Linux mint 19.3 Cinnamon, Nvidia, xorg.conf
Anonim19992
Благодарил (а): 18 раз
29 май 2020, 04:46
Необходима помощь с конфигом (точнее, с его расположением). При сохранении его в etc/X11/xorg.conf - черный экран с мышкой. ((После перезагрузки компьютера (примечание*))
Host: anton-MS-7A34 Kernel: 5.3.0-53-generic x86_64 bits: 64 compiler: gcc
v: 7.5.0 Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Laptop Mobo: Micro-Star model: B350 TOMAHAWK (MS-7A34) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.00 date: 02/15/2017
Topology: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
rev: 1 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 76656
Speed: 1375 MHz min/max: 1550/3200 MHz Core speeds (MHz): 1: 1431 2: 1393
3: 1410 4: 1416 5: 1458 6: 1410 7: 1433 8: 1515 9: 1455 10: 1443 11: 1385
12: 1376
Device-1: NVIDIA GK104 [GeForce GTX 760] vendor: Gigabyte driver: nvidia
v: 435.21 bus ID: 23:00.0
Display: x11 server: X.Org 1.19.6 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa
resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 760/PCIe/SSE2 v: 4.6.0 NVIDIA 435.21
Device-1: NVIDIA GK104 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 23:00.1
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 25:00.3
Sound Server: ALSA v: k5.3.0-53-generic
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus ID: 21:00.0
IF: enp33s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.71 TiB used: 390.43 GiB (22.3%)
ID-1: /dev/sda vendor: OCZ model: VERTEX4 size: 119.24 GiB
ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-08WN4A0
ID-3: /dev/sdc type: USB vendor: Western Digital model: WD5000LMVW-11VEDS3
ID-4: /dev/sdd vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
ID-1: / size: 116.82 GiB used: 36.51 GiB (31.3%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 435.27 GiB used: 253.07 GiB (58.1%) fs: ext4
dev: /dev/sdb1
System Temperatures: cpu: 52.6 C mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
Processes: 361 Uptime: 24m Memory: 7.79 GiB used: 2.33 GiB (30.0%)
inxi: 3.0.32
Последний раз редактировалось пользователем 1 Anonim19992; всего редактировалось раз: 29
Anonim19992
29 май 2020, 05:13
watch?v=2NyF3lDW6yE - ссылка на ютуб с отображением данной проблемы (полную ссылку кидать не могу) (записывал видео для другого момента, увидел такой момент)
Благодарил (а): 1226 раз
29 май 2020, 06:10
Anonim19992 писал(а):
29 май 2020, 05:13
Интересно, почему?
https://www.youtube.com/watch?v=2NyF3lDW6yE
29 май 2020, 07:42
Anonim19992
29 май 2020, 08:55
29 май 2020, 07:42
https://youtu.be/fxJFb8CkKac
Спасибо за сарказм, но можно пожалуйста их помечать offtop иками?)))
На видео видно, что при записи видео через OBS появляются полосы. Есть решение, но для этого нужно сохранять xorg.conf файл. Однако, я столкнулся с проблемой последующего захода в систему. После ввода пароля на экране блокировки появляется лишь курсор, включается музыка приветствия и все. Поэтому я и задал тему в сий чате для помощи (даже вставил лог с inxi -Fxz :smile: ). Я могу конечно каждый раз при заходе в систему это проделывать, но это вообще не тот момент, что должен радовать.
Anonim19992
29 май 2020, 08:56
hellonet писал(а):
29 май 2020, 06:10
29 май 2020, 05:13
Интересно, почему?
Помню, ловил тут 1 человек за ссылки на сторонние ресурсы =))) поэтому и стараюсь их не постить.
29 май 2020, 09:29
29 май 2020, 08:56
ловил тут 1 человек
не человек а злой модер )) И в твоих двух строчках поста ничего толком не написано . Да и в пяти последующих тоже. Я лично до сих пор не улавливаю связи между артефактами в ролике ( о чём ты в первом посте не упомянул) и xorg.conf , откуда ты это взял (ссылку на пруф)).
https://youtu.be/Bcy9L7Sf2MM
Anonim19992
29 май 2020, 09:37
https://obsproject.com/forum/threads/sc ... iew.25977/ Думаю, вместо тысячи слов описывает всю суть проблемы. Есть решение (там же). Это добавление "{ForceFullCompositionPipeline = On}". Но. После перезагрузки у меня не стартует линукс (черный экран с курсором мышки).
29 май 2020, 09:40
Anonim19992, Не по теме , в телеге арча случайно не ты обсуждаешь эту тему? Тольо что там увидел. Если не ты , то может это баг какой?
а ссылке 5 лет уже.
Anonim19992
29 май 2020, 09:41
29 май 2020, 09:40
а ссылке 5 лет уже.
Вчера=) Правда не в телеге (хотя, если это называется телегой, то сорян) а на данном сайте в чате * Насчет времени знаю. Поэтому и уточняю)
29 май 2020, 09:45
https://t.me/ArchLinuxChatRU/485235
Дата сегодняшняя. А твоей ссылке из поста выше 5 лет , попахивает уже. И xorg.conf давно уже ведёт себя не так , как раньше.
29 май 2020, 09:56
https://youtu.be/k-bSOGxffjE
без артефактов , букву прозевал)))
Anonim19992
29 май 2020, 10:09
и это болячка Nvidia =((
29 май 2020, 10:11
Anonim19992, попробуй драйвер постарее применить.
Anonim19992
29 май 2020, 10:14
и уберется вулкан + проблема не решится =( т.к. давняя как кости мамонта =)
Anonim19992
29 май 2020, 11:18
Проверил /etc/X11/xorg.conf.d/20-nvidia.conf, тоже мимо=(
Сейчас этот форум просматривают: Google [Bot] и 2 гостя
