bluetoothe не видит устройства
Telegrammer
06 июн 2020, 18:54
Хочу подключить мышь, а ноут не видит ничего.
g-gun@ggun-HP-Stream-Notebook:~$ inxi -Fxz
  Host: ggun-HP-Stream-Notebook Kernel: 5.3.0-53-generic x86_64 bits: 64
  compiler: gcc v: 7.5.0 Desktop: MATE 1.22.2 Distro: Linux Mint 19.3 Tricia
  base: Ubuntu 18.04 bionic
  Type: Laptop System: HP product: HP Stream Notebook
  v: Type1ProductConfigId serial: <filter>
  Mobo: HP model: 815E v: 32.25 serial: <filter> UEFI [Legacy]: Insyde
  v: F.12 date: 01/05/2016
  ID-1: BAT0 charge: 33.1 Wh condition: 35.3/35.3 Wh (100%)
  model: Hewlett-Packard Primary status: Discharging
  Topology: Dual Core model: Intel Celeron N3050 bits: 64 type: MCP
  arch: Airmont rev: 3 L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 6400
  Speed: 1532 MHz min/max: 480/2160 MHz Core speeds (MHz): 1: 1073 2: 846
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
  Integrated Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (Braswell)
  v: 4.5 Mesa 19.2.8 direct render: Yes
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
  High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k5.3.0-53-generic
  Device-1: Broadcom and subsidiaries BCM43142 802.11b/g/n
  vendor: Hewlett-Packard driver: wl v: kernel port: 1040 bus ID: 02:00.0
  Local Storage: total: 29.12 GiB used: 20.84 GiB (71.6%)
  ID-1: /dev/mmcblk0 model: BGND3R size: 29.12 GiB
  ID-1: / size: 26.89 GiB used: 10.23 GiB (38.1%) fs: ext4 dev: /dev/dm-1
  ID-2: /boot size: 703.5 MiB used: 167.2 MiB (23.8%) fs: ext4
  dev: /dev/mmcblk0p1
  ID-3: swap-1 size: 979.5 MiB used: 220.9 MiB (22.5%) fs: swap
  dev: /dev/dm-3
  System Temperatures: cpu: 45.0 C mobo: N/A
  Processes: 202 Uptime: 5h 28m Memory: 1.80 GiB used: 1.04 GiB (58.0%)
  inxi: 3.0.32
06 июн 2020, 18:58
Telegrammer, если воткнут в юсб мышковод , то покажи lsusb
Telegrammer
06 июн 2020, 18:59
06 июн 2020, 18:58
Мышка то беспроводная) Даже адаптера нету и шнура
06 июн 2020, 19:01
Telegrammer писал(а):
06 июн 2020, 18:59
У мышки должен быть родной модуль в комплекте. Просто по блютузу её не увидеть.
Telegrammer
06 июн 2020, 19:03
06 июн 2020, 19:01
06 июн 2020, 18:59
Раскрою тебе небольшую тайну, есть такие у которых ничего нету. Майкрософт мышка Мышь Microsoft Modern Mobile Mouse черный оптическая (1000dpi) беспроводная BT (2but)
Telegrammer
06 июн 2020, 19:04
Причем ее видит даже мой айфон.
06 июн 2020, 19:06
06 июн 2020, 19:03
Если ты знаешь такие тайны , что же не подключишь?
Telegrammer
06 июн 2020, 19:12
Я не все тайны знаю) И это наверное единственная тайна которую знаю) Я бы подключил если бы она отображалась в ноуте, но увы =(
06 июн 2020, 19:13
06 июн 2020, 19:04
А он не может подсказать её имя ? Если ты не можешь.
06 июн 2020, 19:31
Telegrammer, а ноут видит твой айфон?
Telegrammer
06 июн 2020, 19:46
06 июн 2020, 19:13
06 июн 2020, 19:04
Modern Mobile Mouse
Telegrammer
06 июн 2020, 19:48
06 июн 2020, 19:31
вообше ничего не видит по блютузу.не наушники,не мышь, не колонку
06 июн 2020, 19:49
06 июн 2020, 19:46
Modern Mobile Mouse
Вот прямо это всё , и ни циферек ни буковок больше?
06 июн 2020, 19:51
Тут скорее всего адаптер wifi совмещенный с bluetooth. А драйвер не дает работать bluetooth. Придется искать патченый драйвер, собирать его и ставить.
06 июн 2020, 19:54
06 июн 2020, 19:51
У меня работает совмещённый , только слава богу не броадком.
Telegrammer
06 июн 2020, 19:54
06 июн 2020, 19:49
06 июн 2020, 19:46
Modern Mobile Mouse
Telegrammer
06 июн 2020, 19:56
06 июн 2020, 19:51
сложна для меня уже) ладно с чего мне начать? искать драйвер под мой адаптер на линукс?
06 июн 2020, 19:57
06 июн 2020, 19:54
У тебя какой язык родной? Чёрная оптическая беспроводная , это модель такая?
Telegrammer
06 июн 2020, 19:58
06 июн 2020, 19:57
06 июн 2020, 19:54
у меня русский )
это так на сайте она называется )
06 июн 2020, 20:03
06 июн 2020, 19:58
а у меня в компьтере так называется .
ID 046d:c077 Logitech, Inc. M105 Optical Mouse
тоже чёрная.
