ошибки при старте системы
Ctyx
Благодарил (а): 64 раза
15 июн 2020, 19:12
Всем привет! Возник вопрос по ошибкам во время загрузки системы - хотя после старта проблем не возникает, но... как-то "неуютно". :sad:
Инфо о системе и железе:
ctyx@ctyx-pc:~$ inxi -Fxz
System: Kernel: 5.4.0-37-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Xfce 4.14.2 Distro: Linux Mint 20 Ulyana
base: Ubuntu 20.04 focal
Machine: Type: Laptop System: ASUSTeK product: K52Jc v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K52Jc v: 1.0 serial: <filter> BIOS: American Megatrends v: K52Jc.206 date: 03/29/2010
CPU: Topology: Dual Core model: Intel Core i3 M 350 bits: 64 type: MT MCP arch: Nehalem rev: 2 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18630
Speed: 1237 MHz min/max: 933/2266 MHz Core speeds (MHz): 1: 1108 2: 1210 3: 1117 4: 1214
Graphics: Device-1: Intel Core Processor Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GT218M [GeForce 310M] vendor: ASUSTeK driver: nouveau v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 20.0.4 direct render: Yes
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Device-2: NVIDIA High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.4.0-37-generic
Network: Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: AzureWave AW-NE785 / AW-NE785H 802.11bgn
driver: ath9k v: kernel port: d000 bus ID: 03:00.0
IF: wls1 state: down mac: <filter>
Device-2: JMicron JMC250 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: jme v: 1.0.8 port: a000
bus ID: 04:00.5
IF: ens5f5 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 344.68 GiB used: 140.26 GiB (40.7%)
ID-1: /dev/sda vendor: Kingston model: SA400S37120G size: 111.79 GiB temp: 33 C
ID-2: /dev/sdb vendor: Seagate model: ST9250315AS size: 232.89 GiB temp: 36 C
Partition: ID-1: / size: 28.29 GiB used: 8.25 GiB (29.2%) fs: ext4 dev: /dev/sdb1
ID-2: /home size: 61.05 GiB used: 8.29 GiB (13.6%) fs: ext4 dev: /dev/sdb4
ID-3: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdb3
Sensors: System Temperatures: cpu: 52.0 C mobo: N/A gpu: nouveau temp: 51 C
Info: Processes: 221 Uptime: 17m Memory: 5.60 GiB used: 1.32 GiB (23.5%) Init: systemd runlevel: 5 Compilers: gcc: 9.3.0
Shell: bash v: 5.0.16 inxi: 3.0.38
Выхлоп на команду
$ journalctl -b -p err
ctyx@ctyx-pc:~$ journalctl -b -p err
-- Logs begin at Fri 2020-06-12 21:10:39 MSK, end at Mon 2020-06-15 18:58:37 MSK. --
июн 15 18:46:40 ctyx-pc kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000003) is beyond end of object (length 0x0) (20190816/exoparg2-393)
июн 15 18:46:40 ctyx-pc kernel: ACPI Error: Aborting method \_SB.PCI0.GFX0._DSM due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
июн 15 18:46:40 ctyx-pc kernel: ACPI Error: Aborting method \_SB.PCI0.PEG1.GFX0._DSM due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
июн 15 18:46:40 ctyx-pc blkmapd[400]: open pipe file /run/rpc_pipefs/nfs/blocklayout failed: No such file or directory
июн 15 18:46:45 ctyx-pc kernel: hdaudio hdaudioC1D0: no AFG or MFG node found
июн 15 18:46:45 ctyx-pc kernel: hdaudio hdaudioC1D1: no AFG or MFG node found
июн 15 18:46:45 ctyx-pc kernel: hdaudio hdaudioC1D2: no AFG or MFG node found
июн 15 18:46:45 ctyx-pc kernel: hdaudio hdaudioC1D3: no AFG or MFG node found
