OBS не запускается
OriginalNickname
OBS не запускается
14 май 2020, 19:48
При запуске из меню приложений ничего не происходит, из bash:
qt5ct: using qt5ct plugin
Attempted path: share/obs/obs-studio/locale/en-US.ini
Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
Attempted path: share/obs/obs-studio/locale.ini
Attempted path: /usr/share/obs/obs-studio/locale.ini
Attempted path: share/obs/obs-studio/themes/Dark.qss
Attempted path: /usr/share/obs/obs-studio/themes/Dark.qss
info: CPU Name: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
info: CPU Speed: 4337.443MHz
info: Physical Cores: 6, Logical Cores: 12
info: Physical Memory: 32103MB Total, 2225MB Free
info: Kernel Version: Linux 4.19.0-8-amd64
info: Distribution: "LMDE" "4"
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.4
info: Portable mode: false
qt5ct: D-Bus global menu: no
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_destroyed()
QMetaObject::connectSlotsByName: No matching signal for on_program_customContextMenuRequested(QPoint)
info: OBS 0.0.1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 44100
speakers: 2
info: Initializing OpenGL...
obs: Fatal IO error 22 (Invalid argument) on X server :0.
Железо:
GPU: Nvidia GTX 1030
CPU: i7-8700K
Логи:
05:38:25 PM.218: CPU Name: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
05:38:25 PM.218: CPU Speed: 4400.137MHz
05:38:25 PM.219: Physical Cores: 6, Logical Cores: 12
05:38:25 PM.219: Physical Memory: 32103MB Total, 2195MB Free
05:38:25 PM.219: Kernel Version: Linux 4.19.0-8-amd64
05:38:25 PM.219: Distribution: "LMDE" "4"
05:38:25 PM.219: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.4
05:38:25 PM.220: Portable mode: false
05:38:25 PM.234: OBS 0.0.1 (linux)
05:38:25 PM.234: ---------------------------------
05:38:25 PM.234: audio settings reset:
05:38:25 PM.234: samples per sec: 44100
05:38:25 PM.234: speakers: 2
05:38:25 PM.240: ---------------------------------
05:38:25 PM.240: Initializing OpenGL...
(Остальные - такие же, в ~/.config/obs-studio/ ничего интересного больше нет)
Как заставить его работать?
OBS не запускается
20 май 2020, 14:06
OriginalNickname писал(а):
14 май 2020, 19:48
Вся фишечка в этом сообщении. OBS жалуется что не видит X-сервер на дисплее :0
Как ставили OBS, по рецепту для минт с оф-сайта?
И еще вопрос, драйвера для видео устанавливали? Покажите пожалуйста вывод inxi -Fxz
Вернуться в «LMDE»
