проблема с драйвером от nvidia
Валентин
06 июн 2020, 10:55
Товарищи , кто может подскажите.
На ноутбуке Asus k24jv не получается установить проприетарный драйвер от nvidia.
информация об устройстве
[quote]lg-virt:~$ inxi -Fxz
  Host: lg-virt Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: Cinnamon 4.4.5 Distro: Linux Mint 19.3 Tricia
  base: Ubuntu 18.04 bionic
  Type: Laptop System: ASUSTeK product: K42Jv v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: K42Jv v: 1.0 serial: <filter>
  BIOS: American Megatrends v: K42Jv.210 date: 12/15/2010
  ID-1: BAT0 charge: 39.5 Wh condition: 39.5/72.6 Wh (54%)
  model: ASUSTek K52F-44 status: Full
  Topology: Dual Core model: Intel Core i3 M 350 bits: 64 type: MT MCP
  arch: Nehalem rev: 2 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18088
  Speed: 1463 MHz min/max: 933/2266 MHz Core speeds (MHz): 1: 1463 2: 1463
  3: 1463 4: 1463
  Device-1: Intel Core Processor Integrated Graphics vendor: ASUSTeK
  Device-2: NVIDIA GT215M [GeForce GT 335M] vendor: ASUSTeK driver: nouveau
  v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz, 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel Ironlake Mobile v: 2.1 Mesa 19.0.8
  Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: ASUSTeK
  Device-2: NVIDIA High Definition Audio driver: snd_hda_intel v: kernel
  bus ID: 01:00.1
  Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
  vendor: AzureWave AW-NE785 / AW-NE785H 802.11bgn driver: ath9k v: kernel
  port: d000 bus ID: 03:00.0
  IF: wls1 state: up mac: <filter>
  Device-2: JMicron JMC250 PCI Express Gigabit Ethernet vendor: ASUSTeK
  driver: jme v: 1.0.8 port: 9000 bus ID: 07:00.5
  IF: ens5f5 state: down mac: <filter>
  Local Storage: total: 119.01 GiB used: 14.85 GiB (12.5%)
  ID-1: /dev/sda vendor: Patriot model: Blast size: 111.79 GiB
  ID-2: /dev/sdb type: USB model: USB DISK 2.0 size: 7.21 GiB
  ID-1: / size: 109.53 GiB used: 8.59 GiB (7.8%) fs: ext4 dev: /dev/sda1
  System Temperatures: cpu: 43.0 C mobo: N/A gpu: nouveau temp: 48 C
  Processes: 226 Uptime: 12h 06m Memory: 3.64 GiB used: 1.71 GiB (46.9%)
  inxi: 3.0.32
lg@lg-virt:~$ lspci | grep -E "VGA"
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 12)
01:00.0 VGA compatible controller: NVIDIA Corporation GT215M [GeForce GT 335M] (rev a2)
[/quote]
при попытке установки пробовал использовать рекомендации с оф сайта http://us.download.nvidia.com/XFree86/L ... river.html
результат показан на изображении .
при установки с репозитория происходит крах графической оболочки "Cinnamon запущен в безопасном режиме"
также важное отступление в Biose нет возможности отключить питание интеловской графики
если кто может подскажите или подкинте мысли куда и как копать .
 ! Сообщение из: symon2014
Не забываем о форматировании.
Решение Ара Магеддон » 08 июн 2020, 05:55
Но если хочется - то можно попробовать откатиться на ядро 4.15. (тут должно быть несколько топиков, как именно это сделать, ядра 5.х лучше сразу удалить).
Куча проблем со связкой Интел/нвидиа на ноутах вылезла именно на ядре 5.3
06 июн 2020, 11:26
Валентин писал(а):
06 июн 2020, 10:55
куда и как копать .
Копать в ширь и в глубь до обеда.
Судя по инфе на пожилой бук только что установлена система. Отсюда вопрос , при установке отмечался пункт для установки дополнительного ПО? Во всяком случае , сначала надо обновить систему , и снова показать вывод inxi -Fxz
06 июн 2020, 11:56
Валентин писал(а):
06 июн 2020, 10:55
Лучше не пытаться.
Валентин писал(а):
06 июн 2020, 10:55
Хм. А сразу после установки ОС была эта ошибка?
Валентин писал(а):
06 июн 2020, 10:55
driver: nouveau
У тебя сейчас работает свободный драйвер для невидии вот его и оставь. Для твоей железки самое то.
Валентин
07 июн 2020, 10:27
Раньше был установлен проприетарный драйвер от nvidia. Устанавливал с min'tom 18 из репозитория через терминал. отключая в биосе одну видиокарту.
Система недавно установлена поскольку самостоятельное решении проблемы привело к краху граф. оболочки. При установке отмечался пункт установка стороннего ПО.
После установки системы ошибок нет, они появляются при попытки установки проприетарного драйвера. Система обновлена до последней актуальной версии. Сейчас работает драйвер xserver-xorg-video-nouveau( свободный драйвер).
lg@lg-virt:~$ inxi -Fxz
  Host: lg-virt Kernel: 5.3.0-53-generic x86_64 bits: 64 compiler: gcc
  v: 7.5.0 Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18087
  Speed: 1654 MHz min/max: 933/2266 MHz Core speeds (MHz): 1: 1364 2: 1475
  3: 1334 4: 1525
  Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
  OpenGL: renderer: Mesa DRI Intel Ironlake Mobile v: 2.1 Mesa 19.2.8
  bus ID: 01:00.1
  Sound Server: ALSA v: k5.3.0-53-generic
  Local Storage: total: 141.20 GiB used: 61.77 GiB (43.7%)
  ID-1: / size: 109.53 GiB used: 57.71 GiB (52.7%) fs: ext4 dev: /dev/sda1
  System Temperatures: cpu: 63.0 C mobo: N/A gpu: nouveau temp: 59 C
  Processes: 250 Uptime: 22h 25m Memory: 3.64 GiB used: 2.16 GiB (59.5%)
  inxi: 3.0.32
07 июн 2020, 10:54
Валентин писал(а):
07 июн 2020, 10:27
Вот и сиди на нем. Для твоей видяхи нет разницы закрытый драйвер или свободный. Производительность будет одинаковой. У кого-то производительность даже больше на свободном драйвере. Это все относиться к старым картам.
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
08 июн 2020, 05:55
Валентин
24 июл 2020, 20:37
Проблема решена. В кратце инструкция.
1. Установка ядра 4.12 // именно это ядро поскольку на нем не возникало ошибок по совместимости графической оболочки cinnamon и проприетарного драйвера от nvidia
2. Удаление лишниз ядер // с этим пунктом пришлось конкретно повозится
3. Пполучение удовольствия от достижения желаемого результата.
Спасибо за подсказку. :thumbs:
Вернуться в «Видеокарты»