июн 15 18:46:45 ctyx-pc kernel: hdaudio hdaudioC1D4: no AFG or MFG node found
июн 15 18:46:45 ctyx-pc kernel: hdaudio hdaudioC1D5: no AFG or MFG node found
июн 15 18:46:45 ctyx-pc kernel: hdaudio hdaudioC1D6: no AFG or MFG node found
июн 15 18:46:45 ctyx-pc kernel: hdaudio hdaudioC1D7: no AFG or MFG node found
июн 15 18:46:45 ctyx-pc kernel: snd_hda_intel 0000:01:00.1: no codecs initialized
июн 15 18:46:57 ctyx-pc ntpd[906]: error resolving pool 0.ubuntu.pool.ntp.org: Name or service not known (-2)
июн 15 18:46:57 ctyx-pc ntpd[906]: error resolving pool 1.ubuntu.pool.ntp.org: Name or service not known (-2)
июн 15 18:46:58 ctyx-pc ntpd[906]: error resolving pool 2.ubuntu.pool.ntp.org: Name or service not known (-2)
июн 15 18:46:58 ctyx-pc nfsdcltrack[957]: Failed to init database: -13
июн 15 18:46:59 ctyx-pc ntpd[906]: error resolving pool 3.ubuntu.pool.ntp.org: Name or service not known (-2)
июн 15 18:47:05 ctyx-pc lightdm[1069]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
июн 15 18:47:05 ctyx-pc lightdm[1069]: PAM adding faulty module: pam_kwallet.so
июн 15 18:47:05 ctyx-pc lightdm[1069]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
июн 15 18:47:05 ctyx-pc lightdm[1069]: PAM adding faulty module: pam_kwallet5.so
июн 15 18:47:13 ctyx-pc lightdm[1151]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
июн 15 18:47:13 ctyx-pc lightdm[1151]: PAM adding faulty module: pam_kwallet.so
июн 15 18:47:13 ctyx-pc lightdm[1151]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
июн 15 18:47:13 ctyx-pc lightdm[1151]: PAM adding faulty module: pam_kwallet5.so
июн 15 18:47:16 ctyx-pc lightdm[1151]: gkr-pam: unable to locate daemon control file
июн 15 18:47:17 ctyx-pc pulseaudio[1094]: Error opening PCM device front:0: Нет такого файла или каталога
Это с новым ядром связано для моего старенького железа?
Благодарил (а): 794 раза
15 июн 2020, 19:29
Ctyx писал(а):
15 июн 2020, 19:12
Не может обновить время с инета. Скорее всего просто сеть еще не поднялась.
Ctyx писал(а):
15 июн 2020, 19:12
lightdm зачем-то хочет библиотеку pam_kwallet5.so(это кдешно проги)
Ctyx
15 июн 2020, 19:35
Спасибо за ответ, попробую подтянуть эту библиотеку. Но во время загрузки проскакивает вот этот абзац:
Благодарил (а): 1736 раз
15 июн 2020, 19:41
Ctyx, это новые ядра... тут или пересобирать ядро под свою железку или забить... ни на что не влияет, просто не может найти функции новые...
Ctyx
15 июн 2020, 19:45
15 июн 2020, 19:41
понятно, я так и предположил - на минте 19.3 ошибок нет, а на 20 убунте и соответствено "Ульяне" - ругается на ACPI
15 июн 2020, 19:46
Ctyx, ну у меня на буке с пятого ядра это началось... так что тут как повезёт с железкой :)
15 июн 2020, 19:48
Ctyx, я как-то поднимал подобную тему на форуме с подобными ошибками - много думали, так и не решили что кому надо и я забил.
15 июн 2020, 19:50
15 июн 2020, 19:48
дык разгребать DSDT таблицы под каждую железку офигеешь...
Ctyx
15 июн 2020, 19:51
В общем можно отметить тему как решенную - "забей!!!" :joke:
15 июн 2020, 19:52
Ctyx, да просто закрой и все, а то набегут "умники" и начнут давать "лучшие в мире советы"
15 июн 2020, 19:53
Ctyx писал(а):
15 июн 2020, 19:51
Забито. :close:
