)
inxi: 3.0.32
Не видит wi-fi. То есть вообще как-будто адаптера не существует.
Не видит wifi
26 июн 2020, 18:40
Paquito, покажи вывод
lspci -knn | grep -A2 "Net"
Не видит wifi
26 июн 2020, 19:01
Paquito писал(а):
26 июн 2020, 18:35
Обновиться после установки системы.
strannik
Не видит wifi
26 июн 2020, 19:47
Установи оптический диск или носитель с образом МИНТа.
Затем, после появления иконки на рабочем столе, запусти МЕНЕДЖЕР ДРАЙВЕРОВ.
В окне менеджера выбери нужную позицию и нажми кнопку.
После установки драйвера WIFI система потребует перезагрузку.
Перезагружайся.
Paquito
Не видит wifi
26 июн 2020, 21:17
26 июн 2020, 18:40
07:00.0 Network controller [0280]: Intel Corporation Device [8086:2723] (rev 1a)
Subsystem: Intel Corporation Device [8086:0084]
Paquito
Не видит wifi
26 июн 2020, 21:18
strannik писал(а):
26 июн 2020, 19:47
Перезагружайся.
то есть все-таки надо снова все переустанавливать?
Paquito
Не видит wifi
26 июн 2020, 21:18
26 июн 2020, 19:01
Paquito писал(а):
26 июн 2020, 18:35
Да уже вроде как все что можно обновил)
Whowka
Благодарил (а): 777 раз
Не видит wifi
26 июн 2020, 21:32
Paquito писал(а):
26 июн 2020, 21:18
Ну, для начала, можно внимательней прочитать #4 и попробовать перезагрузиться. :smile:
Paquito
Не видит wifi
26 июн 2020, 23:02
Whowka писал(а):
26 июн 2020, 21:32
Paquito писал(а):
26 июн 2020, 21:18
У меня в менеджере драйверов только вот что
Не видит wifi
27 июн 2020, 05:52
Paquito писал(а):
26 июн 2020, 21:18
Paquito писал(а):
26 июн 2020, 21:18
Я специально процитировал версию ядра из представленных данных. Она говорит о том , что систему после установки не обновляли.
Не видит wifi
27 июн 2020, 17:30
27 июн 2020, 05:52
Её и установили то...
Вернуться в «Работа с сетью»
