Средняя кнопка мыши вставляет текст, несмотря на настройку
LamantinoLinuxmint
18 июн 2020, 19:22
Уточняю, что после применения настройки компьютер был перезагружен несколько раз
Host: edmond-OMEN-by-HP-Laptop-17-an0xx Kernel: 5.0.0-32-generic x86_64
bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.5
Type: Laptop System: HP product: OMEN by HP Laptop 17-an0xx v: N/A
serial: <filter>
Mobo: HP model: 8392 v: 40.26 serial: <filter> UEFI: American Megatrends
v: F.15 date: 02/26/2018
ID-1: BAT0 charge: 46.3 Wh condition: 76.2/76.2 Wh (100%)
model: HP Primary status: Discharging
Topology: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP
arch: Kaby Lake rev: 9 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19968
Speed: 900 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 968 2: 995
3: 974 4: 942
Device-1: Intel vendor: Hewlett-Packard driver: i915 v: kernel
bus ID: 00:02.0
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 440.59 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.4 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa tty: N/A
OpenGL: renderer: GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 440.59
Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus ID: 01:00.1
vendor: Hewlett-Packard driver: r8169 v: kernel port: c000 bus ID: 03:00.0
IF: eno1 state: down mac: <filter>
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: c000
bus ID: 04:00.0
Local Storage: total: 1.03 TiB used: 20.05 GiB (1.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW128HEGR-000H1
ID-2: /dev/sda vendor: HGST (Hitachi) model: HTS721010A9E630
ID-1: / size: 116.38 GiB used: 20.04 GiB (17.2%) fs: ext4
dev: /dev/nvme0n1p5
System Temperatures: cpu: 61.0 C mobo: N/A gpu: nvidia temp: 51 C
Processes: 285 Uptime: 23m Memory: 7.67 GiB used: 4.40 GiB (57.4%)
inxi: 3.0.32
18 июн 2020, 19:25
Мы офигенно рады за тебя.
18 июн 2020, 19:30
ЕМНИП, из того что читал в сети про эту фичу - оно захардкожено, и, вроде как, не отключается.
Но читал давно и фиг его знает как оно сейчас.
А что ты делаешь средней кнопкой?
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
18 июн 2020, 21:28
В циннамоне такой настройки нет. Есть в Гноме и Мате.
Но если очень надо - то можно отключить среднюю кнопку мыши, в англоязычном инете есть несколько инструкций.
19 июн 2020, 11:13
Уточняю - вставка по нажатию средней кнопки в позицию курсора последний выделенный где-то в другом месте текст - это поведение самих X-ов, то самое - почти захардкоженное. На самом деле нет, просто по умолчанию и настолько привычное, что никто даже не задумывается настройку в графике делать. А вот если средняя кнопка вставляет содержимое буффера обмена - это уже паталогия, и косяк DE.
По сути - есть два буфера - один самих X-ов, вставка из которого происходит средней кнопкой (а помещается туда текст автоматически как только завершается процесс выделения), и нормальный - тот что доступен через контекстные меню DE или Ctrl-C - Ctrl-V / Ctrl-Ins - Shift-Ins. Обычно они независимы, чем многие активно пользуются. Буффер X-ов не зависит от DE, и работает "ниже" его. Даже в самой голой X-сессии.
