Баг при перисовки
wwe2012
Баг при перисовки
17 июн 2020, 09:42
У меня стоит LinuxMint 19.3 XFCE
Как эту можно решить проблему
Информация про ПК
Host: HP-Compaq-dc5750-Microtower Kernel: 5.4.0-37-generic x86_64 bits: 64
compiler: gcc v: 7.5.0 Desktop: Xfce 4.14.1 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Desktop System: Hewlett-Packard product: HP Compaq dc5750 Microtower
v: N/A serial: <filter>
Mobo: Hewlett-Packard model: 0A64h serial: <filter> BIOS: Hewlett-Packard
v: 786E3 v02.10 date: 01/25/2007
Topology: Dual Core model: AMD Athlon 64 X2 3800+ bits: 64 type: MCP
arch: K8 rev.F+ rev: 2 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 svm bogomips: 7980
Speed: 2000 MHz min/max: 1000/2000 MHz Core speeds (MHz): 1: 2000 2: 2000
Device-1: AMD RS482/RS485 [Radeon Xpress 1100/1150]
vendor: Hewlett-Packard DC5750 Microtower driver: radeon v: kernel
bus ID: 01:05.0
Display: x11 server: X.Org 1.20.8 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1280x1024~60Hz
OpenGL: renderer: ATI RS480 v: 2.1 Mesa 19.2.8 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Hewlett-Packard DC5750 Microtower
driver: snd_hda_intel v: kernel bus ID: 00:14.2
Sound Server: ALSA v: k5.4.0-37-generic
Device-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
driver: 8139too v: 0.9.28 port: 1100 bus ID: 07:04.0
IF: enp7s4 state: unknown speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom and subsidiaries NetXtreme BCM5755 Gigabit Ethernet PCI
Express
vendor: Hewlett-Packard DC5750 Microtower driver: tg3 v: 3.137 port: 1100
bus ID: 3f:00.0
IF: enp63s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 149.05 GiB used: 36.44 GiB (24.4%)
ID-1: /dev/sda vendor: Hitachi model: HDS721616PLA380 size: 149.05 GiB
ID-1: / size: 54.04 GiB used: 14.01 GiB (25.9%) fs: ext4 dev: /dev/sda3
ID-2: /boot size: 1.91 GiB used: 169.3 MiB (8.7%) fs: ext4 dev: /dev/sda2
ID-3: /home size: 86.01 GiB used: 22.19 GiB (25.8%) fs: ext4
dev: /dev/sda4
ID-4: swap-1 size: 4.00 GiB used: 76.0 MiB (1.9%) fs: swap dev: /dev/sda1
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 210 Uptime: 1h 25m Memory: 2.80 GiB used: 1.55 GiB (55.4%)
inxi: 3.0.32
Последний раз редактировалось пользователем 2 wwe2012; всего редактировалось раз: 17
Баг при перисовки
17 июн 2020, 09:47
wwe2012, а теперь подними глаза и прочитай что написано в красном поле - тут нет экстрасенсов.
wwe2012
Баг при перисовки
17 июн 2020, 09:53
17 июн 2020, 09:47
Исправил
Баг при перисовки
17 июн 2020, 09:57
wwe2012, это все что ты смог после прочтения - ну тогда сиди и жди, может кому-то будет скучно и он поможет тебе с такими вводными данными.
Баг при перисовки
17 июн 2020, 10:01
rogoznik, судя по всему , чёрные полоски. Но мне не скучно. :hoho:
И кто такая перисовка. :-D
wwe2012
Баг при перисовки
17 июн 2020, 11:04
Что еще надо сделать, что бы устроить проблему
Баг при перисовки
17 июн 2020, 11:10
wwe2012 писал(а):
17 июн 2020, 11:04
Это смотря какую проблему ты хочешь получить :-D
А по теме - поменяй композитор.
Баг при перисовки
17 июн 2020, 12:46
wwe2012 писал(а):
17 июн 2020, 11:04
Выучить и сдать ЕГЭ по русскому языку.
Real
Баг при перисовки
17 июн 2020, 13:12
чёт вспомнился б0ян
"Если в слове [хлеб] сделать четыре ошибки, то получится слово [пиво]" (c)
Вернуться в «Xfce»
